[VirtLayer] Changes to the interrupt handling in POK
Philipp Eppelt philipp.eppelt at mailbox.tu-dresden.de
Sun Aug 18 14:03:03 UTC 2013
Hi,
currently I have no RTEMS partition running on POK, as these changes
must first be validated with pure POK partitions. Also I haven't written
the code to get a interrupt handler through the partition abstraction.
CLOCK_HANDLER is a macro which is incrementing the tick counter and
invoking the scheduler in the POK kernel.
To register IRQ handlers from a partition, e.g. an RTEMS partition, I
need to create a new syscall first, to get the callback function into
the meta_handler list.
So when RTEMS tries to attach to an interrupt, the virtualization layer
implementation of POK is invoked and registers a predefined handler via
a syscall with the meta_handler for this irq number. When the interrupt
occurs the registered handler is invoked with the vector number as an
argument. Then the handler invokes C_dispatch_isr() in RTEMS passing the
vector number along.
That's the plan, for the next week.
Cheers,
Philipp
On 08/18/2013 02:45 PM, Cláudio Silva wrote:
> Good job Philipp. It seems a nice first iteration for interrupt
> virtualization. Did you get to try it?
> If I got it right, the POK part of the interrupt handler (CLOCK_HANDLER
> ??) is running after the virtualized RTEMS handler?
> Regards,
> Cláudio
> On Sun, Aug 18, 2013 at 12:18 AM, Philipp Eppelt
> <philipp.eppelt at mailbox.tu-dresden.de
> <mailto:philipp.eppelt at mailbox.tu-dresden.de>> wrote:
>     Hi,
>     lately I worked a lot to extend POK with necessary features to
>     accommodate an RTEMS partition.
>     Since hello world works, I need a way to pass clock ticks to the RTEMS
>     partition running on POK. Therefore the interrupt handling needs to
>     support custom handlers.
>     If everything works out, I can enable the virtualization layer to
>     register an interrupt vector and if it occurs RTEMS is notified by
>     invoking C_dispatch_isr().
>     Blog:
>     http://phipse.github.io/rtems/blog/2013/08/17/pok-hardware-interrupt-handling/
>     Source:
>     https://github.com/phipse/pok
>     Cheers,
>     Philipp
>     _______________________________________________
>     rtems-devel mailing list
>     rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
>     http://www.rtems.org/mailman/listinfo/rtems-devel
