SMP: ISR disable/enable vs. mutual exclustion
Sat Aug 24 02:10:05 UTC 2013
Sebastian Huber wrote:
> I will add the lock to the rtems_chain_control to keep it simple.
Given below I think we will need more.
> There is a big problem with the extract operation:
> void _Chain_Extract(
> Chain_Node *node
> ISR_Level level;
> _ISR_Disable( level );
> _Chain_Extract_unprotected( node );
> _ISR_Enable( level );
> Here we don't have access to the corresponding chain control and thus
> the lock object.
Ouch.
> Thus the normal extract operation is not available on SMP. An extract
> variant which needs also the chain control as a parameter must be used.
I think a node may need a back pointer to the chain control that
contains a lock. I suspect we cannot have a single score chain control
structure for both protected and unprotected operations and support the
current extract. I have not looked at all the uses of extract in the
code so I do not know if the chain control is available and even it is I
think the node should handle this.
