[PATCH 1/2] posix: Reimplement POSIX Key manager to use a red-black tree.
ashi ashi08104 at gmail.com
Sun Feb 24 14:12:08 UTC 2013
On Feb 23, 2013, at 10:52 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> Some quick comments. Reviewing on my Nexus 7 and I would love a client that let's you respond inline.
> Object field in the data structure should be named with capitalisation.
OK
> Look for "DESCRIPTION". convert this and similar blocks to Doxygen.
Sorry, I don't quite understand it, does it mean add a @brief … line above "DESCRIPTION"?
> Why was the manager initialization method renamed keys manager initialization? Others are singular.
I see, I'll change it back to singular.
> New files should follow style with @file comment block.
Does this apply to file in test cases? I find other files under testsuites/psxtests/ has no such block.
> No need for comment about disable dispatching above call to Get to convert from Id to pointer.
OK
> Gedare Bloom <gedare at rtems.org> wrote:
> From: Zhongwei Yao <ashi08104 at gmail.com>
> The POSIX Key manager is reimplemented with a red-black tree to store
> the keys and values. This code was contributed as part of GSOC 2012.
> cpukit/posix/include/rtems/posix/key.h       |   54 ++++++++++++++++-----
> cpukit/posix/include/rtems/posix/threadsup.h |   10 ++++
> cpukit/posix/inline/rtems/posix/key.inl      |    2 +-
> cpukit/posix/src/key.c                       |   59 ++++++++++++++++++++++-
> cpukit/posix/src/keycreate.c                 |   52 +-------------------
> cpukit/posix/src/keydelete.c                 |    3 +-
> cpukit/posix/src/keyfreememory.c             |   35 ++++++++++++-
> cpukit/posix/src/keygetspecific.c            |   20 +++++---
> cpukit/posix/src/keyrundestructors.c         |   67 +++++++++++++++----------
> cpukit/posix/src/keysetspecific.c            |   34 ++++++++++---
> cpukit/posix/src/pthread.c                   |    3 +
> cpukit/sapi/src/posixapi.c                   |    2 +-
> 12 files changed, 229 insertions(+), 112 deletions(-)
> diff --git a/cpukit/posix/include/rtems/posix/key.h b/cpukit/posix/include/rtems/posix/key.h
> index 0bb1dbe..f045dad 100644
> --- a/cpukit/posix/include/rtems/posix/key.h
> +++ b/cpukit/posix/include/rtems/posix/key.h
> @@ -8,6 +8,7 @@
> + *  Copyright (c) 2012 Zhongwei Yao.
>  *  COPYRIGHT (c) 1989-2011.
>  *  On-Line Applications Research Corporation (OAR).
> @@ -20,6 +21,8 @@
> #define _RTEMS_POSIX_KEY_H
> #include <rtems/score/object.h>
> +#include <rtems/score/rbtree.h>
> +#include <rtems/score/chain.h>
>  * @defgroup POSIX_KEY POSIX Key
> @@ -34,32 +37,57 @@ extern "C" {
> #endif
> - * This is the data Structure used to manage a POSIX key.
> - * NOTE: The Values is a table indexed by the index portion of the
> - *       ID of the currently executing thread.
> + * @brief The rbtree node used to manage a POSIX key and value.
> +typedef struct {
> +  /** This field is the chain node structure. */
> +  Chain_Node ch_node;
> +  /** This field is the rbtree node structure. */
> +  RBTree_Node rb_node;
> +  /** This field is the POSIX key used as an rbtree key */
> +  pthread_key_t key;
> +  /** This field is the Thread id also used as an rbtree key */
> +  Objects_Id thread_id;
> +  /** This field points to the POSIX key value of specific thread */
> +  void *value;
> + }  POSIX_Keys_Rbtree_node;
> + * @brief The data structure used to manage a POSIX key.
> typedef struct {
>    /** This field is the Object control structure. */
> -   Objects_Control     Object;
> -   /** This field points to the optional destructor method. */
> -   void              (*destructor)( void * );
> -   /** This field points to the values per thread. */
> -   void              **Values[ OBJECTS_APIS_LAST + 1 ];
> -}  POSIX_Keys_Control;
> +   Objects_Control     object;
> +   /** This field is the data destructor. */
> +   void (*destructor) (void *);
> + }  POSIX_Keys_Control;
> - * The following defines the information control block used to manage
> - * this class of objects.
> + * @brief The information control block used to manage this class of objects.
> POSIX_EXTERN Objects_Information  _POSIX_Keys_Information;
> + * @brief The rbtree control block used to manage all key values
> +POSIX_EXTERN RBTree_Control _POSIX_Keys_Rbtree;
>  * @brief POSIX keys manager initialization.
>  * This routine performs the initialization necessary for this manager.
> -void _POSIX_Key_Manager_initialization(void);
> +void _POSIX_Keys_Manager_initialization(void);
> + * @brief POSIX keys Red-Black tree node comparison.
> + * This routine compares the rbtree node
> +int _POSIX_Keys_Rbtree_compare_function(
> +  const RBTree_Node *node1,
> +  const RBTree_Node *node2
>  * @brief Create thread-specific data POSIX key.
> diff --git a/cpukit/posix/include/rtems/posix/threadsup.h b/cpukit/posix/include/rtems/posix/threadsup.h
> index 80f64dc..d746ea8 100644
> --- a/cpukit/posix/include/rtems/posix/threadsup.h
> +++ b/cpukit/posix/include/rtems/posix/threadsup.h
> @@ -21,6 +21,7 @@
> #include <sys/signal.h>
> #include <rtems/score/coresem.h>
> #include <rtems/score/tqdata.h>
>  *  @defgroup POSIX_THREAD POSIX Thread API Extension
> @@ -79,6 +80,15 @@ typedef struct {
>   /** This is the set of cancelation handlers. */
>   Chain_Control           Cancellation_Handlers;
> +   * This is the thread key value chain's control, which is used
> +   * to track all key value for specific thread, and when thread
> +   * exits, we can remove all key value for specific thread by
> +   * iterating this chain, or we have to search a whole rbtree,
> +   * which is inefficient.
> +  Chain_Control           Key_Chain;
> } POSIX_API_Control;
> diff --git a/cpukit/posix/inline/rtems/posix/key.inl b/cpukit/posix/inline/rtems/posix/key.inl
> index ce5601b..9469580 100644
> --- a/cpukit/posix/inline/rtems/posix/key.inl
> +++ b/cpukit/posix/inline/rtems/posix/key.inl
> @@ -45,7 +45,7 @@ RTEMS_INLINE_ROUTINE void _POSIX_Keys_Free (
>   POSIX_Keys_Control *the_key
> -  _Objects_Free( &_POSIX_Keys_Information, &the_key->Object );
> +  _Objects_Free( &_POSIX_Keys_Information, &the_key->object );
> diff --git a/cpukit/posix/src/key.c b/cpukit/posix/src/key.c
> index 6eace26..82c11af 100644
> --- a/cpukit/posix/src/key.c
> +++ b/cpukit/posix/src/key.c
> @@ -29,6 +29,57 @@
> #include <rtems/score/thread.h>
> #include <rtems/score/wkspace.h>
> #include <rtems/posix/key.h>
> + * _POSIX_Keys_Rbtree_compare_function
> + * DESCRIPTION:
> + * by comparing POSIX key first and comparing thread id second.
> + * And if either of the input nodes's thread_id member is 0, then
> + * it will only compare the pthread_key_t member. That is when we
> + * pass thread_id = 0 node as a search node, the search is done only
> + * by pthread_key_t.
> + * Input parameters: two rbtree node
> + * Output parameters: return positive if first node
> + * has higher key than second, negative if lower, 0 if equal,
> + * and for all the thread id is unique, then return 0 is impossible
> +  pthread_key_t key1 = _RBTree_Container_of(node1,
> +                                           POSIX_Keys_Rbtree_node,
> +                                           rb_node)->key;
> +  pthread_key_t key2 = _RBTree_Container_of(node2,
> +                                           rb_node)->key;
> +  Objects_Id thread_id1 = _RBTree_Container_of(node1,
> +                                              rb_node)->thread_id;
> +  Objects_Id thread_id2 = _RBTree_Container_of(node2,
> +  int diff = key1 - key2;
> +  if ( diff )
> +    return diff;
> +   * if thread_id1 or thread_id2 equals to 0, only key1 and key2 is valued.
> +   * it enables us search node only by pthread_key_t type key.
> +  if ( thread_id1 && thread_id2 )
> +    return thread_id1 - thread_id2;
> +  return 0;
>  *  _POSIX_Key_Manager_initialization
> @@ -42,7 +93,7 @@
>  *  Output parameters:  NONE
>   _Objects_Initialize_information(
>     &_POSIX_Keys_Information,   /* object information table */
> @@ -60,4 +111,10 @@ void _POSIX_Key_Manager_initialization(void)
>     NULL                        /* Proxy extraction support callout */
> #endif
> +  _RBTree_Initialize_empty(
> +    &_POSIX_Keys_Rbtree,
> +    _POSIX_Keys_Rbtree_compare_function,
> +    true
> diff --git a/cpukit/posix/src/keycreate.c b/cpukit/posix/src/keycreate.c
> index b41b590..09778c3 100644
> --- a/cpukit/posix/src/keycreate.c
> +++ b/cpukit/posix/src/keycreate.c
> @@ -37,10 +37,6 @@ int pthread_key_create(
>   POSIX_Keys_Control  *the_key;
> -  void                *table;
> -  uint32_t             the_api;
> -  uint32_t             bytes_to_allocate;
>   _Thread_Disable_dispatch();
> @@ -52,52 +48,8 @@ int pthread_key_create(
>   the_key->destructor = destructor;
> -   *  This is a bit more complex than one might initially expect because
> -   *  APIs are optional.
> -   *  NOTE: Currently RTEMS Classic API tasks are always enabled.
> -  for ( the_api = 1; the_api <= OBJECTS_APIS_LAST; the_api++ ) {
> -    the_key->Values[ the_api ] = NULL;
> -    #if defined(RTEMS_DEBUG)
> -       *  Since the removal of ITRON, this cannot occur.
> -      if ( !_Objects_Information_table[ the_api ] )
> -       continue;
> -       * Currently all managers are installed if the API is installed.
> -       * This would be a horrible implementation error.
> -      if (_Objects_Information_table[ the_api ][ 1 ] == NULL )
> -       _Internal_error_Occurred(
> -         INTERNAL_ERROR_CORE,
> -         true,
> -         INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY
> -    #endif
> -    bytes_to_allocate = sizeof( void * ) *
> -      (_Objects_Information_table[ the_api ][ 1 ]->maximum + 1);
> -    table = _Workspace_Allocate( bytes_to_allocate );
> -    if ( !table ) {
> -      _POSIX_Keys_Free_memory( the_key );
> -      _POSIX_Keys_Free( the_key );
> -      _Thread_Enable_dispatch();
> -      return ENOMEM;
> -    the_key->Values[ the_api ] = table;
> -    memset( table, '\0', bytes_to_allocate );
> -  _Objects_Open_u32( &_POSIX_Keys_Information, &the_key->Object, 0 );
> -  *key = the_key->Object.id;
> +  _Objects_Open_u32( &_POSIX_Keys_Information, &the_key->object, 0 );
> +  *key = the_key->object.id;
>   return 0;
> diff --git a/cpukit/posix/src/keydelete.c b/cpukit/posix/src/keydelete.c
> index 5ef6261..3f594bd 100644
> --- a/cpukit/posix/src/keydelete.c
> +++ b/cpukit/posix/src/keydelete.c
> @@ -42,8 +42,6 @@ int pthread_key_delete(
>   switch ( location ) {
>     case OBJECTS_LOCAL:
> -      _Objects_Close( &_POSIX_Keys_Information, &the_key->Object );
> @@ -51,6 +49,7 @@ int pthread_key_delete(
>        *         of the application to free the memory.
> +      _Objects_Close( &_POSIX_Keys_Information, &the_key->object );
>       return 0;
> diff --git a/cpukit/posix/src/keyfreememory.c b/cpukit/posix/src/keyfreememory.c
> index f71af4f..e01e6e9 100644
> --- a/cpukit/posix/src/keyfreememory.c
> +++ b/cpukit/posix/src/keyfreememory.c
> @@ -21,14 +21,43 @@
> #include <rtems/system.h>
> void _POSIX_Keys_Free_memory(
> -  uint32_t            the_api;
> +  POSIX_Keys_Rbtree_node search_node;
> +  POSIX_Keys_Rbtree_node *p;
> +  RBTree_Node *iter, *next;
> -    _Workspace_Free( the_key->Values[ the_api ] );
> +  search_node.key = the_key->object.id;
> +  search_node.thread_id = 0;
> +  iter = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree, &search_node.rb_node);
> +  if ( !iter )
> +    return;
> +   * find the smallest thread_id node in the rbtree.
> +  next = _RBTree_Next_unprotected( iter, RBT_LEFT );
> +  p = _RBTree_Container_of( next, POSIX_Keys_Rbtree_node, rb_node );
> +  while ( p->key == the_key->object.id) {
> +    iter = next;
> +   * delete all nodes belongs to the_key from the rbtree and chain.
> +  p = _RBTree_Container_of( iter, POSIX_Keys_Rbtree_node, rb_node );
> +  while ( p->key == the_key->object.id ) {
> +    next = _RBTree_Next_unprotected( iter, RBT_RIGHT );
> +    _RBTree_Extract_unprotected( &_POSIX_Keys_Rbtree, iter );
> +    _Chain_Extract_unprotected( &p->ch_node );
> +    _Workspace_Free( p );
> +    iter = next;
> diff --git a/cpukit/posix/src/keygetspecific.c b/cpukit/posix/src/keygetspecific.c
> index debad83..39c0fcc 100644
> --- a/cpukit/posix/src/keygetspecific.c
> +++ b/cpukit/posix/src/keygetspecific.c
> @@ -26,6 +26,7 @@
> @@ -36,19 +37,24 @@ void *pthread_getspecific(
>   pthread_key_t  key
> -  register POSIX_Keys_Control *the_key;
> -  uint32_t                     api;
> -  uint32_t                     index;
>   Objects_Locations            location;
> +  RBTree_Node                 *p;
>   void                        *key_data;
> -  the_key = _POSIX_Keys_Get( key, &location );
> +  _POSIX_Keys_Get( key, &location );
>     case OBJECTS_LOCAL:
> -      api      = _Objects_Get_API( _Thread_Executing->Object.id );
> -      index    = _Objects_Get_index( _Thread_Executing->Object.id );
> -      key_data = (void *) the_key->Values[ api ][ index ];
> +      search_node.key = key;
> +      search_node.thread_id = _Thread_Executing->Object.id;
> +      p = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree, &search_node.rb_node);
> +      key_data = NULL;
> +      if ( p ) {
> +        key_data = _RBTree_Container_of( p,
> +                                        rb_node )->value;
>       return key_data;
> diff --git a/cpukit/posix/src/keyrundestructors.c b/cpukit/posix/src/keyrundestructors.c
> index 9f48888..db31d2b 100644
> --- a/cpukit/posix/src/keyrundestructors.c
> +++ b/cpukit/posix/src/keyrundestructors.c
> @@ -23,7 +23,10 @@
> +#include <rtems/score/wkspace.h>
> +#include <rtems/posix/threadsup.h>
>  *  _POSIX_Keys_Run_destructors
> @@ -38,36 +41,46 @@ void _POSIX_Keys_Run_destructors(
>   Thread_Control *thread
> -  Objects_Maximum thread_index = _Objects_Get_index( thread->Object.id );
> -  Objects_APIs thread_api = _Objects_Get_API( thread->Object.id );
> -  bool done = false;
> +  Chain_Control *chain;
> +  Chain_Node *iter, *next;
> +  void *value;
> +  POSIX_Keys_Control *the_key;
> +  Objects_Locations location;
> -   *  The standard allows one to avoid a potential infinite loop and limit the
> -   *  number of iterations.  An infinite loop may happen if destructors set
> -   *  thread specific data.  This can be considered dubious.
> -   *  Reference: 17.1.1.2 P1003.1c/Draft 10, p. 163, line 99.
> -  while ( !done ) {
> -    Objects_Maximum index = 0;
> -    Objects_Maximum max = _POSIX_Keys_Information.maximum;
> +  _Thread_Disable_dispatch();
> -    done = true;
> +  chain = &((POSIX_API_Control *)\
> +           thread->API_Extensions[ THREAD_API_POSIX ])->Key_Chain;
> +  iter = _Chain_First( chain );
> +  while ( !_Chain_Is_tail( chain, iter ) ) {
> +    next = _Chain_Next( iter );
> +     * remove key from rbtree and chain.
> +     * here Chain_Node *iter can be convert to POSIX_Keys_Rbtree_node *,
> +     * because Chain_Node is the first member of POSIX_Keys_Rbtree_node
> +     * structure.
> +                                &((POSIX_Keys_Rbtree_node *)iter)->rb_node );
> +    _Chain_Extract_unprotected( iter );
> -    for ( index = 1 ; index <= max ; ++index ) {
> -      POSIX_Keys_Control *key = (POSIX_Keys_Control *)
> -        _POSIX_Keys_Information.local_table [ index ];
> +     * run key value's destructor if destructor and value are both non-null.
> +    the_key = _POSIX_Keys_Get( ((POSIX_Keys_Rbtree_node *)iter)->key,
> +                              &location);
> +    destructor = the_key->destructor;
> +    value = ((POSIX_Keys_Rbtree_node *)iter)->value;
> +    if ( destructor != NULL && value != NULL )
> +      (*destructor)( value );
> +     * disable dispatch is nested here
> +    _Thread_Enable_dispatch();
> -      if ( key != NULL && key->destructor != NULL ) {
> -        void *value = key->Values [ thread_api ][ thread_index ];
> -        if ( value != NULL ) {
> -          key->Values [ thread_api ][ thread_index ] = NULL;
> -          (*key->destructor)( value );
> -          done = false;
> +    _Workspace_Free( (POSIX_Keys_Rbtree_node *)iter );
> +    iter = next;
> diff --git a/cpukit/posix/src/keysetspecific.c b/cpukit/posix/src/keysetspecific.c
> index b25e44c..132061a 100644
> --- a/cpukit/posix/src/keysetspecific.c
> +++ b/cpukit/posix/src/keysetspecific.c
> @@ -26,7 +26,9 @@
>  *  17.1.2 Thread-Specific Data Management, P1003.1c/Draft 10, p. 165
> @@ -37,18 +39,36 @@ int pthread_setspecific(
>   const void    *value
> -  uint32_t                     api;
> -  uint32_t                     index;
> +  POSIX_Keys_Rbtree_node      *rb_node;
> +  POSIX_API_Control           *api;
> +  /** _POSIX_Keys_Get() would call _Thread_Disable_dispatch() implicitly*/
>     case OBJECTS_LOCAL:
> -      the_key->Values[ api ][ index ] = (void *) value;
> +      rb_node = _Workspace_Allocate( sizeof( POSIX_Keys_Rbtree_node ) );
> +      if ( !rb_node ) {
> +        return ENOMEM;
> +      rb_node->key = key;
> +      rb_node->thread_id = _Thread_Executing->Object.id;
> +      rb_node->value = value;
> +      if (_RBTree_Insert_unprotected( &_POSIX_Keys_Rbtree,
> +                                     &(rb_node->rb_node) ) ) {
> +          _Workspace_Free( rb_node );
> +          return EAGAIN;
> +      /** append rb_node to the thread API extension's chain */
> +      api = (POSIX_API_Control *)\
> +       (_Thread_Executing->API_Extensions[THREAD_API_POSIX]);
> +      _Chain_Append_unprotected( &api->Key_Chain, &rb_node->ch_node );
>       return 0;
> diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
> index 873449a..0ea44f1 100644
> --- a/cpukit/posix/src/pthread.c
> +++ b/cpukit/posix/src/pthread.c
> @@ -234,6 +234,9 @@ static bool _POSIX_Threads_Create_extension(
>     created
> +  /** initialize thread's key vaule node chain */
> +  _Chain_Initialize_empty( &api->Key_Chain );
>   return true;
> diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
> index 3f65442..b5e62c2 100644
> --- a/cpukit/sapi/src/posixapi.c
> +++ b/cpukit/sapi/src/posixapi.c
> @@ -64,7 +64,7 @@ void _POSIX_API_Initialize(void)
>   _POSIX_signals_Manager_Initialization();
>   _POSIX_Threads_Manager_initialization();
>   _POSIX_Condition_variables_Manager_initialization();
> -  _POSIX_Key_Manager_initialization();
> +  _POSIX_Keys_Manager_initialization();
>   _POSIX_Mutex_Manager_initialization();
>   _POSIX_Message_queue_Manager_initialization();
>   _POSIX_Semaphore_Manager_initialization();
> 1.7.1
> rtems-devel mailing list
> rtems-devel at rtems.org
thanks,
Zhongwei Yao
