[PATCH 2/2] posix: Reimplement POSIX Key manager to use a red-black tree.
Fri Feb 22 14:38:24 UTC 2013
I pulled this from github using the latest pull request you sent.
Maybe you posted an updated patch somewhere? Check to make sure there
are no other major issues to deal with and let me know if there are
any updates for me to pull. I will be looking to commit this work
soon. I will figure out the confdefs.h issue myself.
On Thu, Feb 21, 2013 at 10:19 PM, Ashi <ashi08104 at gmail.com> wrote:
> Gedare, I feel this patch is a little old than my actually work, because
> some line I have removed before(like the "TODO" line), I haven't figured out
> which commit this patch is based.
> Anyway, I've updated according your comments.
> On Sat, Feb 9, 2013 at 9:15 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Feb 7, 2013 at 9:20 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> > From: Zhongwei Yao <ashi08104 at gmail.com>
>> > The POSIX Key manager is reimplemented with a red-black tree to store
>> > the keys and values. This code was contributed as part of GSOC 2012.
>> >  cpukit/posix/include/rtems/posix/key.h       |   56
>> >  cpukit/posix/include/rtems/posix/threadsup.h |    4 ++
>> >  cpukit/posix/inline/rtems/posix/key.inl      |    2 +-
>> >  cpukit/posix/src/key.c                       |   52
>> >  cpukit/posix/src/keycreate.c                 |   53
>> >  cpukit/posix/src/keydelete.c                 |    4 +-
>> >  cpukit/posix/src/keyfreememory.c             |   35 ++++++++++++-
>> >  cpukit/posix/src/keygetspecific.c            |   21 +++++---
>> >  cpukit/posix/src/keyrundestructors.c         |   68
>> >  cpukit/posix/src/keysetspecific.c            |   32 +++++++++---
>> >  cpukit/posix/src/pthread.c                   |    3 +
>> >  cpukit/sapi/src/posixapi.c                   |    2 +-
>> >  12 files changed, 216 insertions(+), 116 deletions(-)
>> > diff --git a/cpukit/posix/include/rtems/posix/key.h
>> > b/cpukit/posix/include/rtems/posix/key.h
>> > index 0bb1dbe..80e534b 100644
>> > --- a/cpukit/posix/include/rtems/posix/key.h
>> > +++ b/cpukit/posix/include/rtems/posix/key.h
>> > @@ -8,6 +8,7 @@
>> > + *  Copyright (c) 2012 Zhongwei Yao.
>> >   *  COPYRIGHT (c) 1989-2011.
>> >   *  On-Line Applications Research Corporation (OAR).
>> > @@ -20,6 +21,8 @@
>> >  #define _RTEMS_POSIX_KEY_H
>> >  #include <rtems/score/object.h>
>> > +#include <rtems/score/rbtree.h>
>> > +#include <rtems/score/chain.h>
>> >   * @defgroup POSIX_KEY POSIX Key
>> > @@ -34,32 +37,57 @@ extern "C" {
>> >  #endif
>> > - * This is the data Structure used to manage a POSIX key.
>> > - * NOTE: The Values is a table indexed by the index portion of the
>> > - *       ID of the currently executing thread.
>> > + * @brief The rbtree node used to manage a POSIX key and value.
>> >  typedef struct {
>> > -   /** This field is the Object control structure. */
>> > -   Objects_Control     Object;
>> > -   /** This field points to the optional destructor method. */
>> > -   void              (*destructor)( void * );
>> > -   /** This field points to the values per thread. */
>> > -   void              **Values[ OBJECTS_APIS_LAST + 1 ];
>> > -}  POSIX_Keys_Control;
>> > +  /** This field is the chain node structure. */
>> > +  Chain_Node ch_node;
>> > +  /** This field is the rbtree node structure. */
>> > +  RBTree_Node rb_node;
>> > +  /** This field is the POSIX key used as an rbtree key */
>> > +  pthread_key_t key;
>> > +  /** This field is the Thread id also used as an rbtree key */
>> > +  Objects_Id thread_id;
>> > +  /** This field points to the POSIX key value of specific thread */
>> > +  void *value;
>> > + }  POSIX_Keys_Rbtree_node;
>> > - * The following defines the information control block used to manage
>> > - * this class of objects.
>> > + * @brief The data structure used to manage a POSIX key.
>> > +typedef struct {
>> > +   /** This field is the Object control structure. */
>> > +   Objects_Control     object;
>> > +   /** This field is the data destructor. */
>> > +   void (*destructor) (void *);
>> > + }  POSIX_Keys_Control;
>> > + * @brief The information control block used to manage this class of
>> > objects.
>> >  POSIX_EXTERN Objects_Information  _POSIX_Keys_Information;
>> > + * @brief The rbtree control block used to manage all key values
>> > +POSIX_EXTERN RBTree_Control _POSIX_Keys_Rbtree;
>> >   * @brief POSIX keys manager initialization.
>> >   * This routine performs the initialization necessary for this manager.
>> > -void _POSIX_Key_Manager_initialization(void);
>> > +void _POSIX_Keys_Manager_initialization(void);
>> > + * @brief POSIX keys Red-Black tree node comparison.
>> > + * This routine compares the rbtree node
>> > +int _POSIX_Keys_Rbtree_compare_function(
>> > +  const RBTree_Node *node1,
>> > +  const RBTree_Node *node2
>> >   * @brief Create thread-specific data POSIX key.
>> > diff --git a/cpukit/posix/include/rtems/posix/threadsup.h
>> > b/cpukit/posix/include/rtems/posix/threadsup.h
>> > index 80f64dc..f47a7d4 100644
>> > --- a/cpukit/posix/include/rtems/posix/threadsup.h
>> > +++ b/cpukit/posix/include/rtems/posix/threadsup.h
>> > @@ -21,6 +21,7 @@
>> >  #include <sys/signal.h>
>> >  #include <rtems/score/coresem.h>
>> >  #include <rtems/score/tqdata.h>
>> >   *  @defgroup POSIX_THREAD POSIX Thread API Extension
>> > @@ -78,6 +79,9 @@ typedef struct {
>> >    int                     cancelation_requested;
>> >    /** This is the set of cancelation handlers. */
>> >    Chain_Control           Cancellation_Handlers;
>> > +  /** This is the thread key value chain's control */
>> > +  Chain_Control          the_chain;
>> Perhaps a more descriptive variable name? Also the name the_chain
>> should be in initial capitals because it is an aggregate structure.
>> Finally, we should make a note of why this chain exists.  it is
>> needed to iterate through the keys of a given thread when destroying
>> the thread.
> Yeah, that's the point. I've add a little more detail in comment.
>> >  } POSIX_API_Control;
>> > diff --git a/cpukit/posix/inline/rtems/posix/key.inl
>> > b/cpukit/posix/inline/rtems/posix/key.inl
>> > index ce5601b..9469580 100644
>> > --- a/cpukit/posix/inline/rtems/posix/key.inl
>> > +++ b/cpukit/posix/inline/rtems/posix/key.inl
>> > @@ -45,7 +45,7 @@ RTEMS_INLINE_ROUTINE void _POSIX_Keys_Free (
>> >    POSIX_Keys_Control *the_key
>> > -  _Objects_Free( &_POSIX_Keys_Information, &the_key->Object );
>> > +  _Objects_Free( &_POSIX_Keys_Information, &the_key->object );
>> > diff --git a/cpukit/posix/src/key.c b/cpukit/posix/src/key.c
>> > index 6eace26..b0a1f86 100644
>> > --- a/cpukit/posix/src/key.c
>> > +++ b/cpukit/posix/src/key.c
>> > @@ -29,6 +29,49 @@
>> >  #include <rtems/score/thread.h>
>> >  #include <rtems/score/wkspace.h>
>> >  #include <rtems/posix/key.h>
>> > + * _POSIX_Keys_Rbtree_compare_function
>> > + * DESCRIPTION:
>> > + * by comparing POSIX key first and comparing thread id second.
>> > + * And if either of the input nodes's thread_id member is 0, then
>> > + * it will only compare the pthread_key_t member. That is when we
>> > + * pass thread_id = 0 node as a search node, the search is done only
>> > + * by pthread_key_t.
>> > + * Input parameters: two rbtree node
>> > + * Output parameters: return positive if first node
>> > + * has higher key than second, negative if lower, 0 if equal,
>> > + * and for all the thread id is unique, then return 0 is impossible
>> > +  pthread_key_t key1 = _RBTree_Container_of(node1,
>> > POSIX_Keys_Rbtree_node, rb_node)->key;
>> > +  pthread_key_t key2 = _RBTree_Container_of(node2,
>> > +  Objects_Id thread_id1 = _RBTree_Container_of(node1,
>> > POSIX_Keys_Rbtree_node, rb_node)->thread_id;
>> > +  Objects_Id thread_id2 = _RBTree_Container_of(node2,
>> These lines are too long (>80 char) and need to be broken. I think
>> there are a few others in this patch too.
> I remember there is a  format check script, which I also have run it my
> code...
>> > +  int diff = key1 - key2;
>> > +  if ( diff )
>> > +    return diff;
>> > +   * if thread_id1 or thread_id2 equals to 0, only key1 and key2 is
>> > valued.
>> > +   * it enables us search node only by pthread_key_t type key.
>> > +  if ( thread_id1 && thread_id2 )
>> > +    return thread_id1 - thread_id2;
>> > +  return 0;
>> >   *  _POSIX_Key_Manager_initialization
>> > @@ -42,7 +85,7 @@
>> >   *  Output parameters:  NONE
>> >    _Objects_Initialize_information(
>> >      &_POSIX_Keys_Information,   /* object information table */
>> > @@ -60,4 +103,11 @@ void _POSIX_Key_Manager_initialization(void)
>> >      NULL                        /* Proxy extraction support callout */
>> >  #endif
>> > +  _RBTree_Initialize_empty(
>> > +    &_POSIX_Keys_Rbtree,     /* the rbtree control block */
>> > +    _POSIX_Keys_Rbtree_compare_function,
>> > +                            /* the rbtree compare function */
>> > +    true                    /* true if each rbtree node is unique */
>> I don't think the parameter comments here are necessary.
>> > diff --git a/cpukit/posix/src/keycreate.c b/cpukit/posix/src/keycreate.c
>> > index b41b590..84a4d9c 100644
>> > --- a/cpukit/posix/src/keycreate.c
>> > +++ b/cpukit/posix/src/keycreate.c
>> > @@ -37,10 +37,6 @@ int pthread_key_create(
>> >    POSIX_Keys_Control  *the_key;
>> > -  void                *table;
>> > -  uint32_t             the_api;
>> > -  uint32_t             bytes_to_allocate;
>> >    _Thread_Disable_dispatch();
>> > @@ -52,52 +48,9 @@ int pthread_key_create(
>> >    the_key->destructor = destructor;
>> > -   *  This is a bit more complex than one might initially expect
>> > because
>> > -   *  APIs are optional.
>> > -   *  NOTE: Currently RTEMS Classic API tasks are always enabled.
>> > -  for ( the_api = 1; the_api <= OBJECTS_APIS_LAST; the_api++ ) {
>> > -    the_key->Values[ the_api ] = NULL;
>> > -    #if defined(RTEMS_DEBUG)
>> > -       *  Since the removal of ITRON, this cannot occur.
>> > -      if ( !_Objects_Information_table[ the_api ] )
>> > -       continue;
>> > -       * Currently all managers are installed if the API is installed.
>> > -       * This would be a horrible implementation error.
>> > -      if (_Objects_Information_table[ the_api ][ 1 ] == NULL )
>> > -       _Internal_error_Occurred(
>> > -         INTERNAL_ERROR_CORE,
>> > -         true,
>> > -         INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY
>> > -    #endif
>> > -    bytes_to_allocate = sizeof( void * ) *
>> > -      (_Objects_Information_table[ the_api ][ 1 ]->maximum + 1);
>> > -    table = _Workspace_Allocate( bytes_to_allocate );
>> > -    if ( !table ) {
>> > -      _POSIX_Keys_Free_memory( the_key );
>> > -      _POSIX_Keys_Free( the_key );
>> > -      _Thread_Enable_dispatch();
>> > -      return ENOMEM;
>> > -    the_key->Values[ the_api ] = table;
>> > -    memset( table, '\0', bytes_to_allocate );
>> > -  _Objects_Open_u32( &_POSIX_Keys_Information, &the_key->Object, 0 );
>> > -  *key = the_key->Object.id;
>> > +  /*problem: not clear about _Objects_Open_u32() */
>> > +  _Objects_Open_u32( &_POSIX_Keys_Information, &the_key->object, 0 );
>> I believe you need to "open" the object for RTEMS object
>> tracking..like reference counting. Not sure though.
> OK.
>> > +  *key = the_key->object.id;
>> >    return 0;
>> > diff --git a/cpukit/posix/src/keydelete.c b/cpukit/posix/src/keydelete.c
>> > index 5ef6261..f45e264 100644
>> > --- a/cpukit/posix/src/keydelete.c
>> > +++ b/cpukit/posix/src/keydelete.c
>> > @@ -42,9 +42,9 @@ int pthread_key_delete(
>> >    switch ( location ) {
>> >      case OBJECTS_LOCAL:
>> > -      _Objects_Close( &_POSIX_Keys_Information, &the_key->Object );
>> > +      /* problem: should it done before _POSIX_Keys_Free_memory? */
>> > +      _Objects_Close( &_POSIX_Keys_Information, &the_key->object );
>> I think you need to be finished with the_key before closing it.
> I see.
>> >         *  NOTE:  The destructor is not called and it is the
>> > responsibility
>> > diff --git a/cpukit/posix/src/keyfreememory.c
>> > b/cpukit/posix/src/keyfreememory.c
>> > index f71af4f..50f560e 100644
>> > --- a/cpukit/posix/src/keyfreememory.c
>> > +++ b/cpukit/posix/src/keyfreememory.c
>> > @@ -21,14 +21,43 @@
>> >  #include <rtems/system.h>
>> >  void _POSIX_Keys_Free_memory(
>> > -  uint32_t            the_api;
>> > +  POSIX_Keys_Rbtree_node search_node;
>> > +  POSIX_Keys_Rbtree_node *p;
>> > +  RBTree_Node *iter, *next;
>> > -    _Workspace_Free( the_key->Values[ the_api ] );
>> > +  search_node.key = the_key->object.id;
>> > +  search_node.thread_id = 0;
>> > +  iter = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree,
>> > &search_node.rb_node);
>> > +  if ( !iter )
>> > +    return;
>> > +   * find the smallest thread_id node in the rbtree.
>> > +  next = _RBTree_Next_unprotected( iter, RBT_LEFT );
>> > +  p = _RBTree_Container_of( next, POSIX_Keys_Rbtree_node, rb_node );
>> > +  while ( p->key == the_key->object.id) {
>> > +    iter = next;
>> > +   * delete all nodes belongs to the_key from the rbtree and chain.
>> > +  p = _RBTree_Container_of( iter, POSIX_Keys_Rbtree_node, rb_node );
>> > +  while ( p->key == the_key->object.id ) {
>> > +    next = _RBTree_Next_unprotected( iter, RBT_RIGHT );
>> > +    _RBTree_Extract_unprotected( &_POSIX_Keys_Rbtree, iter );
>> > +    _Chain_Extract_unprotected( &p->ch_node );
>> > +    _Workspace_Free( p );
>> > +    iter = next;
>> > diff --git a/cpukit/posix/src/keygetspecific.c
>> > b/cpukit/posix/src/keygetspecific.c
>> > index debad83..61adea6 100644
>> > --- a/cpukit/posix/src/keygetspecific.c
>> > +++ b/cpukit/posix/src/keygetspecific.c
>> > @@ -26,6 +26,7 @@
>> > @@ -36,19 +37,23 @@ void *pthread_getspecific(
>> >    pthread_key_t  key
>> > -  register POSIX_Keys_Control *the_key;
>> > -  uint32_t                     api;
>> > -  uint32_t                     index;
>> >    Objects_Locations            location;
>> > +  RBTree_Node                 *p;
>> >    void                        *key_data;
>> > -  the_key = _POSIX_Keys_Get( key, &location );
>> > +  _POSIX_Keys_Get( key, &location );
>> >      case OBJECTS_LOCAL:
>> > -      api      = _Objects_Get_API( _Thread_Executing->Object.id );
>> > -      index    = _Objects_Get_index( _Thread_Executing->Object.id );
>> > -      key_data = (void *) the_key->Values[ api ][ index ];
>> > +      /** TODO: search the node in TCB's chain(maybe the rbtree) to
>> > speed up the search */
>> Is this TODO still relevant? I don't quite understand it.
> I thought search a node in chain's runtime is O(n1) and in rbtree is
> O(log(n2), where n2 is bigger than n1,
> so I think there is no big difference between these two and this TODO can be
> removed.
>> > +      search_node.key = key;
>> > +      search_node.thread_id = _Thread_Executing->Object.id;
>> > +      p = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree,
>> > +      key_data = NULL;
>> > +      if ( p ) {
>> > +        key_data = _RBTree_Container_of( p, POSIX_Keys_Rbtree_node,
>> > rb_node )->value;
>> >        return key_data;
>> > diff --git a/cpukit/posix/src/keyrundestructors.c
>> > b/cpukit/posix/src/keyrundestructors.c
>> > index 9f48888..687217c 100644
>> > --- a/cpukit/posix/src/keyrundestructors.c
>> > +++ b/cpukit/posix/src/keyrundestructors.c
>> > @@ -23,7 +23,10 @@
>> > +#include <rtems/score/wkspace.h>
>> > +#include <rtems/posix/threadsup.h>
>> >   *  _POSIX_Keys_Run_destructors
>> > @@ -38,36 +41,43 @@ void _POSIX_Keys_Run_destructors(
>> >    Thread_Control *thread
>> > -  Objects_Maximum thread_index = _Objects_Get_index( thread->Object.id
>> > -  Objects_APIs thread_api = _Objects_Get_API( thread->Object.id );
>> > -  bool done = false;
>> > +  Chain_Control *chain;
>> > +  Chain_Node *iter, *next;
>> > +  void *value;
>> > +  POSIX_Keys_Control *the_key;
>> > +  Objects_Locations location;
>> > -   *  The standard allows one to avoid a potential infinite loop and
>> > limit the
>> > -   *  number of iterations.  An infinite loop may happen if destructors
>> > set
>> > -   *  thread specific data.  This can be considered dubious.
>> > -   *  Reference: 17.1.1.2 P1003.1c/Draft 10, p. 163, line 99.
>> > -  while ( !done ) {
>> > -    Objects_Maximum index = 0;
>> > -    Objects_Maximum max = _POSIX_Keys_Information.maximum;
>> > +  _Thread_Disable_dispatch();
>> > +  chain = &((POSIX_API_Control *)thread->API_Extensions[
>> > THREAD_API_POSIX ])->the_chain;
>> > +  iter = _Chain_First( chain );
>> > +  while ( !_Chain_Is_tail( chain, iter ) ) {
>> > +    next = _Chain_Next( iter );
>> > +     * remove key from rbtree and chain.
>> > +     * here Chain_Node *iter can be convert to POSIX_Keys_Rbtree_node
>> > +     * because Chain_Node is the first member of POSIX_Keys_Rbtree_node
>> > structure.
>> > &((POSIX_Keys_Rbtree_node *)iter)->rb_node );
>> > +    _Chain_Extract_unprotected( iter );
>> > -    done = true;
>> > -    for ( index = 1 ; index <= max ; ++index ) {
>> > -      POSIX_Keys_Control *key = (POSIX_Keys_Control *)
>> > -        _POSIX_Keys_Information.local_table [ index ];
>> > -      if ( key != NULL && key->destructor != NULL ) {
>> > -        void *value = key->Values [ thread_api ][ thread_index ];
>> > -        if ( value != NULL ) {
>> > -          key->Values [ thread_api ][ thread_index ] = NULL;
>> > -          (*key->destructor)( value );
>> > -          done = false;
>> > +     * run key value's destructor if destructor and value are both
>> > non-null.
>> > +    the_key = _POSIX_Keys_Get( ((POSIX_Keys_Rbtree_node *)iter)->key,
>> > &location);
>> > +    destructor = the_key->destructor;
>> > +    value = ((POSIX_Keys_Rbtree_node *)iter)->value;
>> > +    if ( destructor != NULL && value != NULL )
>> > +      (*destructor)( value );
>> > +     * disable dispatch is nested here
>> > +    _Thread_Enable_dispatch();
>> > +    _Workspace_Free( (POSIX_Keys_Rbtree_node *)iter );
>> > +    iter = next;
>> > diff --git a/cpukit/posix/src/keysetspecific.c
>> > b/cpukit/posix/src/keysetspecific.c
>> > index b25e44c..eeb4d84 100644
>> > --- a/cpukit/posix/src/keysetspecific.c
>> > +++ b/cpukit/posix/src/keysetspecific.c
>> > @@ -26,7 +26,9 @@
>> >   *  17.1.2 Thread-Specific Data Management, P1003.1c/Draft 10, p. 165
>> > @@ -37,18 +39,34 @@ int pthread_setspecific(
>> >    const void    *value
>> > -  uint32_t                     api;
>> > -  uint32_t                     index;
>> > +  POSIX_Keys_Rbtree_node      *rb_node;
>> > +  POSIX_API_Control           *api;
>> > +  /** _POSIX_Keys_Get() would call _Thread_Disable_dispatch()
>> > implicitly*/
>> >      case OBJECTS_LOCAL:
>> > -      the_key->Values[ api ][ index ] = (void *) value;
>> > +      rb_node = _Workspace_Allocate( sizeof( POSIX_Keys_Rbtree_node )
>> This allocation needs to be accounted for in confdefs.h
> I remember we have discussed this before, the exactly post
> is:http://www.rtems.org/pipermail/rtems-devel/2012-August/001712.html,
> but seem there is no conclusion yet.
>> > +      if ( !rb_node ) {
>> > +        return ENOMEM;
>> > +      rb_node->key = key;
>> > +      rb_node->thread_id = _Thread_Executing->Object.id;
>> > +      rb_node->value = value;
>> > +      if (_RBTree_Insert_unprotected( &_POSIX_Keys_Rbtree,
>> > &(rb_node->rb_node) ) ) {
>> > +          _Workspace_Free( rb_node );
>> > +          return EAGAIN;
>> > +      /** append rb_node to the thread API extension's chain */
>> > +      api = (POSIX_API_Control
>> > *)(_Thread_Executing->API_Extensions[THREAD_API_POSIX]);
>> > +      _Chain_Append_unprotected( &api->the_chain, &rb_node->ch_node );
>> >        return 0;
>> > diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
>> > index 873449a..22c835f 100644
>> > --- a/cpukit/posix/src/pthread.c
>> > +++ b/cpukit/posix/src/pthread.c
>> > @@ -234,6 +234,9 @@ static bool _POSIX_Threads_Create_extension(
>> >      created
>> > +  /** initialize thread's key vaule node chain */
>> > +  _Chain_Initialize_empty( &api->the_chain );
>> >    return true;
>> > diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
>> > index 3f65442..b5e62c2 100644
>> > --- a/cpukit/sapi/src/posixapi.c
>> > +++ b/cpukit/sapi/src/posixapi.c
>> > @@ -64,7 +64,7 @@ void _POSIX_API_Initialize(void)
>> >    _POSIX_signals_Manager_Initialization();
>> >    _POSIX_Threads_Manager_initialization();
>> >    _POSIX_Condition_variables_Manager_initialization();
>> > -  _POSIX_Key_Manager_initialization();
>> > +  _POSIX_Keys_Manager_initialization();
>> >    _POSIX_Mutex_Manager_initialization();
>> >    _POSIX_Message_queue_Manager_initialization();
>> >    _POSIX_Semaphore_Manager_initialization();
>> > 1.7.1
