SPI Support for ARM/AT91RM9200
Wendell Silva
silvawp at gmail.com
Mon Feb 11 16:53:44 UTC 2013
2013/2/11 Wendell Silva <silvawp at gmail.com>
> More questions:
> - In order to make CSB337 working on the target hardware, I would like to
> disable MicroMonitor's support by default, since it was broken sometime in
> the past (between 4.9.99 until now). So I'm planing to add a new option
> like RTEMS_ENABLED_UMON_SUPPORT=0, at least until we can figure out why the
> system resets when monConnect() is called. Probably uMon needs to be
> recompiled too; anyway... Further details are documented in the RTEMS
> BugZilla (bug #2088). The question is: Do you agree with the creation of
> such a configuration option? This option would be in the BSP (csb337) level.
Sorry, I noticed that there exists an option ENABLE_UMON at BSP level. So,
all I need is ENABLE_UMON=0.
> - I'm doing these additions based on 4.11 (head). But, I would like to see
> them in 4.10.x too. So, once submitted, would they be merged to the 4.10.3
> in the near future?
> Thanks.
> --Wendell.
> 2013/2/11 Sebastian Huber <sebastian.huber at embedded-brains.de>
>> On 02/11/2013 04:39 PM, Wendell Silva wrote:
>>> Is c/src/lib/libcpu/arm/**at91rm9200/spi a good place it?
>> Yes.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> ______________________________**_________________
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130211/fd8e0064/attachment.html>
