sppagesize01 broken
Wed Dec 11 01:47:15 UTC 2013
On 12/10/2013 7:31 PM, Gedare Bloom wrote:
> This is a new test and known to fail in this way. It should succeed
> with the current newlib, the patch went in today.
Thanks!
My change to return EPERM if you called pthread_cond_wait() and
didn't actually have the mutex locked caught two tests that were
broken. :(
Luckily, adding 3 lines of code to the first of them covered the
case of returning the error.
--joel
> On Tue, Dec 10, 2013 at 6:44 PM, Joel Sherrill
> <Joel.Sherrill at oarcorp.com> wrote:
>> Hi
>> This test is failing for me. I hacked a printf into the output and got this:
>> *** TEST SPPAGESIZE ***
>> PAGESIZE=1 PAGE_SIZE=4096
>> ../../../../../../../rtems/c/src/../../testsuites/sptests/sppagesize/init.c: 28 PAGESIZE == PAGE_SIZE
>> Any suggestions?
>> --joel
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
