psxconfig01 broken
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Aug 20 20:16:17 UTC 2013
Hi
This appears to be a side-effect of adding the POSIX mutex
for use to protect once variables.
*** POSIX TEST CONFIG 01 ***
used blocks = 62, largest used block = 11600, used space = 89424
free blocks = 1, largest free block = 109504, free space = 109504
../../../../../../../rtems/c/src/../../testsuites/psxtests/psxconfig01/init.c:
473 snapshot.posix_api.active_mutexes == CONFIGURE_MAXIMUM_POSIX_MUTEXES
Any thoughts on how to fix this?
