LTO with static libraries
Sebastian Huber
Tue Feb 12 15:50:27 UTC 2013
Hello,
I currently do some testing with PowerPC GCC 4.8. On PowerPC and ARM RTEMS a
lot of LTO (link time optimization) tests fail. For example:
http://gcc.gnu.org/ml/gcc-testresults/2013-02/msg01371.html
Executing on host: /scratch/git-rtems-testing/gcc/b-powerpc-gcc/gcc/xgcc
-B/scratch/git-rtems-testing/gcc/b-powerpc-gcc/gcc/
/home/sh/archive/gcc-git/gcc/testsuite/gcc.c-torture/execute/builtins/20010124-1.c
/home/sh/archive/gcc-git/gcc/testsuite/gcc.c-torture/execute/builtins/20010124-1-lib.c
/home/sh/archive/gcc-git/gcc/testsuite/gcc.c-torture/execute/builtins/lib/main.c gcc_tg.o
-fno-diagnostics-show-caret -w -O2 -flto -fuse-linker-plugin
-fno-fat-lto-objects -fno-tree-loop-distribute-patterns -DSTACK_SIZE=2048
-isystem
/scratch/git-rtems-testing/gcc/b-powerpc-gcc/powerpc-rtems4.11/./newlib/targ-include
-isystem /home/sh/archive/gcc-git/newlib/libc/include
-B/scratch/git-rtems-testing/gcc/install-git/powerpc-rtems4.11/psim/lib/ -specs
bsp_specs -qrtems
-B/scratch/git-rtems-testing/gcc/b-powerpc-gcc/powerpc-rtems4.11/./newlib/
-L/scratch/git-rtems-testing/gcc/b-powerpc-gcc/powerpc-rtems4.11/./newlib
/scratch/git-rtems-testing/gcc/b-powerpc-gcc/rtems_gcc_main.o -Wl,-wrap,exit
-Wl,-wrap,_exit -Wl,-wrap,main -Wl,-wrap,abort -lm -o
/scratch/git-rtems-testing/gcc/b-powerpc-gcc/gcc/testsuite/gcc/20010124-1.x8
(timeout = 300)
spawn /scratch/git-rtems-testing/gcc/b-powerpc-gcc/gcc/xgcc
-isystem
bsp_specs -qrtems
/tmp/ccvxWHA6.ltrans0.ltrans.o: In function `memcpy':
ccvxWHA6.ltrans0.o:(.text+0x4): multiple definition of `memcpy'
/scratch/git-rtems-testing/gcc/b-powerpc-gcc/powerpc-rtems4.11/./newlib/libc.a(lib_a-memcpy.o):/home/sh/archive/gcc-git/newlib/libc/string/memcpy.c:79:
first defined here
collect2: error: ld returned 1 exit status
compiler exited with status 1
output is:
first defined here
FAIL: gcc.c-torture/execute/builtins/20010124-1.c compilation, -O2 -flto
-fuse-linker-plugin -fno-fat-lto-objects
See also:
http://gcc.gnu.org/ml/gcc-help/2011-10/msg00201.html
I used
binutils-2.23.1/configure --target=powerpc-rtems4.11 --disable-werror
to configure the Binutils. Has someone better experiences with LTO on RTEMS?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
