[PATCH 1/3] bsp/csb336: Fix MMU _ttbl_base location to not overlap with exception vectors.
Pavel Pisa
ppisa4lists at pikron.com
Thu Aug 8 23:28:29 UTC 2013
On Friday 09 of August 2013 01:19:19 Pavel Pisa wrote:
> diff --git a/c/src/lib/libbsp/arm/csb336/startup/linkcmds
> b/c/src/lib/libbsp/arm/csb336/startup/linkcmds
> index 0e13a9c..040619a 100644
> --- a/c/src/lib/libbsp/arm/csb336/startup/linkcmds
> +++ b/c/src/lib/libbsp/arm/csb336/startup/linkcmds
> @@ -1,9 +1,10 @@
Resent as
[PATCH 1/3 correct line wrap] bsp/csb336: Fix MMU _ttbl_base location to not overlap with exception vectors.
with correct wrapping (line wrapping off).
