[rtems commit] sptests: add a test for page size
Joel Sherrill Joel.Sherrill at OARcorp.com
Fri Dec 6 15:55:36 UTC 2013
Reviewing from my cell phone so didn't compile.
Copyright year is wrong.
Does sysconf() need to be called to ensure it gives a consistent answer?
Otherwise ok
On Dec 6, 2013 9:46 AM, Gedare Bloom <gedare at rtems.org> wrote:
Module:    rtems
Branch:    master
Commit:    54da1243eb1840a7311e2449e3fb3c00d45c7f2f
Changeset: http://git.rtems.org/rtems/commit/?id=54da1243eb1840a7311e2449e3fb3c00d45c7f2f
Author:    Chirayu Desai <cdesai at cyanogenmod.org>
Date:      Fri Dec  6 20:53:36 2013 +0530
Bug: https://www.rtems.org/bugzilla/show_bug.cgi?id=1216
 testsuites/sptests/Makefile.am               |    4 +-
 testsuites/sptests/configure.ac              |    1 +
 testsuites/sptests/sppagesize/Makefile.am    |   22 ++++++++++++
 testsuites/sptests/sppagesize/init.c         |   45 ++++++++++++++++++++++++++
 testsuites/sptests/sppagesize/sppagesize.doc |   17 ++++++++++
 testsuites/sptests/sppagesize/sppagesize.scn |    2 +
 6 files changed, 89 insertions(+), 2 deletions(-)
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 4618d36..f440b0f 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -26,8 +26,8 @@ SUBDIRS = \
     spintrcritical09 spintrcritical10 spintrcritical11 spintrcritical12 \
     spintrcritical13 spintrcritical14 spintrcritical15 spintrcritical16 \
     spintrcritical17 spintrcritical18 spmkdir spmountmgr01 spheapprot \
-    spsem01 spsem02 spsimplesched01 spsimplesched02 spsimplesched03 spnsext01 \
-    spedfsched01 spedfsched02 spedfsched03 \
+    sppagesize spsem01 spsem02 spsimplesched01 spsimplesched02 \
+    spsimplesched03 spnsext01 spedfsched01 spedfsched02 spedfsched03 \
     spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01
 SUBDIRS += spintrcritical20
 SUBDIRS += spintrcritical19
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 70e425d..69c999a 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -180,6 +180,7 @@ spmountmgr01/Makefile
 spnotepad01/Makefile
 spnsext01/Makefile
 spobjgetnext/Makefile
+sppagesize/Makefile
 spprintk/Makefile
 spprivenv01/Makefile
 spqreslib/Makefile
diff --git a/testsuites/sptests/sppagesize/Makefile.am b/testsuites/sptests/sppagesize/Makefile.am
new file mode 100644
index 0000000..83647ef
--- /dev/null
+++ b/testsuites/sptests/sppagesize/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = sppagesize
+sppagesize_SOURCES = init.c
+dist_rtems_tests_DATA = sppagesize.scn
+dist_rtems_tests_DATA += sppagesize.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(sppagesize_OBJECTS)
+LINK_LIBS = $(sppagesize_LDLIBS)
+sppagesize$(EXEEXT): $(sppagesize_OBJECTS) $(sppagesize_DEPENDENCIES)
+       @rm -f sppagesize$(EXEEXT)
+       $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/sppagesize/init.c b/testsuites/sptests/sppagesize/init.c
index 0000000..0f21aa8
--- /dev/null
+++ b/testsuites/sptests/sppagesize/init.c
@@ -0,0 +1,45 @@
+ *  COPYRIGHT (c) 1989-2011.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <tmacros.h>
+#include <rtems.h>
+#include <limits.h>
+#include <sys/param.h>
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument argument);
+rtems_task Init(
+  rtems_task_argument argument
+    puts("\n\n*** TEST SPPAGESIZE ***");
+    rtems_test_assert(PAGESIZE == PAGE_SIZE);
+    rtems_test_assert(getpagesize() == PAGE_SIZE);
+    puts("*** END OF TEST SPPAGESIZE ***");
+    rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/sppagesize/sppagesize.doc b/testsuites/sptests/sppagesize/sppagesize.doc
index 0000000..696d1fa
--- /dev/null
+++ b/testsuites/sptests/sppagesize/sppagesize.doc
@@ -0,0 +1,17 @@
+#  COPYRIGHT (c) 1989-2011.
+#  On-Line Applications Research Corporation (OAR).
+#  The license and distribution terms for this file may be
+#  found in the file LICENSE in this distribution or at
+#  http://www.rtems.com/license/LICENSE.
+test name:  sppagesize
+directives:
+  getpagesize
+concepts:
++ Verifies that the different declarations of pagesize have
+  the same value
diff --git a/testsuites/sptests/sppagesize/sppagesize.scn b/testsuites/sptests/sppagesize/sppagesize.scn
index 0000000..2468e04
--- /dev/null
+++ b/testsuites/sptests/sppagesize/sppagesize.scn
@@ -0,0 +1,2 @@
+*** TEST SPPAGESIZE ***
+*** END OF TEST SPPAGESIZE ***
rtems-vc mailing list
rtems-vc at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20131206/a41be6f7/attachment.html>
