SPARC linker command files
Jiri Gaisler jiri at gaisler.se
Thu Dec 5 21:57:46 UTC 2013
On 12/03/2013 11:29 AM, Sebastian Huber wrote:
> On 2013-12-03 10:13, Jiri Gaisler wrote:
>> On 12/03/2013 08:46 AM, Sebastian Huber wrote:
>>> >On 2013-12-02 23:06, Jiri Gaisler wrote:
>>>> >>On 11/30/2013 02:31 AM, Gedare Bloom wrote:
>>>>>> >>> >Does the NGMP allow for variant sizes of ROM and RAM? If so will we
>>>>>> >>> >provide separate BSP variants for all possibilities, or how does the
>>>>>> >>> >user select the right size for their board?
>>>> >>The boot loader (or gdb debug monitor) supplies the top-of-stack
>>>> >>address in %sp when the RTEMS binary is called. The area between
>>>> >>the start address and %sp indicates the size of RAM to be used.
>>>> >>In this way only one bsp is needed.
>>> >Ok, good to know.  Then this symbols should probably go away.  Is the boot loader always the same?
>> The most common loader is generated by the mkprom2 PROM builder. The loader
>> sets up system specific things like memory controllers, timers and UARTs.
>> It the calls the RTEMS (or other eg. linux) binary with the top-of-RAM
>> in %sp.
>> The simulator (TSIM) and grmon debug monitor does the same thing as
>> the loader before launching the binary.
> The startup code also assumes a valid stack pointer for CPU0.  So what is the purpose of the global symbols?  Why not use the boot loader provided values we already rely on?
Which exact symbols do you mean? The ones in the link script, or others?
Note that the erc32 bsp is bit special since we could debug it using a gdb
stub, and the needed some way of passing parameters from the stub to the
kernel....
Jiri.
