[PATCH 1/2] cpu part of the virtualization layer for i386
    Gedare Bloom
    gedare at rtems.org
    Tue Dec  3 16:41:46 UTC 2013
On Wed, Nov 27, 2013 at 5:55 PM, Philipp Eppelt
<philipp.eppelt at mailbox.tu-dresden.de> wrote:
>  cpukit/score/cpu/i386/Makefile.am                  |  1 +
>  cpukit/score/cpu/i386/cpu.c                        | 20 +++++
>  cpukit/score/cpu/i386/preinstall.am                |  4 +
>  cpukit/score/cpu/i386/rtems/score/cpu.h            | 50 ++++++++++---
>  cpukit/score/cpu/i386/rtems/score/interrupts.h     | 31 ++++++++
>  .../cpu/i386/rtems/score/virtualizationlayercpu.h  | 85 ++++++++++++++++++++++
>  6 files changed, 179 insertions(+), 12 deletions(-)
>  create mode 100644 cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h
> diff --git a/cpukit/score/cpu/i386/Makefile.am b/cpukit/score/cpu/i386/Makefile.am
> index e35a81c..8f196c5 100644
> --- a/cpukit/score/cpu/i386/Makefile.am
> +++ b/cpukit/score/cpu/i386/Makefile.am
> @@ -12,6 +12,7 @@ include_rtems_score_HEADERS += rtems/score/registers.h
>  include_rtems_score_HEADERS += rtems/score/idtr.h
>  include_rtems_score_HEADERS += rtems/score/cpuatomic.h
>  include_rtems_score_HEADERS += rtems/score/cpusmplock.h
> +include_rtems_score_HEADERS += rtems/score/virtualizationlayercpu.h
>  noinst_LIBRARIES = libscorecpu.a
>  libscorecpu_a_SOURCES = cpu.c cpu_asm.S
> diff --git a/cpukit/score/cpu/i386/cpu.c b/cpukit/score/cpu/i386/cpu.c
> index c87a76d..4dd44bb 100644
> --- a/cpukit/score/cpu/i386/cpu.c
> +++ b/cpukit/score/cpu/i386/cpu.c
> @@ -26,6 +26,10 @@
>  #include <rtems/bspIo.h>
>  #include <rtems/score/thread.h>
> +#if defined(RTEMS_PARAVIRT)
> +#include <rtems/score/virtualizationlayercpu.h>
> +#endif
>  void _CPU_Initialize(void)
>  #if CPU_HARDWARE_FP
> @@ -97,6 +101,20 @@ uint32_t   _CPU_ISR_Get_level( void )
>    return level;
> +void *_CPU_Thread_Idle_body( uintptr_t ignored )
> +  while(1)
> +    _CPU_Virtual_idle_thread();
> +  return NULL;
> +#else
>    while(1){
> @@ -105,6 +123,8 @@ void *_CPU_Thread_Idle_body( uintptr_t ignored )
>    return NULL;
> +#endif /*RTEMS_PARAVIRT*/
>  struct Frame_ {
>         struct Frame_  *up;
>         uintptr_t               pc;
> diff --git a/cpukit/score/cpu/i386/preinstall.am b/cpukit/score/cpu/i386/preinstall.am
> index f9faf87..363e1fb 100644
> --- a/cpukit/score/cpu/i386/preinstall.am
> +++ b/cpukit/score/cpu/i386/preinstall.am
> @@ -59,3 +59,7 @@ $(PROJECT_INCLUDE)/rtems/score/cpusmplock.h: rtems/score/cpusmplock.h $(PROJECT_
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpusmplock.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpusmplock.h
> +$(PROJECT_INCLUDE)/rtems/score/virtualizationlayercpu.h: rtems/score/virtualizationlayercpu.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/virtualizationlayercpu.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/virtualizationlayercpu.h
> diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
> index 43422ed..4e509b7 100644
> --- a/cpukit/score/cpu/i386/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
> @@ -35,6 +35,10 @@ extern "C" {
>  #include <rtems/score/registers.h>     /* formerly part of libcpu */
>  #endif
> +#endif
>  /* conditional compilation parameters */
>  #define CPU_INLINE_ENABLE_DISPATCH       TRUE
> @@ -376,11 +380,22 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
>  #define _CPU_ISR_Flash( _level )   i386_flash_interrupts( _level )
> -#define _CPU_ISR_Set_level( _new_level ) \
> -    if ( _new_level ) __asm__ volatile ( "cli" ); \
> -    else              __asm__ volatile ( "sti" ); \
> +  #define _CPU_ISR_Set_level( _new_level ) \
> +      if( _new_level )  _CPU_Virtual_Interrupts_close(); \
> +      else             _CPU_Virtual_Interrupts_open(); \
> +#else
> +      if ( _new_level ) __asm__ volatile ( "cli" ); \
> +      else              __asm__ volatile ( "sti" ); \
>  uint32_t   _CPU_ISR_Get_level( void );
> @@ -497,16 +512,27 @@ uint32_t   _CPU_ISR_Get_level( void );
>   *    + disable interrupts and halt the CPU
> -#define _CPU_Fatal_halt( _error ) \
> +  #define _CPU_Fatal_halt( _error ) \
> -    uint32_t _error_lvalue = ( _error ); \
> -    __asm__ volatile ( "cli ; \
> -                    movl %0,%%eax ; \
> -                    hlt" \
> -                    : "=r" ((_error_lvalue)) : "0" ((_error_lvalue)) \
> +    _CPU_Virtual_Interrupts_close(); \
> +    _CPU_Virtual_exec_stop_error( _error ); \
Why doesn't "_CPU_Virtual_exec_stop_error() follow the naming/style convention?
> +#else
> +      uint32_t _error_lvalue = ( _error ); \
> +      __asm__ volatile ( "cli ; \
> +                      movl %0,%%eax ; \
> +                      hlt" \
> +                      : "=r" ((_error_lvalue)) : "0" ((_error_lvalue)) \
>  #endif /* ASM */
>  /* end of Fatal Error manager macros */
> diff --git a/cpukit/score/cpu/i386/rtems/score/interrupts.h b/cpukit/score/cpu/i386/rtems/score/interrupts.h
> index bed6330..8d47ea5 100644
> --- a/cpukit/score/cpu/i386/rtems/score/interrupts.h
> +++ b/cpukit/score/cpu/i386/rtems/score/interrupts.h
> @@ -33,6 +33,36 @@ typedef int  (*rtems_raw_irq_is_enabled)     (const struct __rtems_raw_irq_connect_d
> +  #include <rtems/score/virtualizationlayercpu.h>
> +#define i386_disable_interrupts( _level ) \
> +    _CPU_Virtual_Interrupts_disable( _level ); \
> +#define i386_enable_interrupts( _level )  \
> +    _CPU_Virtual_Interrupts_enable( _level ); \
> +#define i386_flash_interrupts( _level ) \
> +    _CPU_Virtual_Interrupts_enable(_level); \
> +    _CPU_Virtual_Interrupts_disable(_level); \
> +#define i386_get_interrupt_level( _level ) \
> +    _CPU_Virtual_Interrupts_get_level( _level ); \
> +#define _CPU_ISR_Disable( _level ) i386_disable_interrupts( _level )
> +#define _CPU_ISR_Enable( _level ) i386_enable_interrupts( _level )
> +#else /*RTEMS_PARAVIRT*/
> @@ -75,6 +105,7 @@ typedef int  (*rtems_raw_irq_is_enabled)     (const struct __rtems_raw_irq_connect_d
>  #endif
> diff --git a/cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h b/cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h
> new file mode 100644
> index 0000000..ce269fa
> --- /dev/null
> +++ b/cpukit/score/cpu/i386/rtems/score/virtualizationlayercpu.h
> @@ -0,0 +1,85 @@
> + * COPYRIGHT (c) 2013 Philipp Eppelt.
> + *    philipp.eppelt at mailbox.tu-dresden.de
> + * Purpose:   CPU part of the virtualization layer.
> + * Licencse:  see RTEMS License.
Fix typo. It might be better to include the boilerplate text here that
identifies the license, which you can copy from other files.
> +#ifndef RTEMS_VIRT_LAYER_CPU_H
> +#define RTEMS_VIRT_LAYER_CPU_H
> +#ifndef ASM
> +/* Interrupts */
> + * \brief Requests an interrupt vector.
> +int
> +_CPU_Virtual_Irq_request( int vector );
> + * \brief Releases an interrupt vector.
> +void
> +_CPU_Virtual_Irq_detach( int vector );
Should we use release instead of detach? what is "normal"?
> + * \brief Enables interrupt delivery or sets it to the specified level.
> + * Use this function in collaboration with _CPU_Virtual_Interrupts_disable and
> + * use its returned _level as argument to this function to assure proper
> + * behaviour.
> +void
> +_CPU_Virtual_Interrupts_enable( int _level );
> + * \brief Disables interrupt delivery and returns the previous level.
> +void
> +_CPU_Virtual_Interrupts_disable( int _level );
> + * \brief Enables and directly disables interrupt delivery.
> +void
> +_CPU_Virtual_Interrupts_flash( int _level );
> + * \brief Requests the current interrupt level.
> +int
> +_CPU_Virtual_Interrupts_get_level( int _level );
> +void
> +_CPU_Virtual_Interrupts_open(void);
> +void
> +_CPU_Virtual_Interrupts_close( void );
> +/* Idle Thread */
> + * \brief Lowest priority thread, doing nothing, never returns;
> +void
> +_CPU_Virtual_idle_thread( void );
s/idle/Idle ?
> +/* Error handling */
> + * \brief Handlers execution errors.
> +void
> +_CPU_Virtual_exec_stop_error( int _error );
Perhaps _CPU_Virtual_Stop_with_error()?
> +#endif /* ASM */
> +#endif /* RTEMS_VIRT_LAYER_CPU_H */
> 1.8.1.4
> rtems-devel mailing list
> rtems-devel at rtems.org
