psxconfig01 broken
Joel Sherrill
Joel.Sherrill at OARcorp.com
Wed Aug 21 11:39:02 UTC 2013
I know. Any thoughts on how to account for the extra mutex?
Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
On 2013-08-20 22:16, Joel Sherrill wrote:
> Hi
> This appears to be a side-effect of adding the POSIX mutex
> for use to protect once variables.
> *** POSIX TEST CONFIG 01 ***
> used blocks = 62, largest used block = 11600, used space = 89424
> free blocks = 1, largest free block = 109504, free space = 109504
> ../../../../../../../rtems/c/src/../../testsuites/psxtests/psxconfig01/init.c:
> 473 snapshot.posix_api.active_mutexes == CONFIGURE_MAXIMUM_POSIX_MUTEXES
> Any thoughts on how to fix this?
This was also introduced with the pthread_once() changes.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
rtems-devel mailing list
rtems-devel at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-devel
