[PATCH 2/3] Filesystem: Add readv/writev handlers
Sebastian Huber
Mon Dec 16 13:29:05 UTC 2013
The readv() and writev() support was implemented in terms of single
calls to the read and write handlers. This imposes a problem on device
files which use an IO vector as single request entity. For example a
low-level network device (e.g. BPF(4)) may use an IO vector to create
one frame from multiple protocol layers each with its own IO vector
entry.
c/src/lib/libbsp/shared/umon/tfsDriver.c | 4 +-
cpukit/libblock/src/blkdev-imfs.c | 4 +-
cpukit/libcsupport/include/rtems/libio.h | 73 +++++++++++++++++++++++
cpukit/libcsupport/src/__usrenv.c | 4 +-
cpukit/libcsupport/src/readv.c | 21 +------
cpukit/libcsupport/src/writev.c | 21 +------
cpukit/libfs/Makefile.am | 2 +
cpukit/libfs/src/defaults/default_handlers.c | 4 +-
cpukit/libfs/src/defaults/default_readv.c | 60 +++++++++++++++++++
cpukit/libfs/src/defaults/default_writev.c | 60 +++++++++++++++++++
cpukit/libfs/src/devfs/devfs_init.c | 4 +-
cpukit/libfs/src/dosfs/msdos_handlers_dir.c | 24 ++++----
cpukit/libfs/src/dosfs/msdos_handlers_file.c | 24 ++++----
cpukit/libfs/src/imfs/imfs_fifo.c | 24 ++++----
cpukit/libfs/src/imfs/imfs_handlers_device.c | 24 ++++----
cpukit/libfs/src/imfs/imfs_handlers_directory.c | 24 ++++----
cpukit/libfs/src/imfs/imfs_handlers_link.c | 24 ++++----
cpukit/libfs/src/imfs/imfs_handlers_memfile.c | 24 ++++----
cpukit/libfs/src/jffs2/src/fs-rtems.c | 12 +++-
cpukit/libfs/src/nfsclient/src/nfs.c | 12 +++-
cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c | 4 +-
cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c | 4 +-
cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c | 4 +-
cpukit/libfs/src/rfs/rtems-rfs-rtems.c | 4 +-
cpukit/libnetworking/lib/ftpfs.c | 8 ++-
cpukit/libnetworking/lib/tftpDriver.c | 4 +-
cpukit/libnetworking/rtems/rtems_syscall.c | 24 ++++----
testsuites/fstests/fsimfsgeneric01/init.c | 49 +++++++++++++++-
28 files changed, 402 insertions(+), 148 deletions(-)
create mode 100644 cpukit/libfs/src/defaults/default_readv.c
create mode 100644 cpukit/libfs/src/defaults/default_writev.c
diff --git a/c/src/lib/libbsp/shared/umon/tfsDriver.c b/c/src/lib/libbsp/shared/umon/tfsDriver.c
index 20e5883..41c5809 100644
--- a/c/src/lib/libbsp/shared/umon/tfsDriver.c
+++ b/c/src/lib/libbsp/shared/umon/tfsDriver.c
@@ -675,5 +675,7 @@ static const rtems_filesystem_file_handlers_r rtems_tfs_handlers = {
.ftruncate_h = rtems_tfs_ftruncate,
.fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
.fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
- .fcntl_h = rtems_filesystem_default_fcntl
+ .fcntl_h = rtems_filesystem_default_fcntl,
+ .readv_h = rtems_filesystem_default_readv,
+ .writev_h = rtems_filesystem_default_writev
diff --git a/cpukit/libblock/src/blkdev-imfs.c b/cpukit/libblock/src/blkdev-imfs.c
index 256f90c..48d5515 100644
--- a/cpukit/libblock/src/blkdev-imfs.c
+++ b/cpukit/libblock/src/blkdev-imfs.c
@@ -220,7 +220,9 @@ static const rtems_filesystem_file_handlers_r rtems_blkdev_imfs_node = {
.ftruncate_h = rtems_filesystem_default_ftruncate,
.fsync_h = rtems_blkdev_imfs_fsync_or_fdatasync,
.fdatasync_h = rtems_blkdev_imfs_fsync_or_fdatasync,
static IMFS_jnode_t *rtems_blkdev_imfs_initialize(
diff --git a/cpukit/libcsupport/include/rtems/libio.h b/cpukit/libcsupport/include/rtems/libio.h
index 21d57eb..4bfa02a 100644
--- a/cpukit/libcsupport/include/rtems/libio.h
+++ b/cpukit/libcsupport/include/rtems/libio.h
@@ -29,6 +29,7 @@
#include <sys/stat.h>
#include <sys/ioctl.h>
#include <sys/statvfs.h>
+#include <sys/uio.h>
#include <unistd.h>
#include <termios.h>
@@ -808,6 +809,29 @@ typedef ssize_t (*rtems_filesystem_read_t)(
+ * @brief Reads an IO vector from a node.
+ * This handler is responsible to update the offset field of the IO descriptor.
+ * @param[in, out] iop The IO pointer.
+ * @param[in] iov The IO vector with buffer for read data. The caller must
+ * ensure that the IO vector values are valid.
+ * @param[in] iovcnt The count of buffers in the IO vector.
+ * @param[in] total The total count of bytes in the buffers in the IO vector.
+ * @retval non-negative Count of read characters.
+ * @retval -1 An error occurred. The errno is set to indicate the error.
+ * @see rtems_filesystem_default_readv().
+typedef ssize_t (*rtems_filesystem_readv_t)(
+ rtems_libio_t *iop,
+ const struct iovec *iov,
+ int iovcnt,
+ ssize_t total
* @brief Writes to a node.
@@ -828,6 +852,29 @@ typedef ssize_t (*rtems_filesystem_write_t)(
+ * @brief Writes an IO vector to a node.
+ * @param[in] iov The IO vector with buffer for write data. The caller must
+ * @retval non-negative Count of written characters.
+ * @see rtems_filesystem_default_writev().
+typedef ssize_t (*rtems_filesystem_writev_t)(
+ int iovcnt,
+ ssize_t total
* @brief IO control of a node.
@@ -992,6 +1039,8 @@ struct _rtems_filesystem_file_handlers_r {
rtems_filesystem_fcntl_t fcntl_h;
rtems_filesystem_poll_t poll_h;
rtems_filesystem_kqfilter_t kqfilter_h;
+ rtems_filesystem_readv_t readv_h;
+ rtems_filesystem_writev_t writev_h;
@@ -1033,6 +1082,18 @@ ssize_t rtems_filesystem_default_read(
+ * @brief Calls the read handler for each IO vector entry.
+ * @see rtems_filesystem_readv_t.
+ssize_t rtems_filesystem_default_readv(
+ int iovcnt,
+ ssize_t total
* @retval -1 Always. The errno is set to ENOTSUP.
* @see rtems_filesystem_write_t.
@@ -1044,6 +1105,18 @@ ssize_t rtems_filesystem_default_write(
+ * @brief Calls the write handler for each IO vector entry.
+ * @see rtems_filesystem_write_t.
+ssize_t rtems_filesystem_default_writev(
+ int iovcnt,
+ ssize_t total
* @retval -1 Always. The errno is set to ENOTTY.
* @see rtems_filesystem_ioctl_t.
diff --git a/cpukit/libcsupport/src/__usrenv.c b/cpukit/libcsupport/src/__usrenv.c
index 88058c4..f860447 100644
--- a/cpukit/libcsupport/src/__usrenv.c
+++ b/cpukit/libcsupport/src/__usrenv.c
@@ -54,7 +54,9 @@ const rtems_filesystem_file_handlers_r rtems_filesystem_null_handlers = {
static void null_op_lock_or_unlock(
diff --git a/cpukit/libcsupport/src/readv.c b/cpukit/libcsupport/src/readv.c
index 2400834..9720afd 100644
--- a/cpukit/libcsupport/src/readv.c
+++ b/cpukit/libcsupport/src/readv.c
@@ -36,31 +36,12 @@ ssize_t readv(
ssize_t total;
- int v;
rtems_libio_t *iop;
total = rtems_libio_iovec_eval( fd, iov, iovcnt, LIBIO_FLAGS_READ, &iop );
if ( total >= 0 ) {
- * Now process the readv().
- total = 0;
- for ( v = 0 ; v < iovcnt ; v++ ) {
- ssize_t bytes = ( *iop->pathinfo.handlers->read_h )(
- iop,
- iov[ v ].iov_base,
- iov[ v ].iov_len
- if ( bytes < 0 )
- return -1;
- total += bytes;
- if ( bytes != iov[ v ].iov_len )
- break;
+ total = ( *iop->pathinfo.handlers->readv_h )( iop, iov, iovcnt, total );
return total;
diff --git a/cpukit/libcsupport/src/writev.c b/cpukit/libcsupport/src/writev.c
index 1c7caf1..c6d1274 100644
--- a/cpukit/libcsupport/src/writev.c
+++ b/cpukit/libcsupport/src/writev.c
@@ -28,31 +28,12 @@ ssize_t writev(
ssize_t total;
- int v;
rtems_libio_t *iop;
total = rtems_libio_iovec_eval( fd, iov, iovcnt, LIBIO_FLAGS_WRITE, &iop );
if ( total >= 0 ) {
- * Now process the writev().
- total = 0;
- ssize_t bytes = ( *iop->pathinfo.handlers->write_h )(
- iop,
- iov[ v ].iov_len
- if ( bytes < 0 )
- return -1;
- total += bytes;
- break;
+ total = ( *iop->pathinfo.handlers->writev_h )( iop, iov, iovcnt, total );
return total;
diff --git a/cpukit/libfs/Makefile.am b/cpukit/libfs/Makefile.am
index 21bb7ef..b8c7790 100644
--- a/cpukit/libfs/Makefile.am
+++ b/cpukit/libfs/Makefile.am
@@ -35,6 +35,8 @@ libdefaultfs_a_SOURCES = \
src/defaults/default_handlers.c src/defaults/default_ops.c
libdefaultfs_a_SOURCES += src/defaults/default_kqfilter.c
libdefaultfs_a_SOURCES += src/defaults/default_poll.c
+libdefaultfs_a_SOURCES += src/defaults/default_readv.c
+libdefaultfs_a_SOURCES += src/defaults/default_writev.c
noinst_LIBRARIES += libimfs.a
libimfs_a_SOURCES =
diff --git a/cpukit/libfs/src/defaults/default_handlers.c b/cpukit/libfs/src/defaults/default_handlers.c
index 2a10a19..ce262b6 100644
--- a/cpukit/libfs/src/defaults/default_handlers.c
+++ b/cpukit/libfs/src/defaults/default_handlers.c
@@ -32,5 +32,7 @@ const rtems_filesystem_file_handlers_r rtems_filesystem_handlers_default = {
diff --git a/cpukit/libfs/src/defaults/default_readv.c b/cpukit/libfs/src/defaults/default_readv.c
new file mode 100644
index 0000000..eb09e60
--- /dev/null
+++ b/cpukit/libfs/src/defaults/default_readv.c
@@ -0,0 +1,60 @@
+ * @file
+ * @brief Default Read IO Vector Handler
+ * @ingroup LibIOFSHandler
+ * COPYRIGHT (c) 1989-2011.
+ * On-Line Applications Research Corporation (OAR).
+ * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/libio_.h>
+int rtems_filesystem_default_readv(
+ int iovcnt,
+ ssize_t total
+ int v;
+ total = 0;
+ for ( v = 0 ; v < iovcnt ; v++ ) {
+ ssize_t bytes = ( *iop->pathinfo.handlers->read_h )(
+ iop,
+ iov[ v ].iov_base,
+ iov[ v ].iov_len
+ if ( bytes < 0 )
+ return -1;
+ total += bytes;
+ if ( bytes != iov[ v ].iov_len )
+ break;
+ return total;
diff --git a/cpukit/libfs/src/defaults/default_writev.c b/cpukit/libfs/src/defaults/default_writev.c
index 0000000..abac0b8
--- /dev/null
+++ b/cpukit/libfs/src/defaults/default_writev.c
@@ -0,0 +1,60 @@
+ * @file
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#if HAVE_CONFIG_H
+#endif
+int rtems_filesystem_default_writev(
+ int iovcnt,
+ ssize_t total
+ int v;
+ total = 0;
+ ssize_t bytes = ( *iop->pathinfo.handlers->write_h )(
+ iop,
+ iov[ v ].iov_len
+ if ( bytes < 0 )
+ return -1;
+ total += bytes;
+ break;
+ return total;
diff --git a/cpukit/libfs/src/devfs/devfs_init.c b/cpukit/libfs/src/devfs/devfs_init.c
index e0dbe2f..4aa9f93 100644
--- a/cpukit/libfs/src/devfs/devfs_init.c
+++ b/cpukit/libfs/src/devfs/devfs_init.c
@@ -52,7 +52,9 @@ const rtems_filesystem_file_handlers_r devFS_file_handlers = {
int devFS_initialize(
diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
index 41efdb4..6d91603 100644
--- a/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
+++ b/cpukit/libfs/src/dosfs/msdos_handlers_dir.c
@@ -22,15 +22,17 @@
#include "msdos.h"
const rtems_filesystem_file_handlers_r msdos_dir_handlers = {
- rtems_filesystem_default_open,
- rtems_filesystem_default_close,
- msdos_dir_read,
- rtems_filesystem_default_write,
- rtems_filesystem_default_ioctl,
- rtems_filesystem_default_lseek_directory,
- msdos_dir_stat,
- rtems_filesystem_default_ftruncate_directory,
- msdos_sync,
- msdos_sync,
- rtems_filesystem_default_fcntl
+ .open_h = rtems_filesystem_default_open,
+ .close_h = rtems_filesystem_default_close,
+ .read_h = msdos_dir_read,
+ .write_h = rtems_filesystem_default_write,
+ .ioctl_h = rtems_filesystem_default_ioctl,
+ .lseek_h = rtems_filesystem_default_lseek_directory,
+ .fstat_h = msdos_dir_stat,
+ .ftruncate_h = rtems_filesystem_default_ftruncate_directory,
+ .fsync_h = msdos_sync,
+ .fdatasync_h = msdos_sync,
diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_file.c b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
index 2a3938d..d5885bb 100644
--- a/cpukit/libfs/src/dosfs/msdos_handlers_file.c
+++ b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
@@ -22,15 +22,17 @@
#include "msdos.h"
const rtems_filesystem_file_handlers_r msdos_file_handlers = {
- msdos_file_close,
- msdos_file_read,
- msdos_file_write,
- rtems_filesystem_default_lseek_file,
- msdos_file_stat,
- msdos_file_ftruncate,
- msdos_file_sync,
- msdos_sync,
+ .close_h = msdos_file_close,
+ .read_h = msdos_file_read,
+ .write_h = msdos_file_write,
+ .lseek_h = rtems_filesystem_default_lseek_file,
+ .fstat_h = msdos_file_stat,
+ .ftruncate_h = msdos_file_ftruncate,
+ .fsync_h = msdos_file_sync,
diff --git a/cpukit/libfs/src/imfs/imfs_fifo.c b/cpukit/libfs/src/imfs/imfs_fifo.c
index 03e6936..743261a 100644
--- a/cpukit/libfs/src/imfs/imfs_fifo.c
+++ b/cpukit/libfs/src/imfs/imfs_fifo.c
@@ -113,17 +113,19 @@ static int IMFS_fifo_ioctl(
static const rtems_filesystem_file_handlers_r IMFS_fifo_handlers = {
- IMFS_fifo_open,
- IMFS_fifo_close,
- IMFS_fifo_read,
- IMFS_fifo_write,
- IMFS_fifo_ioctl,
- rtems_filesystem_default_lseek,
- IMFS_stat,
- rtems_filesystem_default_ftruncate,
- rtems_filesystem_default_fsync_or_fdatasync,
+ .open_h = IMFS_fifo_open,
+ .close_h = IMFS_fifo_close,
+ .read_h = IMFS_fifo_read,
+ .write_h = IMFS_fifo_write,
+ .ioctl_h = IMFS_fifo_ioctl,
+ .lseek_h = rtems_filesystem_default_lseek,
+ .fstat_h = IMFS_stat,
+ .ftruncate_h = rtems_filesystem_default_ftruncate,
+ .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
const IMFS_node_control IMFS_node_control_fifo = {
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_device.c b/cpukit/libfs/src/imfs/imfs_handlers_device.c
index 899b3dc..451e201 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_device.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_device.c
@@ -34,17 +34,19 @@ static int IMFS_stat_device(
static const rtems_filesystem_file_handlers_r IMFS_device_handlers = {
- device_open,
- device_close,
- device_read,
- device_write,
- device_ioctl,
- IMFS_stat_device,
- device_ftruncate,
+ .open_h = device_open,
+ .close_h = device_close,
+ .read_h = device_read,
+ .write_h = device_write,
+ .ioctl_h = device_ioctl,
+ .fstat_h = IMFS_stat_device,
+ .ftruncate_h = device_ftruncate,
static IMFS_jnode_t *IMFS_node_initialize_device(
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_directory.c b/cpukit/libfs/src/imfs/imfs_handlers_directory.c
index 61ca552..ab267d7 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_directory.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_directory.c
@@ -50,17 +50,19 @@ static int IMFS_stat_directory(
static const rtems_filesystem_file_handlers_r IMFS_directory_handlers = {
- imfs_dir_read,
- IMFS_stat_directory,
- rtems_filesystem_default_fsync_or_fdatasync_success,
+ .read_h = imfs_dir_read,
+ .fstat_h = IMFS_stat_directory,
+ .fsync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
+ .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
static IMFS_jnode_t *IMFS_node_initialize_directory(
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_link.c b/cpukit/libfs/src/imfs/imfs_handlers_link.c
index 5118eb5..00f09fc 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_link.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_link.c
@@ -45,17 +45,19 @@ static int IMFS_stat_link(
static const rtems_filesystem_file_handlers_r IMFS_link_handlers = {
- rtems_filesystem_default_read,
- IMFS_stat_link,
+ .read_h = rtems_filesystem_default_read,
+ .fstat_h = IMFS_stat_link,
static IMFS_jnode_t *IMFS_node_initialize_hard_link(
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_memfile.c b/cpukit/libfs/src/imfs/imfs_handlers_memfile.c
index d0c5912..44ed856 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_memfile.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_memfile.c
@@ -34,17 +34,19 @@ static int IMFS_stat_file(
static const rtems_filesystem_file_handlers_r IMFS_memfile_handlers = {
- memfile_open,
- memfile_read,
- memfile_write,
- IMFS_stat_file,
- memfile_ftruncate,
+ .open_h = memfile_open,
+ .read_h = memfile_read,
+ .write_h = memfile_write,
+ .fstat_h = IMFS_stat_file,
+ .ftruncate_h = memfile_ftruncate,
const IMFS_node_control IMFS_node_control_memfile = {
diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
index 1b7d719..c8d6b9b 100644
--- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
+++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
@@ -516,7 +516,9 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_directory_handlers = {
static ssize_t rtems_jffs2_file_read(rtems_libio_t *iop, void *buf, size_t len)
@@ -654,7 +656,9 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_file_handlers = {
.ftruncate_h = rtems_jffs2_file_ftruncate,
static const rtems_filesystem_file_handlers_r rtems_jffs2_link_handlers = {
@@ -668,7 +672,9 @@ static const rtems_filesystem_file_handlers_r rtems_jffs2_link_handlers = {
static void rtems_jffs2_set_location(rtems_filesystem_location_info_t *loc, struct _inode *inode)
diff --git a/cpukit/libfs/src/nfsclient/src/nfs.c b/cpukit/libfs/src/nfsclient/src/nfs.c
index 99e34d5..c249522 100644
--- a/cpukit/libfs/src/nfsclient/src/nfs.c
+++ b/cpukit/libfs/src/nfsclient/src/nfs.c
@@ -2869,7 +2869,9 @@ struct _rtems_filesystem_file_handlers_r nfs_file_file_handlers = {
.ftruncate_h = nfs_file_ftruncate,
/* the directory handlers table */
@@ -2885,7 +2887,9 @@ struct _rtems_filesystem_file_handlers_r nfs_dir_file_handlers = {
/* the link handlers table */
@@ -2901,7 +2905,9 @@ struct _rtems_filesystem_file_handlers_r nfs_link_file_handlers = {
/* we need a dummy driver entry table to get a
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
index dbf9c16..ce1b77f 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
@@ -193,5 +193,7 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_device_handlers = {
.ftruncate_h = rtems_rfs_rtems_device_ftruncate,
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
index baf7155..eed110e 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
@@ -162,5 +162,7 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_dir_handlers = {
.fdatasync_h = rtems_rfs_rtems_fdatasync,
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
index a811ee5..412586d 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
@@ -353,5 +353,7 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_file_handlers = {
.ftruncate_h = rtems_rfs_rtems_file_ftruncate,
.fsync_h = rtems_rfs_rtems_fdatasync,
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
index 5f30cf7..60ab3bb 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
@@ -780,7 +780,9 @@ const rtems_filesystem_file_handlers_r rtems_rfs_rtems_link_handlers =
diff --git a/cpukit/libnetworking/lib/ftpfs.c b/cpukit/libnetworking/lib/ftpfs.c
index 784ff48..d622ff6 100644
--- a/cpukit/libnetworking/lib/ftpfs.c
+++ b/cpukit/libnetworking/lib/ftpfs.c
@@ -1412,7 +1412,9 @@ static const rtems_filesystem_file_handlers_r rtems_ftpfs_handlers = {
.ftruncate_h = rtems_ftpfs_ftruncate,
static const rtems_filesystem_file_handlers_r rtems_ftpfs_root_handlers = {
@@ -1426,5 +1428,7 @@ static const rtems_filesystem_file_handlers_r rtems_ftpfs_root_handlers = {
diff --git a/cpukit/libnetworking/lib/tftpDriver.c b/cpukit/libnetworking/lib/tftpDriver.c
index d549436..c6461e0 100644
--- a/cpukit/libnetworking/lib/tftpDriver.c
+++ b/cpukit/libnetworking/lib/tftpDriver.c
@@ -1051,5 +1051,7 @@ static const rtems_filesystem_file_handlers_r rtems_tftp_handlers = {
.ftruncate_h = rtems_tftp_ftruncate,
diff --git a/cpukit/libnetworking/rtems/rtems_syscall.c b/cpukit/libnetworking/rtems/rtems_syscall.c
index 727eac6..4aa7ad8 100644
--- a/cpukit/libnetworking/rtems/rtems_syscall.c
+++ b/cpukit/libnetworking/rtems/rtems_syscall.c
@@ -812,15 +812,17 @@ rtems_bsdnet_fstat (const rtems_filesystem_location_info_t *loc, struct stat *sp
static const rtems_filesystem_file_handlers_r socket_handlers = {
- rtems_filesystem_default_open, /* open */
- rtems_bsdnet_close, /* close */
- rtems_bsdnet_read, /* read */
- rtems_bsdnet_write, /* write */
- rtems_bsdnet_ioctl, /* ioctl */
- rtems_filesystem_default_lseek, /* lseek */
- rtems_bsdnet_fstat, /* fstat */
- rtems_filesystem_default_ftruncate, /* ftruncate */
- rtems_filesystem_default_fsync_or_fdatasync, /* fsync */
- rtems_filesystem_default_fsync_or_fdatasync, /* fdatasync */
- rtems_bsdnet_fcntl /* fcntl */
+ .close_h = rtems_bsdnet_close,
+ .read_h = rtems_bsdnet_read,
+ .write_h = rtems_bsdnet_write,
+ .ioctl_h = rtems_bsdnet_ioctl,
+ .fstat_h = rtems_bsdnet_fstat,
+ .fstat_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fcntl_h = rtems_bsdnet_fcntl,
diff --git a/testsuites/fstests/fsimfsgeneric01/init.c b/testsuites/fstests/fsimfsgeneric01/init.c
index 720a963..2eab2e4 100644
--- a/testsuites/fstests/fsimfsgeneric01/init.c
+++ b/testsuites/fstests/fsimfsgeneric01/init.c
@@ -20,6 +20,7 @@
#include <fcntl.h>
#include <unistd.h>
@@ -41,6 +42,8 @@ typedef enum {
TEST_FSYNC,
TEST_FDATASYNC,
TEST_FCNTL,
+ TEST_READV,
+ TEST_WRITEV,
TEST_CLOSED,
TEST_FSTAT_UNLINK,
TEST_REMOVED,
@@ -68,7 +71,7 @@ static int handler_close(
test_state *state = IMFS_generic_get_context_by_iop(iop);
- rtems_test_assert(*state == TEST_FCNTL);
+ rtems_test_assert(*state == TEST_WRITEV);
*state = TEST_CLOSED;
return 0;
@@ -202,6 +205,36 @@ static int handler_fcntl(
return 0;
+static ssize_t handler_readv(
+ int iovcnt,
+ ssize_t total
+ test_state *state = IMFS_generic_get_context_by_iop(iop);
+ rtems_test_assert(*state == TEST_FCNTL);
+ *state = TEST_READV;
+ return 0;
+static ssize_t handler_writev(
+ int iovcnt,
+ ssize_t total
+ rtems_test_assert(*state == TEST_READV);
+ *state = TEST_WRITEV;
+ return 0;
static const rtems_filesystem_file_handlers_r node_handlers = {
.open_h = handler_open,
.close_h = handler_close,
@@ -213,7 +246,9 @@ static const rtems_filesystem_file_handlers_r node_handlers = {
.ftruncate_h = handler_ftruncate,
.fsync_h = handler_fsync,
.fdatasync_h = handler_fdatasync,
- .fcntl_h = handler_fcntl
+ .fcntl_h = handler_fcntl,
+ .readv_h = handler_readv,
+ .writev_h = handler_writev
static IMFS_jnode_t *node_initialize(
@@ -269,6 +304,10 @@ static void test_imfs_make_generic_node(void)
char buf [1];
ssize_t n = 0;
off_t off = 0;
+ struct iovec iov = {
+ .iov_base = &buf [0],
+ .iov_len = (int) sizeof(buf)
rv = IMFS_make_generic_node(
path,
@@ -305,6 +344,12 @@ static void test_imfs_make_generic_node(void)
rv = fcntl(fd, F_GETFD);
rtems_test_assert(rv >= 0);
+ rv = readv(fd, &iov, 1);
+ rtems_test_assert(rv == 0);
+ rv = writev(fd, &iov, 1);
rv = close(fd);
1.7.7
