[PATCH] For PR 2164 - RFS File System - fix bitmap_create_search loop bug
Alan Cudmore
alan.cudmore at gmail.com
Wed Dec 18 17:00:42 UTC 2013
This is for the RFS file system. There is a bug in the rtems_rfs_bitmap_create_search loop. It is supposed to iterate over the range of bits in a search element ( usually 32 bits ), so it should loop through bits 0 through 31. Instead it loops through 0 - 32, causing some blocks not to be allocated. As in PR 2163, this depends on the block size and number of blocks in a file system. Block sizes and group sizes that are powers of 2 seem to work fine ( 512 byte blocks, 4096 block groups, etc ). When the block sizes are not powers of 2, then this loop error causes some of the blocks at the end of a group to be skipped, preventing 100% of the blocks from being used. A simple test for this and PR2163 is to create a RAM disk with block size 3900 and at least 1 full group ( 31200 blocks ). A file system with these sizes will not be able to allocate 100% of the blocks.
cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c b/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
index c4050b2..b8bd0b3 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
@@ -599,7 +599,8 @@ rtems_rfs_bitmap_create_search (rtems_rfs_bitmap_control* control)
size -= available;
- if (bit == rtems_rfs_bitmap_element_bits ())
+ /* Iterate from 0 to 1 less than the number of bits in an element */
+ if (bit == (rtems_rfs_bitmap_element_bits () - 1))
bit = 0;
search_map++;
1.8.3.2
