SMP: ISR disable/enable vs. mutual exclustion
Fri Aug 23 14:26:00 UTC 2013
I will add the lock to the rtems_chain_control to keep it simple.
There is a big problem with the extract operation:
void _Chain_Extract(
   Chain_Node *node
   ISR_Level level;
   _ISR_Disable( level );
     _Chain_Extract_unprotected( node );
   _ISR_Enable( level );
Here we don't have access to the corresponding chain control and thus the lock
object.
Thus the normal extract operation is not available on SMP.  An extract variant
which needs also the chain control as a parameter must be used.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
