test failures on sis
Mon Dec 16 07:58:01 UTC 2013
On 2013-12-14 19:32, Joel Sherrill wrote:
> Hi
> The failures on sis on the head indicate a few that need
> some attention.
> WARNING - heapwalk did not appear to complete execution
>          create a loop in the free list
> ../../../../../../../rtems/c/src/../../testsuites/libtests/heapwalk/init.c:
> 55 retval == expectet_retval
In case RTEMS_DEBUG is enabled, then this is ok.
> WARNING - mrfs_fstime did not appear to complete execution
> Sleep a few seconds
> ../../../../../../../rtems/c/src/../../testsuites/fstests/mrfs_fstime/../fstime/test.c:
> 128 st.st_ctime == st.st_mtime
This is a TODO for the RFS.
> WARNING - sp2038 did not appear to complete execution
> I think this is expected.
Yes, this needs a 64-bit time_t.
> WARNING - spintrcritical20 did not appear to complete execution
> *** TEST INTERRUPT CRITICAL SECTION 20 ***
> This looks like recent changes may have broken things or
> the assertion is not really guaranteed all the time.
I think this is a problem with the test.  I see sporadic failures here.
> Support - rtems_timer_create - creating timer 1
> ../../../../../../../rtems/c/src/../../testsuites/sptests/spintrcritical20/init.c:
> 139 ctx->thread_queue_was_null
> WARNING - sppagesize did not appear to complete execution
> Known failure until tools adjusted.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
