[PATCH 1/2] add atomc_sub and atomic_compare_exchange into smpatomic08
Sebastian Huber
Sat Aug 31 07:22:10 UTC 2013
On 2013-08-31 03:49, WeiY wrote:
> + while (!stop(ctx)) {
> + while (_Atomic_Compare_exchange_uint(&ctx->global_swap, &ctx->global_swap_t,
> + worker_index, ATOMIC_ORDER_ACQUIRE, ATOMIC_ORDER_RELEASE)) {
> + /* Wait */
> + ++counter;
> + ++ctx->flag_counter;
> + ctx->global_swap_t = worker_index;
This doesn't work since ctx->global_swap_t is a normal variable. Also
the failure memory order is wrong. You try to implement a mutex here.
In case the compare exchange failed, then we try it again thus we don't
care about a particular memory order here (ATOMIC_ORDER_RELAXED). The
success order is all right, since this is the mutex acquire path.
The init and fini handler for the test case don't fit to the body.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
