[PATCH] bsp/lm4f120: new BSP to support TI LM4F120 XL LaunchPad board
Karel Gardas karel.gardas at centrum.cz
Tue Aug 20 17:11:48 UTC 2013
Hi Eugeniyi,
could you be so kind and review this version of my patch? I've needed to
leave SYSCONRCC_MOSCDIS as it is now since w/o it I'm not able to reach
80MHz on my board. Otherwise I've tried to use your advice to use only
RCC2 whenever possible.
Thanks!
Karel
On 08/20/13 06:51 PM, Karel Gardas wrote:
>   c/src/lib/libbsp/arm/lm3s69xx/configure.ac         |   11 +++-
>   c/src/lib/libbsp/arm/lm3s69xx/include/lm3s69xx.h   |   15 +++++-
>   c/src/lib/libbsp/arm/lm3s69xx/include/syscon.h     |    1 +
>   .../libbsp/arm/lm3s69xx/make/custom/lm4f120.cfg    |    5 ++
>   c/src/lib/libbsp/arm/lm3s69xx/ssi/ssi.c            |    4 +-
>   c/src/lib/libbsp/arm/lm3s69xx/startup/bspstart.c   |   61 +++++++++++++++++--
>   c/src/lib/libbsp/arm/lm3s69xx/startup/syscon.c     |    9 +++
>   7 files changed, 95 insertions(+), 11 deletions(-)
>   create mode 100644 c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm4f120.cfg
