[PATCH 1/5] libmm score API
Hesham Moustafa
heshamelmatary at gmail.com
Mon Aug 26 18:15:29 UTC 2013
On Mon, Aug 26, 2013 at 5:22 PM, Sebastian Huber <
> On 2013-08-26 02:14, Hesham AL-Matary wrote:
>> + * @brief _Memory_management_Region Flags defs
>> +#define RTEMS_MM_REGION_NO_PROTECTION 0x0
>> +#define RTEMS_MM_REGION_PROTECTION_**READ_ONLY 0x1
>> +#define RTEMS_MM_REGION_PROTECTION_**WRITE 0x2
>> +#define RTEMS_MM_REGION_NO_ACCESS 0x3
>> +//#define RTEMS_MM_REGION_PROTECTION_**EXEC 0x4
> I prefer to actually have flags here and not a single integer value.
> So I would use this:
> #define RTEMS_MM_REGION_BIT_READ 0
> #define RTEMS_MM_REGION_BIT_WRITE 1
> #define RTEMS_MM_REGION_BIT_EXECUTE 2
> #define RTEMS_MM_REGION_BIT_CACHE 3
> #define RTEMS_MM_REGION_BIT_DEVICE 4
> #define RTEMS_MM_REGION_BIT_SHARED 5
> Some of these flags are not supported on some architectures like
RTEMS_MM_REGION_BIT_SHARED, or targets that do not have
Cache Unit. How should we handle some of these flags for such
targets that do not support these features in hardware ?
> #define RTEMS_MM_REGION_READ (1U << RTEMS_MM_REGION_BIT_WRITE)
> etc.
> This can be used to get architecture specific values easily:
> ((flags >> RTEMS_MM_REGION_BIT_READ) & 0x1U) << ARCH_READ_SHIFT
> That make sense.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-devel mailing list
> rtems-devel at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130826/1f939b79/attachment-0001.html>
