[PATCH] i386/virtualpok BSP, virtual BSP to be used with POK, build with enable-paravirt
Philipp Eppelt philipp.eppelt at mailbox.tu-dresden.de
Thu Dec 5 15:59:13 UTC 2013
 c/src/lib/libbsp/i386/acinclude.m4                 |   2 +
 c/src/lib/libbsp/i386/virtualpok/Makefile.am       |  87 +++++++
 c/src/lib/libbsp/i386/virtualpok/README.virt       |  23 ++
 c/src/lib/libbsp/i386/virtualpok/bsp_specs         |  14 ++
 c/src/lib/libbsp/i386/virtualpok/clock/ckinit.c    | 139 ++++++++++++
 c/src/lib/libbsp/i386/virtualpok/configure.ac      |  23 ++
 c/src/lib/libbsp/i386/virtualpok/console/console.c | 184 +++++++++++++++
 c/src/lib/libbsp/i386/virtualpok/include/bsp.h     |  53 +++++
 .../virtualpok/include/virtualizationlayerbsp.h    |  62 +++++
 c/src/lib/libbsp/i386/virtualpok/irq/irq.c         |  85 +++++++
 c/src/lib/libbsp/i386/virtualpok/irq/irq.h         |  79 +++++++
 .../i386/virtualpok/make/custom/virtualpok.cfg     |  17 ++
 c/src/lib/libbsp/i386/virtualpok/preinstall.am     |  79 +++++++
 c/src/lib/libbsp/i386/virtualpok/start/start.S     |  37 +++
 .../i386/virtualpok/startup/bspgetworkarea.c       | 102 +++++++++
 .../lib/libbsp/i386/virtualpok/startup/bspstart.c  |  41 ++++
 c/src/lib/libbsp/i386/virtualpok/startup/linkcmds  | 251 +++++++++++++++++++++
 17 files changed, 1278 insertions(+)
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/Makefile.am
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/README.virt
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/bsp_specs
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/clock/ckinit.c
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/configure.ac
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/console/console.c
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/include/bsp.h
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/include/virtualizationlayerbsp.h
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/irq/irq.c
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/irq/irq.h
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/make/custom/virtualpok.cfg
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/preinstall.am
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/start/start.S
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/startup/bspgetworkarea.c
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/startup/bspstart.c
 create mode 100644 c/src/lib/libbsp/i386/virtualpok/startup/linkcmds
diff --git a/c/src/lib/libbsp/i386/acinclude.m4 b/c/src/lib/libbsp/i386/acinclude.m4
index a2f2384..2d60714 100644
--- a/c/src/lib/libbsp/i386/acinclude.m4
+++ b/c/src/lib/libbsp/i386/acinclude.m4
@@ -4,6 +4,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
   case "$1" in
   pc386 )
     AC_CONFIG_SUBDIRS([pc386]);;
+  virtualpok )
+    AC_CONFIG_SUBDIRS([virtualpok]);;
     AC_MSG_ERROR([Invalid BSP]);;
   esac
diff --git a/c/src/lib/libbsp/i386/virtualpok/Makefile.am b/c/src/lib/libbsp/i386/virtualpok/Makefile.am
new file mode 100644
index 0000000..e545962
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/Makefile.am
@@ -0,0 +1,87 @@
+ACLOCAL_AMFLAGS = -I ../../../../aclocal
+include $(top_srcdir)/../../../../automake/compile.am
+include $(top_srcdir)/../../bsp.am
+include_bspdir = $(includedir)/bsp
+dist_project_lib_DATA = bsp_specs
+include_HEADERS = include/bsp.h
+include_HEADERS += ../../shared/include/tm27.h
+include_HEADERS += include/virtualizationlayerbsp.h
+#include_HEADERS += include/virtualizationlayercpu.h
+nodist_include_HEADERS = include/bspopts.h
+nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
+DISTCLEANFILES = include/bspopts.h
+noinst_PROGRAMS =
+include_bsp_HEADERS  = irq/irq.h
+include_bsp_HEADERS += ../../shared/include/irq-generic.h
+#include_bsp_HEADERS  +=
+nodist_include_HEADERS += ../../shared/include/coverhd.h
+#noinst_LIBRARIES = libbspstart.a
+#libbspstart_a_SOURCES = start/_start.S
+dist_project_lib_DATA += startup/linkcmds
+noinst_LIBRARIES = libbsp.a
+libbsp_a_SOURCES =
+# startup
+libbsp_a_SOURCES += start/start.S
+project_lib_DATA = start.$(OBJEXT)
+libbsp_a_SOURCES += ../../shared/bspclean.c
+libbsp_a_SOURCES += ../../shared/bsplibc.c
+libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
+libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
+libbsp_a_SOURCES += startup/bspgetworkarea.c
+libbsp_a_SOURCES += ../../shared/bsppost.c
+libbsp_a_SOURCES += startup/bspstart.c
+libbsp_a_SOURCES += ../../shared/bootcard.c
+libbsp_a_SOURCES += ../../shared/sbrk.c
+libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
+libbsp_a_SOURCES += ../../shared/bspreset_loop.c
+libbsp_a_SOURCES += irq/irq.c
+libbsp_a_SOURCES += ../../shared/src/irq-generic.c
+# TODO I don't really need an IDT, don't I?
+libbsp_a_SOURCES += ../../i386/shared/irq/idt.c
+# clock
+libbsp_a_SOURCES += clock/ckinit.c
+# console
+libbsp_a_SOURCES += console/console.c
+# timer
+#libbsp_a_SOURCES += timer/timer.c timer/timerisr.c
+libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/cache.rel
+libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/page.rel
+libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/score.rel
+noinst_LIBRARIES += libpokpart.a
+libpokpart.a :
+	cp -u $(top_srcdir)/libpart.a .
+	ar t libpart.a > libpart.list
+	sed -e "s/\.lo/\.o/g" libpart.list > libpart.o.list
+	ar x libpart.a
+	rename .lo .o `cat libpart.list`
+	ar q libbsp.a `cat libpart.o.list`
+#	ar cru libpokpart.a `cat libpart.o.list`
+# rm `cat libpart.o.list` is optional as all files get overwritten with new
+# ones by 'ar x'. But I think it's bad style to remove object files during
+# compilation.
+#libpokpart_a_LIBADD = libpart.a
+EXTRA_DIST = times
+include $(srcdir)/preinstall.am
+include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/i386/virtualpok/README.virt b/c/src/lib/libbsp/i386/virtualpok/README.virt
index 0000000..47382ca
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/README.virt
@@ -0,0 +1,23 @@
+Author: Philipp Eppelt
+  philipp.eppelt at mailbox.tu-dresden.de
+This BSP is intended to be used with POK. Other hosts are currently not
+supported.
+The BSP uses functions from the virtualization layer. The host system has to
+provide a library implementing the function specified in the virtualization
+layer. Otherwise the compilation process will fail.
+Further information on the project can be obtained in the RTEMS Wiki:
+wiki.rtems.org/wiki/index.php/GSOC_2013_-_Paravirtualization_of_RTEMS
+== ATTENTION ==
+In order to build this BSP you need a library file called "libpart.a". This
+file is produced by POK after you compiled the rtems-guest example found here:
+https://github.com/phipse/pok
+Then you have to copy libpart.a to this folder. Now you should be able to
+compile.
+Further information can be found here:
+http://phipse.github.io/rtems/blog/2013/07/08/HelloWorld/
diff --git a/c/src/lib/libbsp/i386/virtualpok/bsp_specs b/c/src/lib/libbsp/i386/virtualpok/bsp_specs
index 0000000..861b21e
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/bsp_specs
@@ -0,0 +1,14 @@
+%rename lib old_lib
+*endfile:
+crtend.o%s crtn.o%s
+*startfile:
+%{!qrtems: %(old_startfile)} \
+%{!nostdlib: %{qrtems: crti.o%s crtbegin.o%s }}
+*lib:
+%{!qrtems: %(old_lib)} \
+%{!nostdlib: %{qrtems: --start-group -lrtemsbsp -lrtemscpu -lc -lgcc --end-group \
+%{!qnolinkcmds: -T linkcmds%s}}}
diff --git a/c/src/lib/libbsp/i386/virtualpok/clock/ckinit.c b/c/src/lib/libbsp/i386/virtualpok/clock/ckinit.c
index 0000000..d36eb3d
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/clock/ckinit.c
@@ -0,0 +1,139 @@
+/*  ckinit.c
+ *  This file provides a clock device driver to be used with the
+ *  virtualizationlayer.
+ *  COPYRIGHT (c) 2013.
+ *  Philipp Eppelt.
+ *  COPYRIGHT (c) 1989-1999.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#include <stdlib.h>
+#include <stdio.h>
+#include <bsp.h>
+#include <bsp/irq.h>
+#include <rtems.h>
+#include <rtems/config.h>
+#include <rtems/score/tod.h>
+#include <rtems/score/watchdog.h>
+#include <rtems/score/timestamp.h>
+#include <assert.h>
+#include <rtems/score/virtualizationlayercpu.h>
+#include <virtualizationlayerbsp.h>
+void Clock_isr(void *param);
+static void Clock_isr_handler(void *param);
+ *  The interrupt vector number associated with the clock tick device
+ *  driver.
+#define CLOCK_VECTOR    0x0
+ *  Clock_driver_ticks is a monotonically increasing counter of the
+ *  number of clock ticks since the driver was initialized.
+volatile uint32_t pc386_microseconds_per_isr;
+volatile uint32_t pc386_isrs_per_tick;
+volatile uint32_t         Clock_driver_ticks;
+void     (*Clock_driver_support_at_tick)(void) = NULL;
+#define Clock_driver_support_install_isr( _new, _old ) \
+  do { \
+    _old = NULL; \
+  } while(0)
+bool Clock_isr_enabled = false;
+  if ( Clock_isr_enabled )
+    Clock_isr( param );
+} // Clock_isr_handler
+static void Clock_driver_support_at_tick_empty(void)
+ * @brief Enable clock device; start receiving clock interrupts.
+static void clockOn(void)
+  pc386_isrs_per_tick        = 1;
+  pc386_microseconds_per_isr = rtems_configuration_get_microseconds_per_tick();
+  _CPU_Virtual_Irq_request( CLOCK_VECTOR );
+} // clockOn
+ * @brief Disable clock device; stop receiving clock interrupts.
+static void clockOff(void)
+  _CPU_Virtual_Irq_detach( CLOCK_VECTOR );
+} // clockOff
+ * @brief Install the clock ISR in the RTEMS interrupt table.
+void Clock_driver_install_handler(void);
+  rtems_status_code status;
+  status = rtems_interrupt_handler_install(
+    BSP_PERIODIC_TIMER,
+    "ckinit",
+    RTEMS_INTERRUPT_UNIQUE,
+    Clock_isr_handler,
+    NULL
+  if(status != RTEMS_SUCCESSFUL)
+    printf( "ERROR: During clock interrupt handler install: %i\n", status);
+  else
+    printf( "CLOCK DRIVER installed successfully\n");
+  clockOn();
+} // Clock_driver_install_handler
+uint32_t (*Clock_driver_nanoseconds_since_last_tick)(void) = NULL;
+ * @brief Setup the clock driver.
+void Clock_driver_support_initialize_hardware(void);
+    Clock_driver_support_at_tick = Clock_driver_support_at_tick_empty;
+    Clock_isr_enabled = true;
+} // Clock_driver_support_initialize_hardware
+#define Clock_driver_support_shutdown_hardware() \
+  do { \
+    rtems_status_code status; \
+    clockOff(); \
+    status = rtems_interrupt_handler_remove(  \
+      BSP_PERIODIC_TIMER, \
+      Clock_isr_handler,  \
+      NULL  \
+    assert(status == RTEMS_SUCCESSFUL); \
+  } while (0)
+#include "../../../shared/clockdrv_shell.h"
diff --git a/c/src/lib/libbsp/i386/virtualpok/configure.ac b/c/src/lib/libbsp/i386/virtualpok/configure.ac
index 0000000..eca01cc
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/configure.ac
@@ -0,0 +1,23 @@
+## Process this file with autoconf to produce a configure script.
+AC_PREREQ([2.68])
+AC_INIT([rtems-c-src-lib-libbsp-i386-virtualpok],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
+AC_CONFIG_SRCDIR([bsp_specs])
+RTEMS_TOP(../../../../../..)
+RTEMS_CANONICAL_TARGET_CPU
+AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
+RTEMS_BSP_CONFIGURE
+RTEMS_PROG_CC_FOR_TARGET
+RTEMS_CANONICALIZE_TOOLS
+RTEMS_PROG_CCAS
+AC_SUBST([RTEMS_ROOT],[${rtems_updir}'$(top_builddir)'])
+RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
+# Explicitly list all Makefiles here
+AC_CONFIG_FILES([Makefile])
+AC_OUTPUT
diff --git a/c/src/lib/libbsp/i386/virtualpok/console/console.c b/c/src/lib/libbsp/i386/virtualpok/console/console.c
index 0000000..51ff319
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/console/console.c
@@ -0,0 +1,184 @@
+ *  This file contains the template for a console IO package.
+ *  COPYRIGHT (c) 2013 Philipp Eppelt.
+#define NO_BSP_INIT
+#include <bsp.h>
+#include <rtems/libio.h>
+ * @brief Initializes the console.
+rtems_device_driver console_initialize(
+  rtems_device_major_number  major,
+  rtems_device_minor_number  minor,
+  void                      *arg
+  status = rtems_io_register_name(
+    "/dev/console",
+    major,
+    (rtems_device_minor_number) 0
+  if (status != RTEMS_SUCCESSFUL)
+    rtems_fatal_error_occurred(status);
+// Virtual console init
+  status = _BSP_Virtual_Console_init();
+  if( status != 0 )
+  return RTEMS_SUCCESSFUL;
+ * @brief Read a char from the virtual console (if supported).
+char inbyte( void )
+  return _BSP_Virtual_Char_read();
+ * @brief Write a char to the virtual console.
+void outbyte(
+  char ch
+  _BSP_Virtual_Char_write(&ch);
+/* printk support */
+BSP_output_char_function_type BSP_output_char = outbyte;
+BSP_polling_getchar_function_type BSP_poll_char = inbyte;
+/* Console support */
+ * It is mostly a translation of termios intended calls to the char by char
+ * printk interface.
+ * @brief Does nothing.
+rtems_device_driver console_open(
+  void                    * arg
+rtems_device_driver console_close(
+  void                    * arg
+ * read bytes from the serial port. We only have stdin.
+ * @brief Looks like termios, but reads through inbyte() function.
+rtems_device_driver console_read(
+  void                    * arg
+  rtems_libio_rw_args_t *rw_args;
+  char *buffer;
+  int maximum;
+  int count = 0;
+  rw_args = (rtems_libio_rw_args_t *) arg;
+  buffer = rw_args->buffer;
+  maximum = rw_args->count;
+  for (count = 0; count < maximum; count++) {
+    buffer[ count ] = inbyte();
+    if (buffer[ count ] == '\n' || buffer[ count ] == '\r') {
+      buffer[ count++ ]  = '\n';
+      break;
+  rw_args->bytes_moved = count;
+  return (count >= 0) ? RTEMS_SUCCESSFUL : RTEMS_UNSATISFIED;
+ * @brief Looks like termios, but writes through outbyte() function.
+rtems_device_driver console_write(
+  void                    * arg
+  int count;
+  int maximum;
+  char *buffer;
+    if ( buffer[ count ] == '\n') {
+      outbyte('\r');
+    outbyte( buffer[ count ] );
+  rw_args->bytes_moved = maximum;
+  return 0;
+ * @brief Does nothing!
+rtems_device_driver console_control(
+  void                    * arg
diff --git a/c/src/lib/libbsp/i386/virtualpok/include/bsp.h b/c/src/lib/libbsp/i386/virtualpok/include/bsp.h
index 0000000..1d781ba
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/include/bsp.h
@@ -0,0 +1,53 @@
+/*  bsp.h
+ *  This include file contains all board IO definitions.
+#ifndef _BSP_H
+#define _BSP_H
+#include <bspopts.h>
+#include <rtems.h>
+#include <rtems/console.h>
+#include <rtems/clockdrv.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *  Simple spin delay in microsecond units for device drivers.
+ *  This is very dependent on the clock speed of the target.
+#define rtems_bsp_delay( microseconds ) \
+#define	BSP_DEFAULT_UNIFIED_WORK_AREAS 1
+/* functions */
+rtems_isr_entry set_vector(                    /* returns old vector */
+  rtems_isr_entry     handler,                  /* isr routine        */
+  rtems_vector_number vector,                   /* vector number      */
+  int                 type                      /* RTEMS or RAW intr  */
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/i386/virtualpok/include/virtualizationlayerbsp.h b/c/src/lib/libbsp/i386/virtualpok/include/virtualizationlayerbsp.h
index 0000000..a329610
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/include/virtualizationlayerbsp.h
@@ -0,0 +1,62 @@
+ *    philipp.eppelt at mailbox.tu-dresden.de
+ *  Purpose:   BSP part of the virtualization layer.
+#ifndef RTEMS_VIRT_LAYER_BSP_H
+#define RTEMS_VIRT_LAYER_BSP_H
+ * \brief Initializes the console.
+int
+_BSP_Virtual_Console_init(void);
+ * \brief Reads a character from the console.
+char
+_BSP_Virtual_Char_read(void);
+ * \brief Writes a character to the console.
+void
+_BSP_Virtual_Char_write(char* c);
+ * \brief Initializes the clock.
+int
+_BSP_Virtual_Clock_init(void);
+ * \brief Reads the clock.
+int
+_BSP_Virtual_Clock_read(void);
+ * \brief Handles faults delivered by the host system.
+ * POK will forward occuring faults to this handler.
+int
+_BSP_Virtual_faulthandler(void);
+/* Startup functions
+int
+_BSP_Virtual_getworkspacearea( void );
+#endif /* RTEMS_VIRT_LAYER_BSP_H */
diff --git a/c/src/lib/libbsp/i386/virtualpok/irq/irq.c b/c/src/lib/libbsp/i386/virtualpok/irq/irq.c
index 0000000..a095e26
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/irq/irq.c
@@ -0,0 +1,85 @@
+#include <bsp/irq-generic.h>
+#include <stdio.h>
+#include <inttypes.h> /* PRIu32 */
+uint32_t            irq_count[BSP_IRQ_LINES_NUMBER] = {0};
+uint32_t
+BSP_irq_count_dump(FILE *f)
+  uint32_t tot = 0;
+  int      i;
+  if ( !f )
+    f = stdout;
+  for ( i=0; i<BSP_IRQ_LINES_NUMBER; i++ ) {
+    tot += irq_count[i];
+    fprintf(f,"IRQ %2u: %9"PRIu32"\n", i, irq_count[i]);
+  return tot;
+ * @brief Enable vector line at interrupt source. See description!
+ * Currently this is only a dummy function, as registering the vector on POK
+ * will deliver interrupts before the handler is installed. So the driver
+ * needing the interrupt needs to call _CPU_Virtual_Irq_attach().
+rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
+ * @brief Disabling vector line at interrupt source.
+rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  _CPU_Virtual_Irq_detach( vector );
+ * @brief Dummy function; necessary for a normal startup.
+rtems_status_code bsp_interrupt_facility_initialize(void)
+ * @brief If no interrupt handler is installed for a specified vector number,
+ * this is called and will output a warning.
+void bsp_interrupt_handler_default(rtems_vector_number vector)
+  printk( "WARNING: Somebody forgot to register a handler for this interrupt: %x \n", vector );
+ * @brief Forwards the interrupt to bsp_interrupt_handler_dispatch to look for
+ * the right handler.
+void C_dispatch_isr(int vector)
+  irq_count[vector]++;
+  bsp_interrupt_handler_dispatch(vector);
+ * @brief Initializes interrupts management.
+ * Called by bsp_start(), does all necessary IRQ initialization.
+void  rtems_irq_mngt_init(void)
+     * Init initial Interrupt management config
+    bsp_interrupt_initialize();
+    printf("bsp_interrupt_initialize successful\n");
diff --git a/c/src/lib/libbsp/i386/virtualpok/irq/irq.h b/c/src/lib/libbsp/i386/virtualpok/irq/irq.h
index 0000000..83aa109
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/irq/irq.h
@@ -0,0 +1,79 @@
+/* irq.h
+ *  This include file describe the data structure and the functions implemented
+ *  by rtems to write interrupt handlers.
+ *  CopyRight (C) 1998 valette at crf.canon.fr
+ *  This code is heavilly inspired by the public specification of STREAM V2
+ *  that can be found at :
+ *      <http://www.chorus.com/Documentation/index.html> by following
+ *  the STREAM API Specification Document link.
+ * The code here is to accomodate some drivers from the i386 shared directory,
+ * for the POK BSP they are useless but removing will break compilation.
+ * Leaving this to be here is harmless, this code can be thrown when the POK
+ * BSP gets its own architecture directory.
+#ifndef _IRQ_H_
+#define _IRQ_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * Include some preprocessor value also used by assember code
+#include <rtems.h>
+#define BSP_SHARED_HANDLER_SUPPORT      1
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+| Constants
+    /* Base vector for our IRQ handlers. */
+#define BSP_IRQ_LINES_NUMBER    	16
+#define BSP_LOWEST_OFFSET		0
+#define BSP_MAX_OFFSET		 	(BSP_IRQ_LINES_NUMBER - 1)
+     * Interrupt offset in comparison to BSP_ASM_IRQ_VECTOR_BASE
+     * NB : 1) Interrupt vector number in IDT = offset + BSP_ASM_IRQ_VECTOR_BASE
+     * 	    2) The same name should be defined on all architecture
+     *	       so that handler connection can be unchanged.
+#define BSP_PERIODIC_TIMER      0
+#define BSP_KEYBOARD          	1 /* can't be used, as POK doesn't support keyboards */
+#define BSP_UART_COM2_IRQ	3
+#define BSP_UART_COM1_IRQ	4
+#define BSP_UART_COM3_IRQ	5
+#define BSP_UART_COM4_IRQ	6
+#define BSP_RT_TIMER1	      	8
+#define BSP_RT_TIMER3		10
+#define BSP_SMP_IPI   		16
+#define BSP_INTERRUPT_VECTOR_MIN BSP_LOWEST_OFFSET
+#define BSP_INTERRUPT_VECTOR_MAX BSP_MAX_OFFSET
+| Function Prototypes.
+void C_dispatch_isr(int vector);
+#ifdef __cplusplus
+#endif
+#endif /* _IRQ_H_ */
diff --git a/c/src/lib/libbsp/i386/virtualpok/make/custom/virtualpok.cfg b/c/src/lib/libbsp/i386/virtualpok/make/custom/virtualpok.cfg
index 0000000..a280b9d
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/make/custom/virtualpok.cfg
@@ -0,0 +1,17 @@
+#  Configuration file for the "virtualpok" board
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU=i386
+RTEMS_CPU_MODEL=pentium
+#CPU_CFLAGS =
+# debug info
+CFLAGS_OPTIMIZE_V = -g
+# Miscellaneous additions go here
+#see pc386/make/custom/ for more information
diff --git a/c/src/lib/libbsp/i386/virtualpok/preinstall.am b/c/src/lib/libbsp/i386/virtualpok/preinstall.am
index 0000000..698ede6
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/preinstall.am
@@ -0,0 +1,79 @@
+## Automatically generated by ampolish3 - Do not edit
+if AMPOLISH3
+$(srcdir)/preinstall.am: Makefile.am
+	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
+endif
+PREINSTALL_DIRS =
+DISTCLEANFILES += $(PREINSTALL_DIRS)
+all-local: $(TMPINSTALL_FILES)
+TMPINSTALL_FILES =
+CLEANFILES = $(TMPINSTALL_FILES)
+all-am: $(PREINSTALL_FILES)
+PREINSTALL_FILES =
+CLEANFILES += $(PREINSTALL_FILES)
+$(PROJECT_LIB)/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_LIB)
+	@: > $(PROJECT_LIB)/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
+$(PROJECT_INCLUDE)/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)
+	@: > $(PROJECT_INCLUDE)/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
+$(PROJECT_INCLUDE)/bsp/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
+	@: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
+PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
+$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
+$(PROJECT_INCLUDE)/tm27.h: ../../shared/include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
+$(PROJECT_INCLUDE)/virtualizationlayerbsp.h: include/virtualizationlayerbsp.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/virtualizationlayerbsp.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/virtualizationlayerbsp.h
+$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
+$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
+$(PROJECT_INCLUDE)/bsp/irq.h: irq/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
+$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
+$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
+$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
+PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
+$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
+TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
diff --git a/c/src/lib/libbsp/i386/virtualpok/start/start.S b/c/src/lib/libbsp/i386/virtualpok/start/start.S
index 0000000..5048586
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/start/start.S
@@ -0,0 +1,37 @@
+ *  COPYRIGHT (c) 2013/
+ *  Philipp Eppelt.
+ *  Contact:  philipp.eppelt at mailbox.tu-dresden.de
+ *  Purpose:  Provides GNU entry point and directly go to bootcard.
+#include <rtems/asm.h>
+#include <rtems/score/cpu.h>
+#ifndef CPU_STACK_ALIGNMENT
+#error  "Missing header ? CPU_STACK_ALIGNMENT NOT DEFINED"
+#endif
+.set STACK_SIZE, 0x1000
+| CODE section
+BEGIN_CODE
+	PUBLIC (start)		# GNU default entry point
+	EXTERN (boot_card)
+	EXTERN (bsp_reset)
+SYM (start):
+	call	SYM (boot_card)
+	# TODO when this returns there should be some shut down handling
+	call	SYM (bsp_reset)
diff --git a/c/src/lib/libbsp/i386/virtualpok/startup/bspgetworkarea.c b/c/src/lib/libbsp/i386/virtualpok/startup/bspgetworkarea.c
index 0000000..562a8e9
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/startup/bspgetworkarea.c
@@ -0,0 +1,102 @@
+ *  This routine is an implementation of the bsp_get_work_area()
+ *  that can be used by all BSPs following linkcmds conventions
+ *  regarding heap, stack, and workspace allocation.
+ *  COPYRIGHT (c) 1989-2008.
+ *  Copyright (c) 2011 embedded brains GmbH.
+/* #define BSP_GET_WORK_AREA_DEBUG */
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#ifdef BSP_GET_WORK_AREA_DEBUG
+  #include <rtems/bspIo.h>
+#endif
+ *  These are provided by the linkcmds for ALL of the BSPs which use this file.
+extern char WorkAreaBase[];
+extern char HeapSize[];
+extern char ELFBase[];
+extern char textBase[];
+extern char rodataBase[];
+extern char dataBase[];
+unsigned long _Global_descriptor_table = 0;
+ *  This method returns the base address and size of the area which
+ *  is to be allocated between the RTEMS Workspace and the C Program
+ *  Heap.
+void bsp_work_area_initialize( void )
+/*  uintptr_t ELF_Base = (uintptr_t) ELFBase;
+  uintptr_t text_Base = (uintptr_t) textBase;
+  uintptr_t rodata_Base = (uintptr_t) rodataBase;
+  uintptr_t data_Base = (uintptr_t) dataBase;
+  uintptr_t work_base = (uintptr_t) WorkAreaBase;
+  uint32_t work_size = 0x100000 * 4;
+//  uint32_t base_addr = 0;
+//  uint32_t pok_stack_size = 0;
+  // TODO add call to virtlayer to get space
+  bsp_work_area_initialize_default( work_base, work_size );
+  *work_area_start = (void *) work_base + pok_stack_size;
+  *work_area_size  = size - work_base - pok_stack_size;
+  *heap_start      = 0;
+  *heap_size       = (uintptr_t) HeapSize;
+   *  The following may be helpful in debugging what goes wrong when
+   *  you are allocating the Work Area in a new BSP.
+  #ifdef BSP_GET_WORK_AREA_DEBUG
+      void *sp = __builtin_frame_address(0);
+      void *end = *work_area_start + *work_area_size;
+      printk(
+        "ELFBase = 0x%p\n"
+        "textBase = 0x%p\n"
+        "rodataBase = 0x%p\n"
+        "dataBase = 0x%p\n"
+        "work_area_start (base_addr) = 0x%p\n"
+        "WorkAreaBase = 0x%p\n"
+        "work_area_size = %d 0x%08x\n"
+        "end = 0x%p\n"
+        "heap_start = 0x%p\n"
+        "heap_size = %d\n"
+        "pok stack size = 0x%p\n"
+        "current stack pointer = 0x%p%s\n",
+        ELF_Base,
+        text_Base,
+        rodata_Base,
+        data_Base,
+        *work_area_start,
+        work_base,
+        *work_area_size,  /* decimal */
+        *work_area_size,  /* hexadecimal */
+        end,
+        *heap_start,
+        *heap_size,
+        pok_stack_size,
+        sp,
+        ((sp >= *work_area_start && sp <= end) ? " OVERLAPS!" : "")
+ #endif
diff --git a/c/src/lib/libbsp/i386/virtualpok/startup/bspstart.c b/c/src/lib/libbsp/i386/virtualpok/startup/bspstart.c
index 0000000..e787f96
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/startup/bspstart.c
@@ -0,0 +1,41 @@
+ *  This routine starts the application.  It includes application,
+ *  board, and monitor specific initialization and configuration.
+ *  The generic CPU dependent initialization has been performed
+ *  before this routine is invoked.
+#include <string.h>
+#include <bsp.h>
+#include <rtems.h>
+#include <rtems/bspIo.h>
+extern void rtems_irq_mngt_init(void);
+ *  bsp_start
+ *  This routine does the bulk of the system initialization.
+void bsp_start( void )
+  _BSP_Virtual_Char_write( "Hello RTEMS World\n" );
+  // Initialize IRQ management
+  rtems_irq_mngt_init();
+  // Register clock driver
+  Clock_driver_install_handler();
diff --git a/c/src/lib/libbsp/i386/virtualpok/startup/linkcmds b/c/src/lib/libbsp/i386/virtualpok/startup/linkcmds
index 0000000..a425a94
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/startup/linkcmds
@@ -0,0 +1,251 @@
+ *  Copy of default "default linker script, for normal executables"
+ *  provided with binutils 2.18 with minor modifications for use
+ *  as pc386 linkcmds.  These changes include:
+ *    + sections commented out marked with "XXX commented out --joel"
+ *    + addition of m_hdr section
+ *    + addition of FreeBSD sysctl sections
+ * XXX commented out --joel
+OUTPUT_FORMAT("elf32-i386", "elf32-i386",
+	      "elf32-i386")
+OUTPUT_ARCH(i386)
+ENTRY(start)
+HeapSize = DEFINED(HeapSize) ? HeapSize :
+          DEFINED(_HeapSize) ? _HeapSize : 0x0;
+RamBase = DEFINED(_RamBase) ? RamBase : 0x0;
+RamSize = DEFINED(RamSize) ? RamSize    :
+          DEFINED(_RamSize) ? _RamSize : 0xFFFFFFFF;
+SECTIONS
+  . = 0x1000;
+  /* Read-only sections, merged into text segment: */
+  PROVIDE (__executable_start = 0x08048000); . = 0x08048000 + SIZEOF_HEADERS;
+  .interp         : { *(.interp) }
+  .note.gnu.build-id : { *(.note.gnu.build-id) }
+  .hash           : { *(.hash) }
+  .gnu.hash       : { *(.gnu.hash) }
+  .dynsym         : { *(.dynsym) }
+  .dynstr         : { *(.dynstr) }
+  .gnu.version    : { *(.gnu.version) }
+  .gnu.version_d  : { *(.gnu.version_d) }
+  .gnu.version_r  : { *(.gnu.version_r) }
+  .rel.init       : { *(.rel.init) }
+  .rela.init      : { *(.rela.init) }
+  .rel.text       : { *(.rel.text .rel.text.* .rel.gnu.linkonce.t.*) }
+  .rela.text      : { *(.rela.text .rela.text.* .rela.gnu.linkonce.t.*) }
+  .rel.fini       : { *(.rel.fini) }
+  .rela.fini      : { *(.rela.fini) }
+  .rel.rodata     : { *(.rel.rodata .rel.rodata.* .rel.gnu.linkonce.r.*) }
+  .rela.rodata    : { *(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*) }
+  .rel.data.rel.ro   : { *(.rel.data.rel.ro* .rel.gnu.linkonce.d.rel.ro.*) }
+  .rela.data.rel.ro   : { *(.rela.data.rel.ro* .rela.gnu.linkonce.d.rel.ro.*) }
+  .rel.data       : { *(.rel.data .rel.data.* .rel.gnu.linkonce.d.*) }
+  .rela.data      : { *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*) }
+  .rel.tdata	  : { *(.rel.tdata .rel.tdata.* .rel.gnu.linkonce.td.*) }
+  .rela.tdata	  : { *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*) }
+  .rel.tbss	  : { *(.rel.tbss .rel.tbss.* .rel.gnu.linkonce.tb.*) }
+  .rela.tbss	  : { *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*) }
+  .rel.ctors      : { *(.rel.ctors) }
+  .rela.ctors     : { *(.rela.ctors) }
+  .rel.dtors      : { *(.rel.dtors) }
+  .rela.dtors     : { *(.rela.dtors) }
+  .rel.got        : { *(.rel.got) }
+  .rela.got       : { *(.rela.got) }
+  .rel.bss        : { *(.rel.bss .rel.bss.* .rel.gnu.linkonce.b.*) }
+  .rela.bss       : { *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*) }
+  .rel.plt        : { *(.rel.plt) }
+  .rela.plt       : { *(.rela.plt) }
+  .plt            : { *(.plt) }
+  .text           :
+   *(.m_hdr)
+    *(.text .stub .text.* .gnu.linkonce.t.*)
+    KEEP (*(.text.*personality*))
+    /* .gnu.warning sections are handled specially by elf32.em.  */
+    *(.gnu.warning)
+  } =0x90909090
+  .robsdsets : {
+    /* for pre rtems-libbsd FreeBSD code */
+    __start_set_sysctl_set = .;
+    *(set_sysctl_*);
+    __stop_set_sysctl_set = .;
+    *(set_domain_*);
+    *(set_pseudo_*);
+    /* for rtems-libbsd FreeBSD code */
+    _bsd__start_set_modmetadata_set = .;
+    *(_bsd_set_modmetadata_set);
+    _bsd__stop_set_modmetadata_set = .;
+    _bsd__start_set_sysctl_set = .;
+    *(_bsd_set_sysctl_set);
+    _bsd__stop_set_sysctl_set = .;
+    _bsd__start_set_sysinit_set = .;
+    *(_bsd_set_sysinit_*);
+    _bsd__stop_set_sysinit_set = .;
+    bsp_section_rodata_end = .;
+  } =0x90909090
+  .init           :
+    KEEP (*(.init))
+  } =0x90909090
+  .fini           :
+    KEEP (*(.fini))
+  } =0x90909090
+  PROVIDE (__etext = .);
+  PROVIDE (_etext = .);
+  PROVIDE (etext = .);
+  .rodata         : { *(.rodata .rodata.* .gnu.linkonce.r.*) }
+  .rodata1        : { *(.rodata1) }
+  .eh_frame_hdr : { *(.eh_frame_hdr) }
+  .eh_frame       : ONLY_IF_RO { KEEP (*(.eh_frame)) }
+  .gcc_except_table   : ONLY_IF_RO { *(.gcc_except_table .gcc_except_table.*) }
+  /* Adjust the address for the data segment.  We want to adjust up to
+     the same address within the page on the next page up.  */
+  . = ALIGN (CONSTANT (MAXPAGESIZE)) - ((CONSTANT (MAXPAGESIZE) - .) & (CONSTANT (MAXPAGESIZE) - 1)); . = DATA_SEGMENT_ALIGN (CONSTANT (MAXPAGESIZE), CONSTANT (COMMONPAGESIZE));
+  /* Exception handling  */
+  .eh_frame       : ONLY_IF_RW { KEEP (*(.eh_frame)) }
+  .gcc_except_table   : ONLY_IF_RW { *(.gcc_except_table .gcc_except_table.*) }
+  /* Thread Local Storage sections  */
+  .tdata	  : { *(.tdata .tdata.* .gnu.linkonce.td.*) }
+  .tbss		  : { *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon) }
+  .preinit_array     :
+    PROVIDE_HIDDEN (__preinit_array_start = .);
+    KEEP (*(.preinit_array))
+    PROVIDE_HIDDEN (__preinit_array_end = .);
+  .init_array     :
+     PROVIDE_HIDDEN (__init_array_start = .);
+     KEEP (*(SORT(.init_array.*)))
+     KEEP (*(.init_array))
+     PROVIDE_HIDDEN (__init_array_end = .);
+  .fini_array     :
+    PROVIDE_HIDDEN (__fini_array_start = .);
+    KEEP (*(.fini_array))
+    KEEP (*(SORT(.fini_array.*)))
+    PROVIDE_HIDDEN (__fini_array_end = .);
+  .ctors          :
+    /* gcc uses crtbegin.o to find the start of
+       the constructors, so we make sure it is
+       first.  Because this is a wildcard, it
+       doesn't matter if the user does not
+       actually link against crtbegin.o; the
+       linker won't look for a file to match a
+       wildcard.  The wildcard also means that it
+       doesn't matter which directory crtbegin.o
+       is in.  */
+    KEEP (*crtbegin.o(.ctors))
+    KEEP (*crtbegin?.o(.ctors))
+    /* We don't want to include the .ctor section from
+       the crtend.o file until after the sorted ctors.
+       The .ctor section from the crtend file contains the
+       end of ctors marker and it must be last */
+    KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
+    KEEP (*(SORT(.ctors.*)))
+    KEEP (*(.ctors))
+  .dtors          :
+    KEEP (*crtbegin.o(.dtors))
+    KEEP (*crtbegin?.o(.dtors))
+    KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
+    KEEP (*(SORT(.dtors.*)))
+    KEEP (*(.dtors))
+  .jcr            : { KEEP (*(.jcr)) }
+  .data.rel.ro : { *(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*) *(.data.rel.ro* .gnu.linkonce.d.rel.ro.*) }
+  .dynamic        : { *(.dynamic) }
+  .got            : { *(.got) }
+  . = DATA_SEGMENT_RELRO_END (12, .);
+  .got.plt        : { *(.got.plt) }
+  .data           :
+    *(.data .data.* .gnu.linkonce.d.*)
+    KEEP (*(.gnu.linkonce.d.*personality*))
+    SORT(CONSTRUCTORS)
+  .data1          : { *(.data1) }
+  _edata = .; PROVIDE (edata = .);
+  __bss_start = .;
+  .bss            :
+   *(.dynbss)
+   *(.bss .bss.* .gnu.linkonce.b.*)
+   *(COMMON)
+   /* Align here to ensure that the .bss section occupies space up to
+      _end.  Align after .bss to ensure correct alignment even if the
+      .bss section disappears because there are no input sections.
+      FIXME: Why do we need it? When there is no .bss section, we don't
+      pad the .data section.  */
+   . = ALIGN(. != 0 ? 32 / 8 : 1);
+  . = ALIGN(32 / 8);
+  _end = .; PROVIDE (end = .);
+  . = ALIGN(0x10);
+  WorkAreaBase = .;
+  . = DATA_SEGMENT_END (.);
+  /* Stabs debugging sections.  */
+  .stab          0 : { *(.stab) }
+  .stabstr       0 : { *(.stabstr) }
+  .stab.excl     0 : { *(.stab.excl) }
+  .stab.exclstr  0 : { *(.stab.exclstr) }
+  .stab.index    0 : { *(.stab.index) }
+  .stab.indexstr 0 : { *(.stab.indexstr) }
+  .comment       0 : { *(.comment) }
+  /* DWARF debug sections.
+     Symbols in the DWARF debugging sections are relative to the beginning
+     of the section so we begin them at 0.  */
+  /* DWARF 1 */
+  .debug          0 : { *(.debug) }
+  .line           0 : { *(.line) }
+  /* GNU DWARF 1 extensions */
+  .debug_srcinfo  0 : { *(.debug_srcinfo) }
+  .debug_sfnames  0 : { *(.debug_sfnames) }
+  /* DWARF 1.1 and DWARF 2 */
+  .debug_aranges  0 : { *(.debug_aranges) }
+  .debug_pubnames 0 : { *(.debug_pubnames) }
+  /* DWARF 2 */
+  .debug_info     0 : { *(.debug_info .gnu.linkonce.wi.*) }
+  .debug_abbrev   0 : { *(.debug_abbrev) }
+  .debug_line     0 : { *(.debug_line) }
+  .debug_frame    0 : { *(.debug_frame) }
+  .debug_str      0 : { *(.debug_str) }
+  .debug_loc      0 : { *(.debug_loc) }
+  .debug_macinfo  0 : { *(.debug_macinfo) }
+  /* SGI/MIPS DWARF 2 extensions */
+  .debug_weaknames 0 : { *(.debug_weaknames) }
+  .debug_funcnames 0 : { *(.debug_funcnames) }
+  .debug_typenames 0 : { *(.debug_typenames) }
+  .debug_varnames  0 : { *(.debug_varnames) }
+  /* DWARF 3 */
+  .debug_pubtypes 0 : { *(.debug_pubtypes) }
+  .debug_ranges   0 : { *(.debug_ranges) }
+  /* DWARF extension */
+  .debug_macro    0 : { *(.debug_macro) }
+  .gnu.attributes 0 : { KEEP (*(.gnu.attributes)) }
+  /DISCARD/ : { *(.note.GNU-stack) *(.gnu_debuglink) }
1.8.1.4
