[PATCH] libmm patches after fixups
    Gedare Bloom
    gedare at gwmail.gwu.edu
    Tue Aug 27 16:39:04 UTC 2013
For 0003-libmm-libcpu-arm-shared.patch, you should not specify the
exception handler is inline, since you register a pointer for it. At
any rate can you use the ARM's default exception handler (Sebastian
pointed it out in another email). Also, you should probably get rid of
the arm_cp15_print_fsr.c file or make it part of your test code if you
want to keep it for debugging purposes. There are unused variables in
_CPU_Memory_management_Initialize(), and a lot of unused variables in
_CPU_Memory_management_Set_attributes(). Get rid of unused variables
and get rid of unnecessary initializations of variables.
In the arm-cp15.h file it looks like you have a spurious paste:
I think you only want one of those.
0004-libmm-armbsps-realview-xilinx-raspberry.patch:
* mm_config_table.h: The global variables in these 3 header files
should not be given the static attribute. It does not make a lot of
sense to me for a variable to be static in a header file.
The tests in patch 0005 still need some fixes to deal with workspace
allocation, and eventually to make them flexible and not use
hard-coded addresses.
-Gedare
On Mon, Aug 26, 2013 at 8:23 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> Hey all,
> I have fixed up some issues according to reviews on my
> latest set of patches. Fixups include:
> - Deleting translation table and created a new translation macro.
> (According to Sebastian Review) with introducing flags at high-level
> for attributes.
> - s/dummy_data_abort_excpetion_handler/default_data_abort_excpetion_handler/
> and made it call bsp_generic_fatal
> - Created new xxx_fsr_print_description C file (According to Gedare review)
> - Moved FSR Regiser Defines to arm-cp15.h (According to Gedare review)
> - Deleted hard coded values.
> - Remove blanks and white spaces.
> Regards,
> Hesham
