ARM RTEMS SMP Support
Wed Feb 13 23:39:30 UTC 2013
Xi
Can you post the URL for your project? And a general bit
on the status and target. That way if someone wants to help,
everything will be right here.
--joel
On 2/13/2013 4:56 PM, Xi Yang wrote:
> Hi Joel,
> On 14 February 2013 05:37, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> You just threw down the gauntlet to Xi Yang!! Time to
>> merge. :)
>> On 2/13/2013 12:02 PM, Claus, Ric wrote:
>> SMP is not available for ARM?  That's a big issue for me.  What's involved
>> to provide that support?
>> Compared to writing a BSP from scratch, not much. :)
>> You can look at either the pc386 or leon3 BSPs and associated
>> ports for an idea of how much code is architecture
>> and BSP specific.
>> Or even better.. help us merge the GSOC project by Xi Yang.
> Sorry, Joel. I was too busy to clean the code. I will try my best to
> submit the patches as soon as possible.
> By the way, I am doing a research project which is using RTEMS as the
> kernel for the small M3 ARM cores.
> Regards.
>> http://www.rtems.com/ml/rtems-users/2012/august/msg00084.html
>> has a github link. I suspect there may be some BSP or CPU model
>> variation between his work and yours.
>> Our atomic code is based off that in FreeBSD. So this would be the
>> starting point for the atomic.h support.
>> http://svnweb.freebsd.org/base/head/sys/arm/include/atomic.h?view=log&pathrev=151334
>> --joel
>> Ric
>> ________________________________________
>> From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] On
>> Behalf Of Joel Sherrill [joel.sherrill at OARcorp.com]
>> Sent: Wednesday, February 13, 2013 8:42 AM
>> To: yangwei weiyang
>> Cc: RTEMS Devel
>> Subject: Re: [rtems commit] tests: atomic support for RTEMS. Uniprocessor
>> tests for atomic ops.
>> On 2/13/2013 10:28 AM, yangwei weiyang wrote:
>> OK i am studying how to implement a common ISR_Disable and ISR_Enable
>> ops to simulate atomic ops. But it is just for the UP architectures,
>> for SMP architectures which are not supported by atomic now this will
>> not be suitable.
>> That's OK. The only architectures we currently support SMP on are
>> x86 and SPARC (only for LEON3).  Beyond powerpc and arm, I think
>> it is unlikely we will have SMP.
>> In general terms, if the CPU doesn't have atomic instructions
>> to implement these with, then it is very unlikely to ever show
>> up in an SMP configuration.  This makes the ISR disable/enable
>> implementation suitable for UP.
>> My biggest concerns is more general. I envision two common
>> scenarios within a single architecture:
>> + certain cpu models or architecture revisions have atomic
>>      instructions and some don't. But this is defined in the
>>     architecture and can be handled in cpukit. ISR disable/enable
>>      in some cases, real atomic in others.
>> + Similar case but CPU models have pulled instructions from
>>      architectural revisions "above" them. The instruction is
>>      there but not part of the real architectural revision the CPU
>>      model is based upon.
>> The isr disable/enable implementation may need to be available
>> all the time as a fallback.
>> --joel
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
