Fixed size cpusetf patch
Jennifer Averett Jennifer.Averett at OARcorp.com
Tue Dec 17 13:20:54 UTC 2013
I started out with it as one, but because of the way the tests run
a lot of data comes out (one line for each comparison).  I split them
up so each test doesn't output so many screens of data.  If I put them
back as one, would it be better only print at the top of the test (ex.
AND test) then print details upon a failure within that (this doesn't
match the way other tests work though)
> -----Original Message-----
> From: rtems-devel-bounces at rtems.org [mailto:rtems-devel-
> bounces at rtems.org] On Behalf Of Sebastian Huber
> Sent: Tuesday, December 17, 2013 1:42 AM
> To: rtems-devel at rtems.org
> Subject: Re: Fixed size cpusetf patch
> On 2013-12-16 20:17, Jennifer Averett wrote:
> > Attached is an patch for a set of tests that checks  the fixed size
> > functionali8ty in cpuset.h
> > Any comments, questions, suggestions?
> Do we really need five different test programs.  Can't we use one test
> program with five test functions?
> rtems-devel mailing list
