[PATCH 3/7] score: atomic support for RTEMS. Atomic operations for i386.
Mon Feb 4 19:33:34 UTC 2013
 cpukit/score/cpu/i386/rtems/score/cpuatomic.h |  341 +++++++++++++++++++++++++
 1 files changed, 341 insertions(+), 0 deletions(-)
 create mode 100644 cpukit/score/cpu/i386/rtems/score/cpuatomic.h
diff --git a/cpukit/score/cpu/i386/rtems/score/cpuatomic.h b/cpukit/score/cpu/i386/rtems/score/cpuatomic.h
new file mode 100644
index 0000000..ae57584
--- /dev/null
+++ b/cpukit/score/cpu/i386/rtems/score/cpuatomic.h
@@ -0,0 +1,341 @@
+ * @file  rtems/score/cpuatomic.h
+ * This include file implements the atomic operations for i386 and defines
+ * atomic data types which are used by the atomic operations API file. This
+ * file should use fixed name cpuatomic.h and should be included in atomic
+ * operations API file atomic.h. Most of the parts of implementations are
+ * imported from FreeBSD kernel.
+ * Copyright (c) 1998 Doug Rabson
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
+#define _RTEMS_SCORE_ATOMIC_CPU_H
+#include <rtems/score/genericcpuatomic.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMS atomic implementation
+#if defined(RTEMS_SMP)
+#define	MPLOCKED	"lock ; "
+#else
+#define	MPLOCKED
+#endif
+#if !defined(RTEMS_SMP)
+ * We assume that a = b will do atomic loads and stores.  However, on a
+ * PentiumPro or higher, reads may pass writes, so for that case we have
+ * to use a serializing instruction (i.e. with LOCK) to do the load in
+ * SMP kernels.  For UP kernels, however, the cache of the single processor
+ * is always consistent, so we only need to take care of compiler.
+#define	ATOMIC_STORE_LOAD(NAME, TYPE, LOP, SOP)               \
+static inline Atomic_##TYPE                           \
+_CPU_Atomic_Load_##NAME(volatile Atomic_##TYPE *p)      \
+  Atomic_##TYPE tmp;                                    \
+  tmp = *p;                                             \
+  __asm __volatile("" : : : "memory");                  \
+  return (tmp);                                         \
+static inline _CPU_Atomic_Load_acq_##NAME(volatile Atomic_##TYPE *p)  \
+  tmp = *p;                                             \
+  return (tmp);                                         \
+static inline void                                    \
+_CPU_Atomic_Store_##NAME(volatile Atomic_##TYPE *p, Atomic_##TYPE v) \
+  *p = v;                                                            \
+_CPU_Atomic_Store_rel_##NAME(volatile Atomic_##TYPE *p, Atomic_##TYPE v) \
+  *p = v;        \
+#else /* !(!SMP) */
+  Atomic_##TYPE res;                                    \
+  __asm __volatile(MPLOCKED LOP                         \
+  : "=a" (res),                 /* 0 */                 \
+  "=m" (*p)                     /* 1 */                 \
+  : "m" (*p)                    /* 2 */                 \
+  : "memory", "cc");                                    \
+  return (res);                                         \
+_CPU_Atomic_Load_acq_##NAME(volatile Atomic_##TYPE *p)  \
+  return (res);                                         \
+ * The XCHG instruction asserts LOCK automagically.	\
+  __asm __volatile(SOP                                               \
+  : "=m" (*p),                  /* 0 */                              \
+  "+r" (v)                      /* 1 */                              \
+  : "memory");                                                       \
+  : "memory");                                                           \
+#endif /* !SMP */
+ * The assembly is volatilized to avoid code chunk removal by the compiler.
+ * GCC aggressively reorders operations and memory clobbering is necessary
+ * in order to avoid that for memory barriers.
+#define	ATOMIC_FETCH_GENERIC(NAME, TYPENAME, TYPE, OP, CONS, V)                         \
+_CPU_Atomic_Fetch_##NAME##_##TYPENAME(volatile Atomic_##TYPE *p, Atomic_##TYPE v) \
+  __asm __volatile(MPLOCKED OP                                                \
+  : "=m" (*p)        \
+  : CONS (V), "m" (*p)                                                        \
+  : "cc");        \
+_CPU_Atomic_Fetch_##NAME##_barr_##TYPENAME(volatile Atomic_##TYPE *p, Atomic_##TYPE v)\
+  : "=m" (*p)        \
+ * Atomic compare and set, used by the mutex functions
+ * if (*dst == expect) *dst = src (all 32 bit words)
+ * Returns 0 on failure, non-zero on success
+static inline int
+_CPU_Atomic_Compare_exchange_int(volatile Atomic_Int *dst, Atomic_Int expect, Atomic_Int src)
+  unsigned char res;
+  __asm __volatile(
+  "    " MPLOCKED "    "
+  "    cmpxchgl %2,%1 ;    "
+  "    sete	%0 ;       "
+  "1:                      "
+  "# atomic_cmpset_int"
+    "=m" (*dst)              /* 1 */
+  : "r" (src),               /* 2 */
+    "a" (expect),            /* 3 */
+    "m" (*dst)               /* 4 */
+  return (res);
+static inline int
+_CPU_Atomic_Compare_exchange_long(volatile Atomic_Long *dst, Atomic_Long expect, Atomic_Long src)
+  return (_CPU_Atomic_Compare_exchange_int((volatile Atomic_Int *)dst, (Atomic_Int)expect,
+         (Atomic_Int)src));
+ATOMIC_STORE_LOAD(int, Int,	"cmpxchgl %0,%1",  "xchgl %1,%0");
+ATOMIC_STORE_LOAD(long, Long,	"cmpxchgl %0,%1",  "xchgl %1,%0");
+ATOMIC_FETCH_GENERIC(add, int, Int, "addl %1,%0", "ir", v);
+ATOMIC_FETCH_GENERIC(sub, int, Int, "subl %1,%0", "ir", v);
+ATOMIC_FETCH_GENERIC(or,  int, Int, "orl %1,%0",  "ir", v);
+ATOMIC_FETCH_GENERIC(and, int, Int, "andl %1,%0", "ir", v);
+ATOMIC_FETCH_GENERIC(add, long, Long, "addl %1,%0", "ir", v);
+ATOMIC_FETCH_GENERIC(sub, long, Long, "subl %1,%0", "ir", v);
+ATOMIC_FETCH_GENERIC(or,  long, Long, "orl %1,%0",  "ir", v);
+ATOMIC_FETCH_GENERIC(and, long, Long, "andl %1,%0", "ir", v);
+#define	_CPU_Atomic_Fetch_or_acq_int		_CPU_Atomic_Fetch_or_barr_int
+#define	_CPU_Atomic_Fetch_or_rel_int		_CPU_Atomic_Fetch_or_barr_int
+#define	_CPU_Atomic_Fetch_and_acq_int		_CPU_Atomic_Fetch_and_barr_int
+#define	_CPU_Atomic_Fetch_and_rel_int		_CPU_Atomic_Fetch_and_barr_int
+#define	_CPU_Atomic_Fetch_add_acq_int		_CPU_Atomic_Fetch_add_barr_int
+#define	_CPU_Atomic_Fetch_add_rel_int		_CPU_Atomic_Fetch_add_barr_int
+#define	_CPU_Atomic_Fetch_sub_acq_int		_CPU_Atomic_Fetch_sub_barr_int
+#define	_CPU_Atomic_Fetch_sub_rel_int		_CPU_Atomic_Fetch_sub_barr_int
+#define	_CPU_Atomic_Compare_exchange_acq_int  _CPU_Atomic_Compare_exchange_int
+#define	_CPU_Atomic_Compare_exchange_rel_int  _CPU_Atomic_Compare_exchange_int
+#define	_CPU_Atomic_Fetch_or_acq_long		_CPU_Atomic_Fetch_or_barr_long
+#define	_CPU_Atomic_Fetch_or_rel_long		_CPU_Atomic_Fetch_or_barr_long
+#define	_CPU_Atomic_Fetch_and_acq_long		_CPU_Atomic_Fetch_and_barr_long
+#define	_CPU_Atomic_Fetch_and_rel_long		_CPU_Atomic_Fetch_and_barr_long
+#define	_CPU_Atomic_Fetch_add_acq_long		_CPU_Atomic_Fetch_add_barr_long
+#define	_CPU_Atomic_Fetch_add_rel_long		_CPU_Atomic_Fetch_add_barr_long
+#define	_CPU_Atomic_Fetch_sub_acq_long	        _CPU_Atomic_Fetch_sub_barr_long
+#define	_CPU_Atomic_Fetch_sub_rel_long	        _CPU_Atomic_Fetch_sub_barr_long
+#define	_CPU_Atomic_Compare_exchange_acq_long _CPU_Atomic_Compare_exchange_long
+#define	_CPU_Atomic_Compare_exchange_rel_long _CPU_Atomic_Compare_exchange_long
+/* Operations on 32-bit double words. */
+#define	_CPU_Atomic_Fetch_or_32(p, v)  \
+    _CPU_Atomic_Fetch_or_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Fetch_or_acq_32(p, v)  \
+    _CPU_Atomic_Fetch_or_acq_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Fetch_or_rel_32(p, v)  \
+    _CPU_Atomic_Fetch_or_rel_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Fetch_and_32(p, v)  \
+    _CPU_Atomic_Fetch_and_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Fetch_and_acq_32(p, v)  \
+    _CPU_Atomic_Fetch_and_acq_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Fetch_and_rel_32(p, v)  \
+    _CPU_Atomic_Fetch_and_rel_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Fetch_add_32(p, v)  \
+    _CPU_Atomic_Fetch_add_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Fetch_add_acq_32(p, v)  \
+    _CPU_Atomic_Fetch_add_acq_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Fetch_add_rel_32(p, v)  \
+    _CPU_Atomic_Fetch_add_rel_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Fetch_sub_32(p, v)  \
+    _CPU_Atomic_Fetch_sub_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Fetch_sub_acq_32(p, v)  \
+    _CPU_Atomic_Fetch_sub_acq_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Fetch_sub_rel_32(p, v)  \
+    _CPU_Atomic_Fetch_sub_rel_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Load_32(p)  \
+    _CPU_Atomic_Load_int((volatile Atomic_Int *)(p))
+#define	_CPU_Atomic_Load_acq_32(p)  \
+    _CPU_Atomic_Load_acq_int((volatile Atomic_Int *)(p))
+#define _CPU_Atomic_Store_32(p, v)  \
+    _CPU_Atomic_Store_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Store_rel_32(p, v)  \
+    _CPU_Atomic_Store_rel_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define	_CPU_Atomic_Compare_exchange_32(dst, old, new)  \
+    _CPU_Atomic_Compare_exchange_int((volatile Atomic_Int *)(dst), (Atomic_Int)(old), (Atomic_Int)(new))
+#define	_CPU_Atomic_Compare_exchange_acq_32(dst, old, new)  \
+    _CPU_Atomic_Compare_exchange_acq_int((volatile Atomic_Int *)(dst), (Atomic_Int)(old), (Atomic_Int)(new))
+#define	_CPU_Atomic_Compare_exchange_rel_32(dst, old, new)  \
+    _CPU_Atomic_Compare_exchange_rel_int((volatile Atomic_Int *)(dst), (Atomic_Int)(old), (Atomic_Int)(new))
+/* Operations on pointers. */
+#define	_CPU_Atomic_Fetch_or_ptr(p, v) \
+#define	_CPU_Atomic_Fetch_or_acq_ptr(p, v) \
+#define	_CPU_Atomic_Fetch_or_rel_ptr(p, v) \
+#define	_CPU_Atomic_Fetch_and_ptr(p, v) \
+#define	_CPU_Atomic_Fetch_and_acq_ptr(p, v) \
+#define	_CPU_Atomic_Fetch_and_rel_ptr(p, v) \
+#define	_CPU_Atomic_Fetch_add_ptr(p, v) \
+#define	_CPU_Atomic_Fetch_add_acq_ptr(p, v) \
+#define	_CPU_Atomic_Fetch_add_rel_ptr(p, v) \
+#define	_CPU_Atomic_Fetch_sub_ptr(p, v) \
+#define	_CPU_Atomic_Fetch_sub_acq_ptr(p, v) \
+#define	_CPU_Atomic_Fetch_sub_rel_ptr(p, v) \
+#define _CPU_Atomic_Load_ptr(p) \
+#define	_CPU_Atomic_Load_acq_ptr(p) \
+#define _CPU_Atomic_Store_ptr(p, v) \
+    _CPU_Atomic_Store_int((volatile Atomic_Int *)(p), (v))
+#define	_CPU_Atomic_Store_rel_ptr(p, v) \
+    _CPU_Atomic_Store_rel_int((volatile Atomic_Int *)(p), (v))
+#define	_CPU_Atomic_Compare_exchange_ptr(dst, old, new) \
+#define	_CPU_Atomic_Compare_exchange_acq_ptr(dst, old, new) \
+    _CPU_Atomic_Compare_exchange_acq_int((volatile Atomic_Int *)(dst), (Atomic_Int)(old), \
+            (Atomic_Int)(new))
+#define	_CPU_Atomic_Compare_exchange_rel_ptr(dst, old, new) \
+    _CPU_Atomic_Compare_exchange_rel_int((volatile Atomic_Int *)(dst), (Atomic_Int)(old), \
+#ifdef __cplusplus
+#endif
+#endif
+/*  end of include file */
1.7.1
