[PATCH 1/2] score: PR2140: _Thread_queue_Extract()
Gedare Bloom
gedare at rtems.org
Fri Aug 23 14:38:24 UTC 2013
On Fri, Aug 23, 2013 at 6:58 AM, Sebastian Huber
> Return if the caller performed the extract operation. The caller may
> perform certain actions if it was the one who actually performed the
> extract operation.
> cpukit/score/include/rtems/score/threadqimpl.h | 12 +++++++++---
> cpukit/score/src/threadqextract.c | 6 +++---
> cpukit/score/src/threadqextractfifo.c | 5 +++--
> cpukit/score/src/threadqextractpriority.c | 8 +++++---
> 4 files changed, 20 insertions(+), 11 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
> index c72982d..0762f0d 100644
> --- a/cpukit/score/include/rtems/score/threadqimpl.h
> +++ b/cpukit/score/include/rtems/score/threadqimpl.h
> @@ -135,8 +135,11 @@ void _Thread_queue_Requeue(
> * @param[in] the_thread_queue is the pointer to the ThreadQ header
> * @param[in] the_thread is the pointer to a thread control block that is to be removed
> + * @retval true The extract operation was performed by the caller.
> + * @retval false Otherwise.
I'm confused by the use of "caller" here. Does it refer to the
_Thread_queue_Extract function?
> extract operation.
> -void _Thread_queue_Extract(
> +bool _Thread_queue_Extract(
> Thread_queue_Control *the_thread_queue,
> Thread_Control *the_thread
> @@ -258,8 +261,11 @@ Thread_blocking_operation_States _Thread_queue_Enqueue_priority (
> * timeout or state
> * - INTERRUPT LATENCY:
> * + EXTRACT_PRIORITY
> -void _Thread_queue_Extract_priority_helper(
> +bool _Thread_queue_Extract_priority_helper(
> Thread_Control *the_thread,
> bool requeuing
> @@ -332,7 +338,7 @@ Thread_blocking_operation_States _Thread_queue_Enqueue_fifo (
> * This routine removes the_thread from the_thread_queue
> * and cancels any timeouts associated with this blocking.
> -void _Thread_queue_Extract_fifo(
> +bool _Thread_queue_Extract_fifo(
> diff --git a/cpukit/score/src/threadqextract.c b/cpukit/score/src/threadqextract.c
> index 8e0e3e8..b2da4f0 100644
> --- a/cpukit/score/src/threadqextract.c
> +++ b/cpukit/score/src/threadqextract.c
> @@ -21,7 +21,7 @@
> #include <rtems/score/threadqimpl.h>
> @@ -31,8 +31,8 @@ void _Thread_queue_Extract(
> * is a macro and the underlying methods do not have the same signature.
> if ( the_thread_queue->discipline == THREAD_QUEUE_DISCIPLINE_PRIORITY )
> - _Thread_queue_Extract_priority( the_thread_queue, the_thread );
> + return _Thread_queue_Extract_priority( the_thread_queue, the_thread );
> else /* must be THREAD_QUEUE_DISCIPLINE_FIFO */
> - _Thread_queue_Extract_fifo( the_thread_queue, the_thread );
> + return _Thread_queue_Extract_fifo( the_thread_queue, the_thread );
> diff --git a/cpukit/score/src/threadqextractfifo.c b/cpukit/score/src/threadqextractfifo.c
> index 5038738..21c9827 100644
> --- a/cpukit/score/src/threadqextractfifo.c
> +++ b/cpukit/score/src/threadqextractfifo.c
> @@ -25,7 +25,7 @@
> #include <rtems/score/threadimpl.h>
> #include <rtems/score/watchdogimpl.h>
> Thread_queue_Control *the_thread_queue __attribute__((unused)),
> @@ -36,7 +36,7 @@ void _Thread_queue_Extract_fifo(
> if ( !_States_Is_waiting_on_thread_queue( the_thread->current_state ) ) {
> _ISR_Enable( level );
> - return;
> + return false;
> _Chain_Extract_unprotected( &the_thread->Object.Node );
> @@ -58,4 +58,5 @@ void _Thread_queue_Extract_fifo(
> _Thread_MP_Free_proxy( the_thread );
> #endif
> + return true;
> diff --git a/cpukit/score/src/threadqextractpriority.c b/cpukit/score/src/threadqextractpriority.c
> index 2b79398..d22fdf2 100644
> --- a/cpukit/score/src/threadqextractpriority.c
> +++ b/cpukit/score/src/threadqextractpriority.c
> @@ -24,7 +24,7 @@
> bool requeuing
> @@ -45,7 +45,7 @@ void _Thread_queue_Extract_priority_helper(
> _ISR_Disable( level );
> - return;
> + return false;
> @@ -87,7 +87,7 @@ void _Thread_queue_Extract_priority_helper(
> if ( requeuing ) {
> - return;
> + return true;
> if ( !_Watchdog_Is_active( &the_thread->Timer ) ) {
> @@ -103,4 +103,6 @@ void _Thread_queue_Extract_priority_helper(
> if ( !_Objects_Is_local_id( the_thread->Object.id ) )
> #endif
> + return true;
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
