texinfo-5.0 available
Joel Sherrill
Joel.Sherrill at OARcorp.com
Sun Feb 17 17:03:40 UTC 2013
I tried versions while it was under development. It will take a while to hit distributions and user installs. We need to test against it. It may require some new probes to detect new versus old.
--joel
Gedare Bloom <gedare at rtems.org> wrote:
Nice. Are we ready to switch our doc build to it?
On Sun, Feb 17, 2013 at 11:10 AM, Joel Sherrill <joel.sherrill at oarcorp.com<mailto:joel.sherrill at oarcorp.com>> wrote:
Hi
This is what we were waiting for. :)
-------- Original Message --------
Subject: texinfo-5.0 available
Date: Sat, 16 Feb 2013 20:34:07 -0600
From: Karl Berry <karl at freefriends.org><mailto:karl at freefriends.org>
To: info-gnu at gnu.org<mailto:info-gnu at gnu.org> <info-gnu at gnu.org><mailto:info-gnu at gnu.org>
CC: bug-texinfo at gnu.org<mailto:bug-texinfo at gnu.org> <bug-texinfo at gnu.org><mailto:bug-texinfo at gnu.org>
We have released version 5.0 of Texinfo, the GNU documentation format.
It's available via a mirror (xz is much smaller than gz,
but gz is available too just in case):
http://ftpmirror.gnu.org/texinfo/texinfo-5.0.tar.xz
http://ftpmirror.gnu.org/texinfo/texinfo-5.0.tar.gz
Or if automatic redirection fails, the list of mirrors is at:
http://www.gnu.org/prep/ftp.html
Or if need be you can use the main GNU ftp server:
http://ftp.gnu.org/gnu/texinfo/texinfo-5.0.tar.xz
http://ftp.gnu.org/gnu/texinfo/texinfo-5.0.tar.gz
Or via rsync://ftp.gnu.org/gnu/texinfo/<http://ftp.gnu.org/gnu/texinfo/>; some mirrors also support rsync.
As you might imagine, there are numerous changes since the previous
release (4.13, over four long years ago). By far the biggest change is
a complete reimplementation of makeinfo. It is now much more flexible
but also, sadly, much slower, despite all our optimization efforts. We
hope all the many improvements make the new version worthwhile for users
nevertheless.
The full NEWS is below. It's also available at
http://cvs.savannah.gnu.org/viewvc/texinfo/texinfo/NEWS?view=markup
Please email bugs or suggestions to bug-texinfo at gnu.org<mailto:bug-texinfo at gnu.org>,
general discussion to help-texinfo at gnu.org<mailto:help-texinfo at gnu.org>.
The Texinfo home page: http://www.gnu.org/software/texinfo/
Special thanks to my colleagues Patrice Dumas (for creating the new makeinfo)
and Sergey Poznyakoff (for maintaining the standalone Info).
Happy documenting,
karl at gnu.org<mailto:karl at gnu.org>
Texinfo 5.0 (16 February 2013)
* Language:
. Texinfo commands are supported in node names.
. #line directives are recognized.
. @-commands are now recognized in raw format blocks. Therefore, for
example, lone @, { and } characters in @tex, @html and similar
environments must be converted to the normal @@, @{, and @} commands.
. new commands @inlinefmt and @inlineraw for brace-delimited conditionals.
. new conditionals @ifcommanddefined and @ifcommandnotdefined to test
if a Texinfo command is available.
. new command @part for a group of chapters.
. new environments @raggedright, @smallquotation,
@indentedblock, and @smallindentedblock.
. new commands @codequoteundirected and @codequotebacktick,
for a better interface than the @set variables; now respected by @kbd.
. new command @xrefautomaticsectiontitle to allow using section titles
in cross references by default, instead of node names.
. new commands for Texinfo special characters:
@atchar{} @lbracechar{} @rbracechar{} @backslashchar{} @hashchar{}.
. new commands @deftypefnnewline to print return types on their own lines.
. new command @headitemfont for the sake of template rows.
. new command @urefbreakstyle to control breaking of @url/@uref in TeX.
. new diacritic command @ogonek.
. new commands for Icelandic letters eth and thorn: @DH{} @dh{} @TH{} @th{}.
. new command @errormsg to report an error.
. five-argument xrefs can refer to a whole manual, by omitting the
section name and either omitting the node name or using "Top".
. DEL (0x7f = 0177 = 127) is a true comment character (catcode 14 in TeX).
* texi2any is the new generic converter for Texinfo that can produce all
supported output formats, both those from texi2dvi (PDF/DVI) and from
makeinfo (Info/HTML/etc.). texi2any and makeinfo are now different
names for the same program; there are no differences in behavior based
on the program name.
The new implementation is in Perl, requiring Perl 5.7.3 (released in
March 2002) and its standard Encode module.
The Perl texi2any/makeinfo both replaces and is intended to be (for
all practical purposes) upward-compatible with the C makeinfo. It has
many new features not in the C makeinfo. For example, cross-manual
references are now fully supported, and allows for extensive
customization of the HTML output. See the `Generic Translator
texi2any' chapter in the manual (among other places) for more about
this reimplementation.
The new program is, unfortunately, noticeably slower at present than
the C program was. We hope all the many improvements make the new
version worthwhile for users nevertheless.
* pod2texi is a new (Perl) program that uses the capabilities of
texi2any to translate Perl pod documentation to Texinfo.
* texinfo.tex:
. urls (given to @uref and @url) are broken by default at special
characters; behavior controllable with @urefbreakstyle.
. support some per-language hyphenation, when the underlying TeX
engine does (for instance, etex/pdfetex from TeX Live 2008 or
later). Words with accented letters are still not handled properly.
. @title, text will be broken if needed, and @* can be used to override.
. new Icelandic translation: txi-is.tex.
. new Hungarian translation: txi-hu.tex.
. official updates between full package releases available at
http://ftpmirror.gnu.org/texinfo/texinfo.tex.
* texi2dvi:
. new option --max-iterations.
http://ftpmirror.gnu.org/texinfo/texi2dvi.
* info:
. INFOPATH is determined from PATH by default, or if an element "PATH"
is specified.
. New command Info-virtual-index, bound to I by default, following Emacs.
. Info keywords not found by searches.
. A lower limit on the length of search patterns, default 1,
specified by the variable min-search-length.
. Use ASCII versions of images, if supplied by the document.
. xz compression supported.
* install-info:
* Documentation:
. new appendix with a technical description of the Info file format.
. information on the customizations of the HTML output now possible.
* Distribution:
. new file htmlxref.cnf is installed to support cross-manual
references; official updates between full package releases available
at http://ftpmirror.gnu.org/texinfo/htmlxref.cnf.
. language support for no removed/renamed to nb, per Norwegian translators.
. new translations: id it,
and document translations: eo pl.
. texinfo.cat<http://texinfo.cat> file removed since it is (to our knowledge) unused.
. documentation license now GFDLv1.3 or later.
. autoconf 2.69, automake 1.13.1, gettext 0.18.2.
rtems-devel mailing list
rtems-devel at rtems.org<mailto:rtems-devel at rtems.org>
http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130217/3b0afbe7/attachment.html>
