[PATCH 2/3] bsp/csb336: Memory map update and jump to start at image start provided.
Fri Aug 9 07:01:19 UTC 2013
Hello Pavel,
thanks for your patches.
On 2013-08-09 01:22, Pavel Pisa wrote:
>   - The first two megabytes of SDRAM unused by RTEMS are mapped
>     with attributes to allow specific purposes.
>     - the first MB (at address 0x08000000) is nocached to allow
>       directly set some values read by booot-block after warm reset
>     - the second MB (at address 0x08100000) is set for write-through
>       caching.  That allows to use memory for LCD frame-buffer without
>       need to flush cache after each redraw.
This seems quite application specific.  Maybe add a BSP option to configure.ac?
> Jump to start provided at address 0x08200000 allows
> to load application image even as plain binary file
> and start it by jump to image start address.
> Signed-off-by: Pavel Pisa<ppisa at pikron.com>
The RTEMS project has currently nothing to sign.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
