[rtems commit] sparc64: revert linkcmds to 4 MB ram size
Mon Feb 11 20:57:15 UTC 2013
The niagara BSP does not work with the larger RAM size right now. The
larger size was tested with usiii. I need to eventually split the
linkcmds for the two, because they require different memory layouts.
For now, since niagara is the only BSP that can be tested on open
simulators [1], I will prefer to have the niagara working in the RTEMS
repo. With this patch, and the alignment fix, anyone should be able to
now follow my instructions to get a bootable RTEMS on the GEM5
simulator.
[1] http://gedare-csphd.blogspot.com/2013/02/rtems-on-gem5-sparc.html
On Mon, Feb 11, 2013 at 3:47 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Any particular reason why?  Just curious.
> On 2/11/2013 2:33 PM, Gedare Bloom wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    0241ab0c1453513fcc84b0deab0fc15f2f77f572
>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=0241ab0c1453513fcc84b0deab0fc15f2f77f572
>> Author:    Gedare Bloom <gedare at rtems.org>
>> Date:      Mon Feb 11 14:18:26 2013 -0500
>>   c/src/lib/libbsp/sparc64/shared/startup/linkcmds |    4 ++--
>>   1 files changed, 2 insertions(+), 2 deletions(-)
>> diff --git a/c/src/lib/libbsp/sparc64/shared/startup/linkcmds
>> b/c/src/lib/libbsp/sparc64/shared/startup/linkcmds
>> index 57d7c26..ae9688d 100644
>> --- a/c/src/lib/libbsp/sparc64/shared/startup/linkcmds
>> +++ b/c/src/lib/libbsp/sparc64/shared/startup/linkcmds
>> @@ -11,8 +11,8 @@
>>    * Declare some sizes.
>>   RamBase = DEFINED(RamBase) ? RamBase : 0x0;
>> -RamSize = DEFINED(RamSize) ? RamSize : 12M;
>> -HeapSize = DEFINED(HeapSize) ? HeapSize : 2M;
>> +RamSize = DEFINED(RamSize) ? RamSize : 4M;
>> +HeapSize = DEFINED(HeapSize) ? HeapSize : 1M;
>>     RAM_END = RamBase + RamSize;
>> rtems-vc mailing list
>> rtems-vc at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-vc
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
