[PATCH] Updating legacy code in arm nds
    Vipul Nayyar
    nayyar_vipul at yahoo.com
    Sun Aug 18 14:34:51 UTC 2013
 c/src/lib/libbsp/arm/gba/irq/irq.h                 |  2 +
 c/src/lib/libbsp/arm/nds/Makefile.am               | 14 +++++
 c/src/lib/libbsp/arm/nds/clock/clock.c             | 40 ++++++++-------
 c/src/lib/libbsp/arm/nds/include/bsp.h             |  5 ++
 c/src/lib/libbsp/arm/nds/include/irq.h             | 21 ++++++++
 c/src/lib/libbsp/arm/nds/irq/irq.c                 | 59 ++++++++++++++++++++++
 .../nds/libnds/source/common/interruptDispatcher.S | 45 ++---------------
 c/src/lib/libbsp/arm/nds/preinstall.am             | 12 +++++
 c/src/lib/libbsp/arm/nds/startup/bspstart.c        |  3 +-
 9 files changed, 142 insertions(+), 59 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/nds/include/irq.h
diff --git a/c/src/lib/libbsp/arm/gba/irq/irq.h b/c/src/lib/libbsp/arm/gba/irq/irq.h
index d0c841f..224cf9b 100644
--- a/c/src/lib/libbsp/arm/gba/irq/irq.h
+++ b/c/src/lib/libbsp/arm/gba/irq/irq.h
@@ -61,4 +61,6 @@
 #define BSP_INTERRUPT_VECTOR_MAX (BSP_MAX_INT - 1)
+void bsp_interrupt_dispatch();
 #endif /* _IRQ_H_ */
diff --git a/c/src/lib/libbsp/arm/nds/Makefile.am b/c/src/lib/libbsp/arm/nds/Makefile.am
index 2776974..6de2601 100644
--- a/c/src/lib/libbsp/arm/nds/Makefile.am
+++ b/c/src/lib/libbsp/arm/nds/Makefile.am
@@ -54,6 +54,20 @@ rtc_rel_SOURCES = rtc/rtc.c ../../shared/tod.c
 rtc_rel_CPPFLAGS = $(AM_CPPFLAGS) -DARM9 -I$(srcdir)/libnds/include
 rtc_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
+include_bsp_HEADERS = ../../shared/include/irq-generic.h
+include_bsp_HEADERS += ../../shared/include/irq-info.h
+include_bsp_HEADERS += include/irq.h
+libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
+libbsp_a_SOURCES += ../../shared/src/irq-generic.c
+libbsp_a_SOURCES += ../../shared/src/irq-info.c
+libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
+libbsp_a_SOURCES += ../../shared/src/irq-server.c
+libbsp_a_SOURCES += ../../shared/src/irq-shell.c
+libbsp_a_SOURCES += irq/irq.c
+libbsp_a_CPPFLAGS = $(AM_CPPFLAGS) -DARM9 -I$(srcdir)/libnds/include -I$(srcdir)/include
+libbsp_a_LDFLAGS = $(RTEMS_RELLDFLAGS)
 noinst_PROGRAMS += console.rel
 console_rel_SOURCES = console/console.c
 console_rel_CPPFLAGS = $(AM_CPPFLAGS) -DARM9 -I$(srcdir)/libnds/include -I$(srcdir)/include
diff --git a/c/src/lib/libbsp/arm/nds/clock/clock.c b/c/src/lib/libbsp/arm/nds/clock/clock.c
index b263e55..5e37941 100644
--- a/c/src/lib/libbsp/arm/nds/clock/clock.c
+++ b/c/src/lib/libbsp/arm/nds/clock/clock.c
@@ -14,13 +14,15 @@
 #include <bsp.h>
+#include <bsp/irq.h>
 #include <rtems/irq.h>
 #include <nds.h>
+#include <assert.h>
  * forward declaration for clock isr in clockdrv_shell.h
-void Clock_isr(rtems_irq_hdl_param arg);
+void Clock_isr(void * arg);
  * forward declarations for methods in this file
@@ -28,18 +30,6 @@ void Clock_isr(rtems_irq_hdl_param arg);
 void Clock_driver_support_shutdown_hardware (void);
 void Clock_driver_support_initialize_hardware (void);
- * isr registration variables.
-static rtems_irq_connect_data clock_isr_data = {
-  .name   = IRQ_TIMER0,
-  .hdl    = Clock_isr,
-  .handle = NULL,
-  .on     = NULL,
-  .off    = NULL,
-  .isOn   = NULL,
 void update_touchscreen (void);
@@ -53,9 +43,17 @@ void update_touchscreen (void);
  * install isr for clock driver.
 #define Clock_driver_support_install_isr( _new, _old ) \
-  do {						       \
-    _old = NULL;				       \
-    BSP_install_rtems_irq_handler(&clock_isr_data);    \
+  do {                                                 \
+    rtems_status_code status = RTEMS_SUCCESSFUL;       \
+    _old = NULL;                                       \
+    status = rtems_interrupt_handler_install(          \
+      IRQ_TIMER0,                                      \
+      "Clock",                                         \
+      RTEMS_INTERRUPT_UNIQUE,                          \
+      Clock_isr,                                       \
+      NULL                                             \
+    assert(status == RTEMS_SUCCESSFUL);                \
   } while (0)
@@ -63,7 +61,15 @@ void update_touchscreen (void);
-  BSP_remove_rtems_irq_handler (&clock_isr_data);
+  status = rtems_interrupt_handler_remove(
+    IRQ_TIMER0,
+    Clock_isr,
+    NULL
   TIMER_CR (0) &= ~(TIMER_ENABLE);
diff --git a/c/src/lib/libbsp/arm/nds/include/bsp.h b/c/src/lib/libbsp/arm/nds/include/bsp.h
index 3565841..3b20be2 100644
--- a/c/src/lib/libbsp/arm/nds/include/bsp.h
+++ b/c/src/lib/libbsp/arm/nds/include/bsp.h
@@ -23,6 +23,11 @@ extern "C"
 #include <rtems/console.h>
 #include <rtems/clockdrv.h>
+#define BSP_FEATURE_IRQ_EXTENSION
+#define ARM9
+//#define ARM7
   struct rtems_bsdnet_ifconfig;
   int
diff --git a/c/src/lib/libbsp/arm/nds/include/irq.h b/c/src/lib/libbsp/arm/nds/include/irq.h
new file mode 100644
index 0000000..dff89b0
--- /dev/null
+++ b/c/src/lib/libbsp/arm/nds/include/irq.h
@@ -0,0 +1,21 @@
+ * @file
+ * @ingroup bsp_interrupt
+ * @brief Nintendo DS Interrupt definitions.
+#ifndef LIBBSP_ARM_NDS_IRQ_H
+#define LIBBSP_ARM_NDS_IRQ_H
+#ifndef ASM
+  #include <rtems.h>
+  #include <rtems/irq.h>
+  #include <rtems/irq-extension.h>
+#endif
+#define BSP_INTERRUPT_VECTOR_MIN	0
+#define BSP_INTERRUPT_VECTOR_MAX	25
+#endif /* LIBBSP_ARM_NDS_IRQ_H */
diff --git a/c/src/lib/libbsp/arm/nds/irq/irq.c b/c/src/lib/libbsp/arm/nds/irq/irq.c
index 1ffcd4d..e29cac7 100644
--- a/c/src/lib/libbsp/arm/nds/irq/irq.c
+++ b/c/src/lib/libbsp/arm/nds/irq/irq.c
@@ -9,10 +9,69 @@
  * http://www.rtems.com/license/LICENSE
+#include <rtems/score/armv4.h>
+#include <rtems/score/armv7m.h>
 #include <bsp.h>
 #include <nds.h>
+#include <bsp/irq-generic.h>
+void IntrMain(void);  // Prototype for assembly interrupt dispatcher
+rtems_status_code bsp_interrupt_facility_initialize(void)
+  /* disable all interrupts */
+  REG_IE  = 0;      // disable all interrupts
+  REG_IF  = IRQ_ALL;    // clear all pending interrupts
+  REG_IME = 1;      // enable global interrupt
+  IRQ_HANDLER = IntrMain;
+  return RTEMS_SUCCESSFUL;
+void bsp_interrupt_handler_default(rtems_vector_number vector)
+  printk("spurious interrupt: %u\n", vector);
+void bsp_interrupt_dispatch(void)
+  unsigned reg_ie = REG_IE;
+  unsigned reg_if = REG_IF & reg_ie;
+  rtems_vector_number vector = (*(vuint16*)0x04000208);
+  // not sure how to use reg_if here.
+  bsp_interrupt_handler_dispatch(vector);
+rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector){
+  if (vector & IRQ_VBLANK)
+    REG_DISPSTAT |= DISP_VBLANK_IRQ ;
+  if (vector & IRQ_HBLANK)
+    REG_DISPSTAT |= DISP_HBLANK_IRQ ;
+  if (vector & IRQ_VCOUNT)
+    REG_DISPSTAT |= DISP_YTRIGGER_IRQ;
+  REG_IE |= vector;
+  REG_IME = 1;
+rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector){
+    REG_DISPSTAT &= ~DISP_VBLANK_IRQ ;
+    REG_DISPSTAT &= ~DISP_HBLANK_IRQ ;
+    REG_DISPSTAT &= ~DISP_YTRIGGER_IRQ;
+  REG_IE &= ~vector;
  * this function check that the value given for the irq line is valid.
diff --git a/c/src/lib/libbsp/arm/nds/libnds/source/common/interruptDispatcher.S b/c/src/lib/libbsp/arm/nds/libnds/source/common/interruptDispatcher.S
index 927fa74..f1a651d 100644
--- a/c/src/lib/libbsp/arm/nds/libnds/source/common/interruptDispatcher.S
+++ b/c/src/lib/libbsp/arm/nds/libnds/source/common/interruptDispatcher.S
@@ -29,9 +29,9 @@
 	.section	.bsp_fast_text,"ax",%progbits
 #endif
-	.extern	irqTable
-	.code 32
+	.extern bsp_interrupt_dispatch
+	.code 32
 	.global	IntrMain
 IntrMain:
@@ -43,44 +43,12 @@ IntrMain:
 	mrs	r0, spsr
 	stmfd	sp!, {r0-r1,r3,lr}	@ {spsr, IME, REG_BASE, lr_irq}
-	ldr	r1, [r3,#0x210]		@ REG_IE
-	ldr	r2, [r3,#0x214]		@ REG_IF
-	and	r1,r1,r2
 	ldr	r0,=__irq_flags		@ defined by linker script
 	ldr	r2,[r0]
 	orr	r2,r2,r1
 	str	r2,[r0]
-	ldr	r2,=irqTable
- at ---------------------------------------------------------------------------------
-findIRQ:
-	ldr r0, [r2, #4]
-	cmp	r0,#0
-	beq	no_handler
-	ands	r0, r0, r1
-	bne	jump_intr
-	add	r2, r2, #8
-	b	findIRQ
-no_handler:
-	str	r1, [r3, #0x0214]	@ IF Clear
-	ldmfd   sp!, {r0-r1,r3,lr}	@ {spsr, IME, REG_BASE, lr_irq}
-	str	r1, [r3, #0x208]	@ restore REG_IME
-	mov	pc,lr
-jump_intr:
-	ldr	r1, [r2]		@ user IRQ handler address
-	cmp	r1, #0
-	bne	got_handler
-	mov	r1, r0
-	b	no_handler
 got_handler:
@@ -90,18 +58,13 @@ got_handler:
 	orr	r2, r2, #0x1f		@ /  --> Enable IRQ & FIQ. Set CPU mode to System.
 	msr	cpsr,r2
-	str	r0, [r3, #0x0214]	@ IF Clear
+	str r0, [r3, #0x0214] @ IF Clear
-	push	{lr}
-	adr	lr, IntrRet
-	bx	r1
+	b 	bsp_interrupt_dispatch
 IntrRet:
-	mov	r3, #0x4000000		@ REG_BASE
-	str	r3, [r3, #0x208]	@ disable IME
-	pop	{lr}
 	mrs	r3, cpsr
 	bic	r3, r3, #0xdf		@ \__
diff --git a/c/src/lib/libbsp/arm/nds/preinstall.am b/c/src/lib/libbsp/arm/nds/preinstall.am
index e0555de..e36d648 100644
--- a/c/src/lib/libbsp/arm/nds/preinstall.am
+++ b/c/src/lib/libbsp/arm/nds/preinstall.am
@@ -78,6 +78,18 @@ $(PROJECT_INCLUDE)/nds/sound.h: sound/sound.h $(PROJECT_INCLUDE)/nds/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/nds/sound.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/nds/sound.h
+$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
+$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
+$(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
 $(PROJECT_INCLUDE)/libnds/$(dirstamp):
 	@$(MKDIR_P) $(PROJECT_INCLUDE)/libnds
 	@: > $(PROJECT_INCLUDE)/libnds/$(dirstamp)
diff --git a/c/src/lib/libbsp/arm/nds/startup/bspstart.c b/c/src/lib/libbsp/arm/nds/startup/bspstart.c
index b57d758..1914aec 100644
--- a/c/src/lib/libbsp/arm/nds/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/nds/startup/bspstart.c
@@ -23,7 +23,8 @@ extern void BSP_rtems_irq_mngt_init (void);
 void bsp_start (void)
   /* initialize irq management */
-  BSP_rtems_irq_mngt_init ();
+  bsp_interrupt_initialize();
+  REG_IME = IME_ENABLE;
   /* setup console mode for lower screen */
   irqEnable (IRQ_VBLANK);
1.7.11.7
