[rtems commit] posix: Change pthread_once to be SMP safe.
Sebastian Huber
Wed Aug 14 08:50:24 UTC 2013
On 2013-08-14 10:37, Chris Johns wrote:
> Sebastian Huber wrote:
>> On 2013-08-14 10:00, Chris Johns wrote:
>>>>> + r = pthread_mutex_init( &_POSIX_Once_Lock, &mattr );
>>>>> + if ( r != 0 )
>>>>> + rtems_fatal( RTEMS_FATAL_SOURCE_ASSERT, 0x80aa2000 | r );
>>>> This is a configuration error. We need a proper error code for this with
>>>> source INTERNAL_ERROR_POSIX_API.
>>> Agree. I will change it to INTERNAL_ERROR_POSIX_API. I am not sure
>>> what you
>>> mean by proper error code.
>> I just realized that we need new enums for the RTEMS and POSIX API
>> errors. The fatal error handling in the RTEMS and POSIX API is currently
>> a hack due to the missing unique (source, code) pair identifying the
>> exact error location.
>> So we need enums similar to Internal_errors_Core_list for the RTEMS and
>> POSIX API associated with the error sources INTERNAL_ERROR_RTEMS_API and
> In the case of the POSIX API it may pay to define values with the bottom 8 bits
> an errno error code. This would match the current 2 uses in the internal error
> in the POSIX. For example for the pthread_once mutex init it would be ...
> _Internal_error_Occurred( INTERNAL_ERROR_POSIX_API, true,
> _POSIX_Error( POSIX_PTHREAD_ONCE_ERROR, eno ));
> Note, POSIX_PTHREAD_ONCE_ERROR can be whatever.
> Chris
This looks good, but I would use
void _POSIX_Fatal_error( POSIX_Fatal_domain domain, int eno )
uint32_t code = ( domain << 8 ) | ( ( uint32_t ) eno & 0xffU );
_Internal_error_Occurred( INTERNAL_ERROR_POSIX_API, false, code );
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
