rtems.git build broken(?) for --enable-rtemsbsp=psim with samples: multiple definition of `_POSIX_Once_Lock'
Nick Withers
nick at nickwithers.com
Sat Aug 17 03:26:54 UTC 2013
Hullo all,
It seems perhaps the rtems.git build is broken for the "psim" BSP, with
samples enabled (at least "hello"): multiple definitions of "_POSIX_Once_Lock".
It builds for the "mvme3100" BSP without error with or without samples
Last little bit from the "make" ("gmake" on my FreeBSD 9.2-PRERELEASE,
r254324, host) output:
____
gmake[3]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/wrapup'
Making all in testsuites
gmake[3]: Entering directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites'
Making all in samples
gmake[4]: Entering directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples'
gmake all-recursive
gmake[5]: Entering directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples'
Making all in hello
gmake[6]: Entering directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples/hello'
powerpc-rtems4.11-gcc -B../../../../../psim/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I. -I../../../../../../../../rtems/c/src/../../testsuites/samples/hello -I.. -meabi -mcpu=603e -msdata=sysv -fno-common -Dppc603e -O2 -g -fno-keep-inline-functions -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o ../../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c
mv -f .deps/init.Tpo .deps/init.Po
powerpc-rtems4.11-gcc -B../../../../../psim/lib/ -specs bsp_specs -qrtems -meabi -mcpu=603e -msdata=sysv -fno-common -Dppc603e -O2 -g -fno-keep-inline-functions -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -meabi -mcpu=603e -msdata=sysv -fno-common -Dppc603e -o hello.exe init.o
../../../../../psim/lib/librtemscpu.a(libposix_a-once.o): In function `_POSIX_Once_Manager_initialization':
/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/cpukit/posix/../../../../../../../rtems/c/src/../../cpukit/posix/src/once.c:30: multiple definition of `_POSIX_Once_Lock'
../../../../../psim/lib/librtemscpu.a(libsapi_a-posixapi.o):/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/cpukit/sapi/../../../../../../../rtems/c/src/../../cpukit/sapi/src/posixapi.c:50: first defined here
collect2: error: ld returned 1 exit status
gmake[6]: *** [hello.exe] Error 1
gmake[6]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples/hello'
gmake[5]: *** [all-recursive] Error 1
gmake[5]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples'
gmake[4]: *** [all] Error 2
gmake[4]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c'
gmake: *** [all-recursive] Error 1
____
Nick Withers
email: nick at nickwithers.com
Web: http://www.nickwithers.com
Mobile: +61 414 397 446
