SPARC linker command files
Tue Dec 3 07:46:13 UTC 2013
On 2013-12-02 23:06, Jiri Gaisler wrote:
> On 11/30/2013 02:31 AM, Gedare Bloom wrote:
>> >Does the NGMP allow for variant sizes of ROM and RAM? If so will we
>> >provide separate BSP variants for all possibilities, or how does the
>> >user select the right size for their board?
> The boot loader (or gdb debug monitor) supplies the top-of-stack
> address in %sp when the RTEMS binary is called. The area between
> the start address and %sp indicates the size of RAM to be used.
> In this way only one bsp is needed.
Ok, good to know.  Then this symbols should probably go away.  Is the boot
loader always the same?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
