Fixed size cpusetf patch
Tue Dec 17 13:27:07 UTC 2013
On 2013-12-17 14:20, Jennifer Averett wrote:
> I started out with it as one, but because of the way the tests run
> a lot of data comes out (one line for each comparison).  I split them
> up so each test doesn't output so many screens of data.  If I put them
> back as one, would it be better only print at the top of the test (ex.
> AND test) then print details upon a failure within that (this doesn't
> match the way other tests work though)
The only interesting output is the "END OF TEST" message, since this checked by
the RTEMS testing script.  I case of failure you get an assert message, this
should be enough.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
