[PATCH 1/6] add atomic init function
WeiY wei.a.yang at gmail.com
Mon Aug 19 15:39:43 UTC 2013
 cpukit/score/include/rtems/score/atomic.h       |   27 ++++++++++++++++++++++
 cpukit/score/include/rtems/score/cpustdatomic.h |   28 +++++++++++++++++++++++
 2 files changed, 55 insertions(+)
diff --git a/cpukit/score/include/rtems/score/atomic.h b/cpukit/score/include/rtems/score/atomic.h
index d94ac92..db70fe8 100644
--- a/cpukit/score/include/rtems/score/atomic.h
+++ b/cpukit/score/include/rtems/score/atomic.h
@@ -32,6 +32,33 @@ extern "C" {
+ * @brief atomic data initializer for static initialization.
+#define ATOMIC_VAR_INITIALIZER(value) CPU_ATOMIC_INITIALIZER(value)
+ * @brief Initializes an atomic type value into a atomic object.
+ * @param object an atomic type pointer of object.
+ * @param value a value to be stored into object.
+RTEMS_INLINE_ROUTINE void _Atomic_Init_uint(
+  volatile Atomic_Uint *object,
+  uint_fast32_t value
+  _CPU_atomic_Init_uint(object, value);
+RTEMS_INLINE_ROUTINE void _Atomic_Init_ptr(
+  volatile Atomic_Pointer *object,
+  uintptr_t value
+  _CPU_atomic_Init_ptr(object, value);
  * @brief Atomically load an atomic type value from atomic object.
diff --git a/cpukit/score/include/rtems/score/cpustdatomic.h b/cpukit/score/include/rtems/score/cpustdatomic.h
index 243a834..7de7ebb 100644
--- a/cpukit/score/include/rtems/score/cpustdatomic.h
+++ b/cpukit/score/include/rtems/score/cpustdatomic.h
@@ -67,6 +67,34 @@ typedef enum {
   ATOMIC_ORDER_RELEASE = memory_order_release
 } Atomic_Order;
+#define CPU_ATOMIC_INITIALIZER(value) ATOMIC_VAR_INIT(value)
+RTEMS_INLINE_ROUTINE void _CPU_atomic_Init_uint(
+  atomic_init(object, value);
+RTEMS_INLINE_ROUTINE void _CPU_atomic_Init_ptr(
+  uintptr_t value
1.7.9.5
