setitimer()
Joel Sherrill
Joel.Sherrill at OARcorp.com
Sat Dec 21 01:33:21 UTC 2013
Depending on what it is doing, using time fire after might be a better option.
On Dec 20, 2013 1:52 PM, "Claus, Ric" <claus at slac.stanford.edu> wrote:
A program that I’m trying to make compatible with RTEMS (iperf 2.0.5) uses the posix function setitimer(), which has only a trivial implementation under RTEMS. I modified the code as follows:
if ( mMode_Time ) {
memset (&it, 0, sizeof (it));
it.it_value.tv_sec = (int) (mSettings->mAmount / 100.0);
it.it_value.tv_usec = (int) 10000 * (mSettings->mAmount -
it.it_value.tv_sec * 100.0);
#ifndef __rtems__
err = setitimer( ITIMER_REAL, &it, NULL );
if ( err != 0 ) {
perror("setitimer");
exit(1);
#else
FAIL (mSettings->mAmount > UINT_MAX / 10000, "ualarm", mSettings);
ualarm(mSettings->mAmount * 10000, 0);
#endif
If implementing setitimer( ITIMER_REAL, … ) with ualarm() is a valid thing to do (please comment), would it be useful for me to provide a patch to setitimer() that operates this way? I’m not sure whether in this scenario the alarm must be cancelled with alarm(0, 0) later or not, but that would prevent this from being a generic solution.
Cheers,
Ric
rtems-devel mailing list
rtems-devel at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20131220/4b567a26/attachment-0001.html>
