Allocate memory within an application and modify its access permissions
Wed Aug 28 07:00:16 UTC 2013
On 2013-08-28 02:00, Hesham Moustafa wrote:
> Hey all,
> I want to allocate memory within an application code, set
> memory access attributes on it, and check whether these
> permissions are set correctly or not.
> I tried to use _Workspace_Allocate(), malloc(), and partition and region
> managers to allocate a region of memory, but just after I set the
> allocated region to READ_ONLY attribute, an exception occurs. There is
> no problem when I set WRITE attribute. Also when I use hard-coded
> addresses ( that do not belong to any used section by RTEMS), I get it
> working correctly.
Why do you get an exception?  The heap manager places some administration data
right at the begin and end of an allocated block.  See also
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__RBHeap.html
> Is there a way to allocate memory without hard-coded addresses
> (target-independent), or the previous "exception-after-set" problem ?
> Regards,
> Hesham
> rtems-devel mailing list
> rtems-devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
