bsp/csb336: Patches and RTEMS 4.10
Sebastian Huber
Mon Aug 19 09:00:18 UTC 2013
Hello Pavel,
thanks for testing this.
On 2013-08-15 10:15, Pavel Pisa wrote:
> I have done build of RTEMS 4.10 for CSB336 and tested it on hardware
> and the data abort in bsp_interrupt_dispatch() is there as well.
> Following master branch fix patch is mandatory for CSB336 to run
> on RTEMS 4.10 and applies cleanly to 4.10 branch
> bsp/csb336: mc9328mxl correct AITC access in bsp_interrupt_dispatch.
> RTEMS 4.9 version has IRQ dispatch implemented in assembler function
> bsp_irq_asm.S:ExecuteITHandler()
> and it is correct and works for us well for years.
> Please, commit patch to 4.10 branch as well.
Done.
> I have ported and
> applied other three patches on 4.10 branch but they are not mandatory.
> I would be happy to post modified 4.10 version of these if you think
> that non-fix changes are usesfull for 4.10. They could hardly break
> others CSB336 RTEMS 4.10 setup, because it was misscompiled with RTEMS
> default GCC optimization flags without the fix.
We can add them to 4.10 if you think this is useful. Can I simply git
cherry-pick them?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
