[PATCH] Updated legacy code in ata & dec21140
Thu Aug 1 16:32:41 UTC 2013
On 8/1/2013 11:30 AM, Vipul Nayyar wrote:
> Ok, I understand that including irq-extension.h in libchip drivers is
> not required.
> So, you agree that using ifdefs is the way to go. I should use IRQ API
> methods & rtems_interrupt_catch() for simple vectored architectures
> like it's done in ata.c. Right ?
Without looking at the code, Yes. :)
Simple vectored architectures should use rtems_interrupt_catch().
> Regards
> Vipul Nayyar
> *From:* Sebastian Huber <sebastian.huber at embedded-brains.de>
> *To:* Vipul Nayyar <nayyar_vipul at yahoo.com>
> *Cc:* Joel Sherrill <joel.sherrill at oarcorp.com>;
> "rtems-devel at rtems.org" <rtems-devel at rtems.org>
> *Sent:* Thursday, 1 August 2013 9:24 PM
> *Subject:* Re: [PATCH] Updated legacy code in ata & dec21140
> On 2013-08-01 17:41, Vipul Nayyar wrote:
> > I added "#include <rtems/irq-extension.h>" in ata.c  so that the generic
> > methods could work. Shouldn't including the extensions header solve
> the problem ?
> The BSPs providing the IRQ extensions API include this file via
> <bsp/irq.h>
> indirectly and they should define BSP_FEATURE_IRQ_EXTENSION in <bsp.h>.
> Phone  : +49 89 189 47 41-16
> Fax    : +49 89 189 47 41-09
> <mailto:sebastian.huber at embedded-brains.de>
> PGP    : Public key available on request.
Joel Sherrill, Ph.D.              Director of Research & Development
joel.sherrill at OARcorp.com         On-Line Applications Research
Ask me about RTEMS: a free RTOS   Huntsville AL 35805
Support Available                 (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130801/416c236e/attachment-0001.html>
