SMP: ISR disable/enable vs. mutual exclustion
Mon Aug 26 16:00:37 UTC 2013
On Mon, Aug 26, 2013 at 11:52 AM, Sebastian Huber
> On 2013-08-20 14:59, Sebastian Huber wrote:
>> One big issue are the RTEMS chains:
>> http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ClassicChains.html
>> To make them SMP ready we have two options.
>> 1. Instead of ISR disable/enable use ISR locks.  Advantage: not interface
>> change.  Disadvantage: space overhead for user which only use the
>> unprotected
>> routines.
>> 2. Add a new chain API, e.g. new structure rtems_chain_with_lock which
>> provides
>> a chain + ISR lock.  Advantage: you get what you need.  Disadvantage: API
>> duplication.
> The RTEMS Red-Black-Tree API suffers from the same problem.
> http://www.rtems.org/onlinedocs/doxygen/cpukit/html/rbtree_8h.html
Yes, but for different functions, primarily the iterators and the "find header".
> rtems-devel mailing list
> rtems-devel at rtems.org
