[PATCH 3/3] Filesystem: Use default kqfilter and poll handler
Mon Dec 16 13:29:06 UTC 2013
 c/src/lib/libbsp/shared/umon/tfsDriver.c        |    2 ++
 cpukit/libblock/src/blkdev-imfs.c               |    2 ++
 cpukit/libcsupport/src/__usrenv.c               |    2 ++
 cpukit/libfs/src/defaults/default_handlers.c    |    2 ++
 cpukit/libfs/src/devfs/devfs_init.c             |    2 ++
 cpukit/libfs/src/dosfs/msdos_handlers_dir.c     |    2 ++
 cpukit/libfs/src/dosfs/msdos_handlers_file.c    |    2 ++
 cpukit/libfs/src/imfs/imfs_fifo.c               |    2 ++
 cpukit/libfs/src/imfs/imfs_handlers_device.c    |    2 ++
 cpukit/libfs/src/imfs/imfs_handlers_directory.c |    2 ++
 cpukit/libfs/src/imfs/imfs_handlers_link.c      |    2 ++
 cpukit/libfs/src/imfs/imfs_handlers_memfile.c   |    2 ++
 cpukit/libfs/src/jffs2/src/fs-rtems.c           |    6 ++++++
 cpukit/libfs/src/nfsclient/src/nfs.c            |    6 ++++++
 cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c      |    2 ++
 cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c      |    2 ++
 cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c     |    2 ++
 cpukit/libfs/src/rfs/rtems-rfs-rtems.c          |    2 ++
 cpukit/libnetworking/lib/ftpfs.c                |    4 ++++
 cpukit/libnetworking/lib/tftpDriver.c           |    2 ++
 cpukit/libnetworking/rtems/rtems_syscall.c      |    2 ++
 21 files changed, 52 insertions(+), 0 deletions(-)
diff --git a/c/src/lib/libbsp/shared/umon/tfsDriver.c b/c/src/lib/libbsp/shared/umon/tfsDriver.c
index 41c5809..0f561ea 100644
--- a/c/src/lib/libbsp/shared/umon/tfsDriver.c
+++ b/c/src/lib/libbsp/shared/umon/tfsDriver.c
@@ -676,6 +676,8 @@ static const rtems_filesystem_file_handlers_r rtems_tfs_handlers = {
   .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
   .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
   .fcntl_h = rtems_filesystem_default_fcntl,
+  .kqfilter_h = rtems_filesystem_default_kqfilter,
+  .poll_h = rtems_filesystem_default_poll,
   .readv_h = rtems_filesystem_default_readv,
   .writev_h = rtems_filesystem_default_writev
diff --git a/cpukit/libblock/src/blkdev-imfs.c b/cpukit/libblock/src/blkdev-imfs.c
index 48d5515..f52d158 100644
--- a/cpukit/libblock/src/blkdev-imfs.c
+++ b/cpukit/libblock/src/blkdev-imfs.c
@@ -221,6 +221,8 @@ static const rtems_filesystem_file_handlers_r rtems_blkdev_imfs_node = {
   .fsync_h = rtems_blkdev_imfs_fsync_or_fdatasync,
   .fdatasync_h = rtems_blkdev_imfs_fsync_or_fdatasync,
diff --git a/cpukit/libcsupport/src/__usrenv.c b/cpukit/libcsupport/src/__usrenv.c
index f860447..ba1016e 100644
--- a/cpukit/libcsupport/src/__usrenv.c
+++ b/cpukit/libcsupport/src/__usrenv.c
@@ -55,6 +55,8 @@ const rtems_filesystem_file_handlers_r rtems_filesystem_null_handlers = {
diff --git a/cpukit/libfs/src/defaults/default_handlers.c b/cpukit/libfs/src/defaults/default_handlers.c
index ce262b6..2924351 100644
--- a/cpukit/libfs/src/defaults/default_handlers.c
+++ b/cpukit/libfs/src/defaults/default_handlers.c
@@ -33,6 +33,8 @@ const rtems_filesystem_file_handlers_r rtems_filesystem_handlers_default = {
diff --git a/cpukit/libfs/src/devfs/devfs_init.c b/cpukit/libfs/src/devfs/devfs_init.c
index 4aa9f93..e5ba418 100644
--- a/cpukit/libfs/src/devfs/devfs_init.c
+++ b/cpukit/libfs/src/devfs/devfs_init.c
@@ -53,6 +53,8 @@ const rtems_filesystem_file_handlers_r devFS_file_handlers = {
diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
index 6d91603..881fe4b 100644
--- a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
+++ b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
@@ -33,6 +33,8 @@ const rtems_filesystem_file_handlers_r msdos_dir_handlers = {
   .fsync_h = msdos_sync,
   .fdatasync_h = msdos_sync,
diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_file.c b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
index d5885bb..3858403 100644
--- a/cpukit/libfs/src/dosfs/msdos_handlers_file.c
+++ b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
@@ -33,6 +33,8 @@ const rtems_filesystem_file_handlers_r msdos_file_handlers = {
   .fsync_h = msdos_file_sync,
diff --git a/cpukit/libfs/src/imfs/imfs_fifo.c b/cpukit/libfs/src/imfs/imfs_fifo.c
index 743261a..ec796c7 100644
--- a/cpukit/libfs/src/imfs/imfs_fifo.c
+++ b/cpukit/libfs/src/imfs/imfs_fifo.c
@@ -124,6 +124,8 @@ static const rtems_filesystem_file_handlers_r IMFS_fifo_handlers = {
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_device.c b/cpukit/libfs/src/imfs/imfs_handlers_device.c
index 451e201..908ab2b 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_device.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_device.c
@@ -45,6 +45,8 @@ static const rtems_filesystem_file_handlers_r IMFS_device_handlers = {
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_directory.c b/cpukit/libfs/src/imfs/imfs_handlers_directory.c
index ab267d7..ca3014a 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_directory.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_directory.c
@@ -61,6 +61,8 @@ static const rtems_filesystem_file_handlers_r IMFS_directory_handlers = {
   .fsync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
   .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_link.c b/cpukit/libfs/src/imfs/imfs_handlers_link.c
index 00f09fc..a59b35f 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_link.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_link.c
@@ -56,6 +56,8 @@ static const rtems_filesystem_file_handlers_r IMFS_link_handlers = {
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_memfile.c b/cpukit/libfs/src/imfs/imfs_handlers_memfile.c
index 44ed856..dc616e4 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_memfile.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_memfile.c
@@ -45,6 +45,8 @@ static const rtems_filesystem_file_handlers_r IMFS_memfile_handlers = {
diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
index c8d6b9b..85f9ede 100644
--- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
+++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
@@ -517,6 +517,8 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_directory_handlers = {
@@ -657,6 +659,8 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_file_handlers = {
@@ -673,6 +677,8 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_link_handlers = {
diff --git a/cpukit/libfs/src/nfsclient/src/nfs.c b/cpukit/libfs/src/nfsclient/src/nfs.c
index c249522..9b19bf4 100644
--- a/cpukit/libfs/src/nfsclient/src/nfs.c
+++ b/cpukit/libfs/src/nfsclient/src/nfs.c
@@ -2870,6 +2870,8 @@ struct _rtems_filesystem_file_handlers_r nfs_file_file_handlers = {
@@ -2888,6 +2890,8 @@ struct _rtems_filesystem_file_handlers_r nfs_dir_file_handlers = {
@@ -2906,6 +2910,8 @@ struct _rtems_filesystem_file_handlers_r nfs_link_file_handlers = {
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
index ce1b77f..f75fd01 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
@@ -194,6 +194,8 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_device_handlers = {
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
index eed110e..b60c990 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
@@ -163,6 +163,8 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_dir_handlers = {
   .fdatasync_h = rtems_rfs_rtems_fdatasync,
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
index 412586d..95f1e57 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
@@ -354,6 +354,8 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_file_handlers = {
   .fsync_h     = rtems_rfs_rtems_fdatasync,
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
index 60ab3bb..08b80a2 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
@@ -781,6 +781,8 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_link_handlers =
diff --git a/cpukit/libnetworking/lib/ftpfs.c b/cpukit/libnetworking/lib/ftpfs.c
index d622ff6..884e9c3 100644
--- a/cpukit/libnetworking/lib/ftpfs.c
+++ b/cpukit/libnetworking/lib/ftpfs.c
@@ -1413,6 +1413,8 @@ static const rtems_filesystem_file_handlers_r rtems_ftpfs_handlers = {
@@ -1429,6 +1431,8 @@ static const rtems_filesystem_file_handlers_r rtems_ftpfs_root_handlers = {
diff --git a/cpukit/libnetworking/lib/tftpDriver.c b/cpukit/libnetworking/lib/tftpDriver.c
index c6461e0..414012a 100644
--- a/cpukit/libnetworking/lib/tftpDriver.c
+++ b/cpukit/libnetworking/lib/tftpDriver.c
@@ -1052,6 +1052,8 @@ static const rtems_filesystem_file_handlers_r rtems_tftp_handlers = {
diff --git a/cpukit/libnetworking/rtems/rtems_syscall.c b/cpukit/libnetworking/rtems/rtems_syscall.c
index 4aa7ad8..b221578 100644
--- a/cpukit/libnetworking/rtems/rtems_syscall.c
+++ b/cpukit/libnetworking/rtems/rtems_syscall.c
@@ -823,6 +823,8 @@ static const rtems_filesystem_file_handlers_r socket_handlers = {
 	.fstat_h = rtems_filesystem_default_fsync_or_fdatasync,
 	.fcntl_h = rtems_bsdnet_fcntl,
1.7.7
