[PATCH] Mongoose HTTPd from 3.2 to 3.9 (last commit before MIT -> GPL)
Sebastian Huber
Wed Dec 4 09:12:26 UTC 2013
Hello Nick,
On 2013-12-04 01:48, Nick Withers wrote:
> On Mon, 2013-12-02 at 09:44 +1100, Nick Withers wrote:
>> >On Fri, 2013-11-29 at 13:00 +0100, Sebastian Huber wrote:
>>> > >Hello Nick,
>>> > >it seems that there was again an API change. Can you please build with
>>> > >"--enable-tests" and fix the errors below. Can you please also run this test
>>> > >and make sure it passes.
>> >Will do - thanks Sebastian!
> Righto - please find attached an updated patch. Tested the mghttpd01 app
> successfully under psim and on MVME3100 hardware (both powerpc).
> If this does get committed, it'd be nice to include a warning of the
> interface changes on the Wiki (which I'm happy to do :-)). Perhaps the
> following (from the commit message, not an exhaustive list of
> differences) would do?
thanks for the patch. I checked it in
http://git.rtems.org/rtems/commit/?id=b5d2d4a61ce91765e9cac1b02271a8f4b049c558
Would you mind updating the wiki?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
