[PATCH RTEMS 4.10-git] bsp/csb336: Memory map update to support i.MX1 based PiMX1 as well.
Pavel Pisa ppisa4lists at pikron.com
Mon Aug 19 12:22:26 UTC 2013
CSB336 i.MX1/i.MXS memory map organization
 - SDRAM starts at address 0x08000000 but 2 MB are reserved
   for boot-block/loader (or other use) before RTEMS image
   origin/load address (that is kept from previous setup)
 - Caching of 30 MB of SDRAM used for RTEMS (start at 0x08200000)
   is changed to writeback mode which provides higher throughput.
 - The first 1 MB of RTEMS dedicated SDRAM is remapped to address 0
   to provide area for ARM CPU exceptions table.
 - Internal registers and rest of the Flash (above 1 MB) are mapped
   one to one. Registers region is extended to 2 MB to cover
   eSRAM found on i.MX1 chip variant.
 - The first two megabytes of SDRAM unused by RTEMS are mapped
   with attributes to allow specific purposes.
   - the first MB (at address 0x08000000) is nocached to allow
     directly set some values read by booot-block after warm reset
   - the second MB (at address 0x08100000) is set for write-through
     caching.  That allows to use memory for LCD frame-buffer without
     need to flush cache after each redraw.
Signed-off-by: Pavel Pisa <pi at baree.pikron.com>
 c/src/lib/libbsp/arm/csb336/startup/memmap.c |   10 +++++++---
 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/arm/csb336/startup/memmap.c b/c/src/lib/libbsp/arm/csb336/startup/memmap.c
index 356bea7..3d5b98a 100644
--- a/c/src/lib/libbsp/arm/csb336/startup/memmap.c
+++ b/c/src/lib/libbsp/arm/csb336/startup/memmap.c
@@ -19,10 +19,14 @@
 mmu_sect_map_t mem_map[] = {
 /*  <phys addr>  <virt addr> <size> <flags> */
-    {0x08200000, 0x00000000,   1,    MMU_CACHE_NONE},     /* Mirror of SDRAM */
+    {0x08200000, 0x00000000,   1,    MMU_CACHE_WBACK},    /* Mirror of SDRAM */
     {0x00100000, 0x00100000,   1,    MMU_CACHE_NONE},     /* Bootstrap ROM */
-    {0x00200000, 0x00200000,   1,    MMU_CACHE_NONE},     /* Internal Regs */
-    {0x08000000, 0x08000000,  32,    MMU_CACHE_WTHROUGH}, /* SDRAM */
+    {0x00200000, 0x00200000,   2,    MMU_CACHE_NONE},     /* Internal Regs + eSRAM */
+    {0x08000000, 0x08000000,   1,    MMU_CACHE_NONE},     /* SDRAM */
+    {0x08100000, 0x08100000,   1,    MMU_CACHE_WTHROUGH}, /* SDRAM */
+    {0x08200000, 0x08200000,  30,    MMU_CACHE_WBACK},    /* SDRAM */
     {0x10000000, 0x10000000,   8,    MMU_CACHE_NONE},     /* CS0 - Flash */
     {0x12000000, 0x12000000,   1,    MMU_CACHE_NONE},     /* CS1 - enet */
     {0x13000000, 0x13000000,   1,    MMU_CACHE_NONE},     /* CS2 - */
1.7.10.4
