Current head compilation problem
    Joel Sherrill
    Joel.Sherrill at OARcorp.com
    Sat Aug 17 12:58:54 UTC 2013
For now Sree could use a pc386 variant that has a higher CPU model like pc486.
Deng Hengyi <wei.a.yang at gmail.com> wrote:
Hi all,
There is a patch i submitted but it is not merged now[1], this patch will solve this error,  but as you know the i386 do not have atomic instruction
So atomic related code should not compiled at all, now the check-atomic.m4 will pass check that indicates the i386 support atomic. I will provide a
new patch to add compare_and_swap check to avoid this issue.
1. http://www.rtems.org/pipermail/rtems-devel/2013-August/004081.html
WeiY
Best Regards
在 2013-8-17,下午8:37,Gedare Bloom <gedare at rtems.org> 写道:
> Send a separate email with this bug info, or file a bug report. This
> is unrelated and was probably introduced by the code changes
> contributed by Hengyi.
> -Gedare
> On Sat, Aug 17, 2013 at 2:38 AM, Sree Harsha Konduri
> <sreehars at buffalo.edu> wrote:
>> Hello,
>> After applying the patch that Joel has sent out, there is a new bug that is
>> occuring in smpatomic tests.
>> The bug is shown below,
>> gmake[6]: Entering directory
>> `/home/harsha/rtems/4.11/pc386/i386-rtems4.11/c/pc386/testsuites/smptests/smpatomic02'
>> i386-rtems4.11-gcc -B../../../../../pc386/lib/ -specs bsp_specs -qrtems
>> -DHAVE_CONFIG_H -I.
>> -I../../../../../../../rtems/c/src/../../testsuites/smptests/smpatomic02
>> -I..
>> -I../../../../../../../rtems/c/src/../../testsuites/smptests/../support/include
>> -mtune=i386 -O2 -g -Wall -Wmissing-prototypes
>> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
>> tasks.o -MD -MP -MF .deps/tasks.Tpo -c -o tasks.o
>> ../../../../../../../rtems/c/src/../../testsuites/smptests/smpatomic02/tasks.c
>> In file included from
>> ../../../../../pc386/lib/include/rtems/score/cpuatomic.h:29:0,
>>                 from
>> ../../../../../pc386/lib/include/rtems/score/atomic.h:21,
>>                 from
>> ../../../../../pc386/lib/include/rtems/rtems/atomic.h:26,
>>                 from
>> ../../../../../../../rtems/c/src/../../testsuites/smptests/smpatomic02/tasks.c:19:
>> ../../../../../pc386/lib/include/rtems/score/cpustdatomic.h: In function
>> 'Test_task':
>> ../../../../../pc386/lib/include/rtems/score/cpustdatomic.h:83:3: error:
>> invalid memory model for '__atomic_load'
>>   return atomic_load_explicit( object, order );
>> ../../../../../pc386/lib/include/rtems/score/cpustdatomic.h:91:3: error:
>> gmake[6]: *** [tasks.o] Error 1
>> gmake[6]: Leaving directory
>> gmake[5]: *** [all-recursive] Error 1
>> Thanks,
>> Sree
>> On Fri, Aug 16, 2013 at 4:57 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
>> wrote:
>>> I think the change from #ifdef to #if changed this.
>>> pc386 set CLOCK_DRIVER_ISRS_PER_TICK to a
>>> string rather than a numeric value. I added
>>> CLOCK_DRIVER_ISRS_PER_TICK_VALUE and
>>> did some other clean up on the driver.
>>> With the attached patch, it compiles again and
>>> ticker runs.
>>> Please review and let me know if OK to commit.
>>> On 8/16/2013 11:03 AM, Gedare Bloom wrote:
>>>> OK. If you find the bug in the modified clockdrv_shell.h think about
>>>> how it might be fixed.
>>>> On Fri, Aug 16, 2013 at 11:49 AM, Vipul Nayyar <nayyar_vipul at yahoo.com>
>>>> wrote:
>>>>> Hello,
>>>>> Will look more closely into the matter.
>>>>> FWIW, I compiled the pc386 bsp giving the same configure statement as
>>>>> Sree
>>>>> gave, in my personal fork of rtems from github which is about 18 or so
>>>>> commits behind the master( that means my fork does not contain Sebastian
>>>>> Chris' #define -> #if patches).
>>>>> And it compiled successfully, without giving any errors.
>>>>> What I feel, is that the following two patches that modified
>>>>> clockdrv_shell.h need to be checked again..
>>>>> http://git.rtems.org/rtems/commit/?id=b7f206097313f794dbe53202542b5894aad6a117
>>>>> http://git.rtems.org/rtems/commit/?id=d473dc0b22d3276130f893a51350c8bfb8beaac8
>>>>> My patches for pc386 were checked carefully by Sebastian, but will have
>>>>> to
>>>>> look more closely to find any bug caused due to my patches.
>>>>> Regards
>>>>> Vipul Nayyar
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
