[PATCH 05/12] score: _Priority_bit_map_Handler_initialization()
Sebastian Huber
Tue Aug 13 13:42:50 UTC 2013
Delete _Priority_bit_map_Handler_initialization() and rely on BSS
initialization. Move definition of _Priority_Major_bit_map and
_Priority_Bit_map to separate file. Move definition of __log2table also
to this file.
cpukit/sapi/src/exinit.c | 2 -
cpukit/score/Makefile.am | 1 +
.../score/include/rtems/score/prioritybitmapimpl.h | 35 +--------------
cpukit/score/src/prioritybitmap.c | 48 ++++++++++++++++++++
cpukit/score/src/schedulerpriority.c | 6 ---
5 files changed, 50 insertions(+), 42 deletions(-)
create mode 100644 cpukit/score/src/prioritybitmap.c
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index bfcfa7c..10c1559 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -45,7 +45,6 @@
#include <rtems/score/interr.h>
#include <rtems/score/isr.h>
#include <rtems/score/priority.h>
-#include <rtems/score/prioritybitmapimpl.h>
@@ -128,7 +127,6 @@ void rtems_initialize_data_structures(void)
_API_Mutex_Initialization( 1 );
_API_Mutex_Allocate( &_RTEMS_Allocator_Mutex );
- _Priority_bit_map_Handler_initialization();
_Watchdog_Handler_initialization();
_TOD_Handler_initialization();
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index a725ffc..c6954f6 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -178,6 +178,7 @@ libscore_a_SOURCES += src/objectallocate.c src/objectclose.c \
src/objectactivecount.c
## SCHEDULER_C_FILES
+libscore_a_SOURCES += src/prioritybitmap.c
libscore_a_SOURCES += src/scheduler.c
libscore_a_SOURCES += src/schedulerdefaultallocatefree.c
libscore_a_SOURCES += src/schedulerdefaultreleasejob.c
diff --git a/cpukit/score/include/rtems/score/prioritybitmapimpl.h b/cpukit/score/include/rtems/score/prioritybitmapimpl.h
index e2db034..27be57e 100644
--- a/cpukit/score/include/rtems/score/prioritybitmapimpl.h
+++ b/cpukit/score/include/rtems/score/prioritybitmapimpl.h
@@ -20,6 +20,7 @@
#define _RTEMS_SCORE_PRIORITYBITMAPIMPL_H
#include <rtems/score/prioritybitmap.h>
+#include <rtems/score/priority.h>
#ifdef __cplusplus
extern "C" {
@@ -57,28 +58,7 @@ extern Priority_bit_map_Control
* a highly optimized bit scan without the use of special CPU
* instructions.
-#ifndef SCORE_INIT
extern const unsigned char __log2table[256];
-#else
-const unsigned char __log2table[256] = {
- 7, 7, 6, 6, 5, 5, 5, 5, 4, 4, 4, 4, 4, 4, 4, 4,
- 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3,
- 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
- 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
- 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
-#endif
#endif
@@ -218,19 +198,6 @@ RTEMS_INLINE_ROUTINE uint32_t _Priority_Bits_index (
extern Priority_bit_map_Control _Priority_Bit_map[16] CPU_STRUCTURE_ALIGNMENT;
- * This routine performs the initialization necessary for this handler.
-RTEMS_INLINE_ROUTINE void _Priority_bit_map_Handler_initialization( void )
- int index;
- _Priority_Major_bit_map = 0;
- for ( index=0 ; index <16 ; index++ )
- _Priority_Bit_map[ index ] = 0;
* This routine uses the_priority_map to update the priority
* bit maps to indicate that a thread has been readied.
diff --git a/cpukit/score/src/prioritybitmap.c b/cpukit/score/src/prioritybitmap.c
new file mode 100644
index 0000000..f0e79d8
--- /dev/null
+++ b/cpukit/score/src/prioritybitmap.c
@@ -0,0 +1,48 @@
+ * @file
+ * @brief Priority Bit Map Implementation
+ * @ingroup ScorePriorityBitmap
+ * Copyright (C) 2010 Gedare Bloom.
+ * Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/prioritybitmapimpl.h>
+Priority_bit_map_Control _Priority_Bit_map[16] CPU_STRUCTURE_ALIGNMENT;
+/* Instantiate any global variables needed by the priority scheduler */
+volatile Priority_bit_map_Control _Priority_Major_bit_map;
+#if ( CPU_USE_GENERIC_BITFIELD_DATA == TRUE )
+const unsigned char __log2table[256] = {
+ 7, 7, 6, 6, 5, 5, 5, 5, 4, 4, 4, 4, 4, 4, 4, 4,
+ 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3,
+ 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
+ 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
+ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
+#endif
diff --git a/cpukit/score/src/schedulerpriority.c b/cpukit/score/src/schedulerpriority.c
index ab17063..e36a44b 100644
--- a/cpukit/score/src/schedulerpriority.c
+++ b/cpukit/score/src/schedulerpriority.c
@@ -21,11 +21,6 @@
#include <rtems/score/schedulerpriorityimpl.h>
-/* Instantiate any global variables needed by the priority scheduler */
-volatile Priority_bit_map_Control _Priority_Major_bit_map;
-Priority_bit_map_Control _Priority_Bit_map[16] CPU_STRUCTURE_ALIGNMENT;
void _Scheduler_priority_Initialize(void)
/* allocate ready queue structures */
@@ -34,7 +29,6 @@ void _Scheduler_priority_Initialize(void)
_Scheduler_priority_Ready_queue_initialize( ready_queues );
_Scheduler.information = ready_queues;
1.7.7
