Initializing status code (sc) before using
Sebastian Huber
Fri Aug 23 08:03:45 UTC 2013
Hello Cynthia,
I would use the attached fix. I am bit confused about your comment. The
problem seems to be in the worker creation and not the swap function?
On 2013-08-23 05:55, Rempel, Cynthia wrote:
> Hi,
> If sc happens to not be set to RTEMS_SUCCESSFUL, this function will not swap the workers... probably won't happen, but submitting a patch anyway.
> Thanks,
> Cindy
> rtems-devel mailing list
> rtems-devel at rtems.org
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130823/cd8ca424/attachment.bin>
