Patch to fix some simple compilation warnings
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Aug 2 18:52:57 UTC 2013
Hi
Thanks for the patch. I have a few questions.
* Should R. be the first name in the commit? Or can we use
your full first name?
* Normally we would want some description of the changes
but since this is a warning cleanup, that's not a big deal.
* dirutils.c: I don't use cexp but know it is a shell in which you
can invoke C methods. The methods you made static appear
to all have one of more char * arguments which makes me
suspect they may be helpers to be invoked from cexp.
Do you use cexp? Can they still be invoked if static?
The names are pretty common so I am prone to approve the
patch if we don't hear from any cexp users. But if someone
complains IMO we should remove the static and prepend cexp_
to the name to avoid putting such common names into the
global symbol space.
* rtems-rfs-format.c: Chris Johns should comment.
* main_lsof.c: Also from Chris so he should comment.
* cleanuppush.c: Looks ok to me.
--joel
On 8/2/2013 9:02 AM, R. Diez wrote:
> Hi all:
> I think I'll test the waters around here with a small patch to fix some compilation warnings, please see the attached patch file. I does not need to be applied exactly as suggested, anything to make those warnings go away will do!
> Thanks,
> rdiez
