Atomic Operations and Required Architecture Support for RTEMS SMP
Thu Aug 29 08:17:25 UTC 2013
I sent a patch to the Newlib list which fixes that atomic flag problems:
https://sourceware.org/ml/newlib/2013/msg00685.html
FYI:
FreeBSD started to use C11 atomic operations in the kernel space:
http://svnweb.freebsd.org/base?view=revision&revision=251230
In the kernel space the operations with implicit sequentially-consistent memory
order are forbidden.  This is similar to our API choice.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
