SMP: ISR disable/enable vs. mutual exclustion
Sebastian Huber
Mon Aug 26 15:52:24 UTC 2013
On 2013-08-20 14:59, Sebastian Huber wrote:
> One big issue are the RTEMS chains:
> http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ClassicChains.html
> To make them SMP ready we have two options.
> 1. Instead of ISR disable/enable use ISR locks. Advantage: not interface
> change. Disadvantage: space overhead for user which only use the unprotected
> routines.
> 2. Add a new chain API, e.g. new structure rtems_chain_with_lock which provides
> a chain + ISR lock. Advantage: you get what you need. Disadvantage: API
> duplication.
The RTEMS Red-Black-Tree API suffers from the same problem.
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/rbtree_8h.html
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
