[PATCH 1/2] posix: Reimplement POSIX Key manager to use a red-black tree.
Ashi
ashi08104 at gmail.com
Mon Feb 25 01:46:50 UTC 2013
Yeah, of course!
On Feb 23, 2013, at 10:52 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> Some quick comments. Reviewing on my Nexus 7 and I would love a client
that let's you respond inline.
> Object field in the data structure should be named with capitalisation.
OK
> Look for "DESCRIPTION". convert this and similar blocks to Doxygen.
Sorry, I don't quite understand it, does it mean add a @brief … line above
"DESCRIPTION"?
> Why was the manager initialization method renamed keys manager
initialization? Others are singular.
I see, I'll change it back to singular.
> New files should follow style with @file comment block.
Does this apply to file in test cases? I find other files under
testsuites/psxtests/ has no such block.
> No need for comment about disable dispatching above call to Get to
convert from Id to pointer.
OK
thanks,
Zhongwei Yao
On Mon, Feb 25, 2013 at 12:28 AM, Joel Sherrill
<joel.sherrill at oarcorp.com>wrote:
> I appear to have deleted the message I meant to reply to. :(
> It may have been to me directly since I can't find it in the archive.
> Can it be resent? Thanks.
> --joel
>> Object field in the data structure should be named with capitalization.
>> Gedare Bloom <gedare at rtems.org> wrote:
>> From: Zhongwei Yao <ashi08104 at gmail.com>
>> The POSIX Key manager is reimplemented with a red-black tree to store
>> the keys and values. This code was contributed as part of GSOC 2012.
>> cpukit/posix/include/rtems/**posix/key.h | 54
>> cpukit/posix/include/rtems/**posix/threadsup.h | 10 ++++
>> cpukit/posix/inline/rtems/**posix/key.inl | 2 +-
>> cpukit/posix/src/key.c | 59
>> cpukit/posix/src/keycreate.c | 52 +-------------------
>> cpukit/posix/src/keydelete.c | 3 +-
>> cpukit/posix/src/**keyfreememory.c | 35 ++++++++++++-
>> cpukit/posix/src/**keygetspecific.c | 20 +++++---
>> cpukit/posix/src/**keyrundestructors.c | 67
>> cpukit/posix/src/**keysetspecific.c | 34 ++++++++++---
>> cpukit/posix/src/pthread.c | 3 +
>> cpukit/sapi/src/posixapi.c | 2 +-
>> 12 files changed, 229 insertions(+), 112 deletions(-)
>> diff --git a/cpukit/posix/include/rtems/**posix/key.h
>> b/cpukit/posix/include/rtems/**posix/key.h
>> index 0bb1dbe..f045dad 100644
>> --- a/cpukit/posix/include/rtems/**posix/key.h
>> +++ b/cpukit/posix/include/rtems/**posix/key.h
>> @@ -8,6 +8,7 @@
>> + * Copyright (c) 2012 Zhongwei Yao.
>> * COPYRIGHT (c) 1989-2011.
>> * On-Line Applications Research Corporation (OAR).
>> @@ -20,6 +21,8 @@
>> #define _RTEMS_POSIX_KEY_H
>> #include <rtems/score/object.h>
>> +#include <rtems/score/rbtree.h>
>> +#include <rtems/score/chain.h>
>> * @defgroup POSIX_KEY POSIX Key
>> @@ -34,32 +37,57 @@ extern "C" {
>> #endif
>> - * This is the data Structure used to manage a POSIX key.
>> - * NOTE: The Values is a table indexed by the index portion of the
>> - * ID of the currently executing thread.
>> + * @brief The rbtree node used to manage a POSIX key and value.
>> +typedef struct {
>> + /** This field is the chain node structure. */
>> + Chain_Node ch_node;
>> + /** This field is the rbtree node structure. */
>> + RBTree_Node rb_node;
>> + /** This field is the POSIX key used as an rbtree key */
>> + pthread_key_t key;
>> + /** This field is the Thread id also used as an rbtree key */
>> + Objects_Id thread_id;
>> + /** This field points to the POSIX key value of specific thread */
>> + void *value;
>> + } POSIX_Keys_Rbtree_node;
>> + * @brief The data structure used to manage a POSIX key.
>> typedef struct {
>> /** This field is the Object control structure. */
>> - Objects_Control Object;
>> - /** This field points to the optional destructor method. */
>> - void (*destructor)( void * );
>> - /** This field points to the values per thread. */
>> - void **Values[ OBJECTS_APIS_LAST + 1 ];
>> -} POSIX_Keys_Control;
>> + Objects_Control object;
>> + /** This field is the data destructor. */
>> + void (*destructor) (void *);
>> + } POSIX_Keys_Control;
>> - * The following defines the information control block used to manage
>> - * this class of objects.
>> + * @brief The information control block used to manage this class of
>> objects.
>> POSIX_EXTERN Objects_Information _POSIX_Keys_Information;
>> + * @brief The rbtree control block used to manage all key values
>> +POSIX_EXTERN RBTree_Control _POSIX_Keys_Rbtree;
>> * @brief POSIX keys manager initialization.
>> * This routine performs the initialization necessary for this manager.
>> -void _POSIX_Key_Manager_**initialization(void);
>> +void _POSIX_Keys_Manager_**initialization(void);
>> + * @brief POSIX keys Red-Black tree node comparison.
>> + * This routine compares the rbtree node
>> +int _POSIX_Keys_Rbtree_compare_**function(
>> + const RBTree_Node *node1,
>> + const RBTree_Node *node2
>> * @brief Create thread-specific data POSIX key.
>> diff --git a/cpukit/posix/include/rtems/**posix/threadsup.h
>> b/cpukit/posix/include/rtems/**posix/threadsup.h
>> index 80f64dc..d746ea8 100644
>> --- a/cpukit/posix/include/rtems/**posix/threadsup.h
>> +++ b/cpukit/posix/include/rtems/**posix/threadsup.h
>> @@ -21,6 +21,7 @@
>> #include <sys/signal.h>
>> #include <rtems/score/coresem.h>
>> #include <rtems/score/tqdata.h>
>> * @defgroup POSIX_THREAD POSIX Thread API Extension
>> @@ -79,6 +80,15 @@ typedef struct {
>> /** This is the set of cancelation handlers. */
>> Chain_Control Cancellation_Handlers;
>> + * This is the thread key value chain's control, which is used
>> + * to track all key value for specific thread, and when thread
>> + * exits, we can remove all key value for specific thread by
>> + * iterating this chain, or we have to search a whole rbtree,
>> + * which is inefficient.
>> + Chain_Control Key_Chain;
>> } POSIX_API_Control;
>> diff --git a/cpukit/posix/inline/rtems/**posix/key.inl
>> b/cpukit/posix/inline/rtems/**posix/key.inl
>> index ce5601b..9469580 100644
>> --- a/cpukit/posix/inline/rtems/**posix/key.inl
>> +++ b/cpukit/posix/inline/rtems/**posix/key.inl
>> @@ -45,7 +45,7 @@ RTEMS_INLINE_ROUTINE void _POSIX_Keys_Free (
>> POSIX_Keys_Control *the_key
>> - _Objects_Free( &_POSIX_Keys_Information, &the_key->Object );
>> + _Objects_Free( &_POSIX_Keys_Information, &the_key->object );
>> diff --git a/cpukit/posix/src/key.c b/cpukit/posix/src/key.c
>> index 6eace26..82c11af 100644
>> --- a/cpukit/posix/src/key.c
>> +++ b/cpukit/posix/src/key.c
>> @@ -29,6 +29,57 @@
>> #include <rtems/score/thread.h>
>> #include <rtems/score/wkspace.h>
>> #include <rtems/posix/key.h>
>> + * _POSIX_Keys_Rbtree_compare_**function
>> + * DESCRIPTION:
>> + * by comparing POSIX key first and comparing thread id second.
>> + * And if either of the input nodes's thread_id member is 0, then
>> + * it will only compare the pthread_key_t member. That is when we
>> + * pass thread_id = 0 node as a search node, the search is done only
>> + * by pthread_key_t.
>> + * Input parameters: two rbtree node
>> + * Output parameters: return positive if first node
>> + * has higher key than second, negative if lower, 0 if equal,
>> + * and for all the thread id is unique, then return 0 is impossible
>> + pthread_key_t key1 = _RBTree_Container_of(node1,
>> + POSIX_Keys_Rbtree_node,
>> + rb_node)->key;
>> + pthread_key_t key2 = _RBTree_Container_of(node2,
>> + rb_node)->key;
>> + Objects_Id thread_id1 = _RBTree_Container_of(node1,
>> + rb_node)->thread_id;
>> + Objects_Id thread_id2 = _RBTree_Container_of(node2,
>> + int diff = key1 - key2;
>> + if ( diff )
>> + return diff;
>> + * if thread_id1 or thread_id2 equals to 0, only key1 and key2 is
>> valued.
>> + * it enables us search node only by pthread_key_t type key.
>> + if ( thread_id1 && thread_id2 )
>> + return thread_id1 - thread_id2;
>> + return 0;
>> * _POSIX_Key_Manager_**initialization
>> @@ -42,7 +93,7 @@
>> * Output parameters: NONE
>> _Objects_Initialize_**information(
>> &_POSIX_Keys_Information, /* object information table */
>> @@ -60,4 +111,10 @@ void _POSIX_Key_Manager_**initialization(void)
>> NULL /* Proxy extraction support callout */
>> #endif
>> + _RBTree_Initialize_empty(
>> + &_POSIX_Keys_Rbtree,
>> + _POSIX_Keys_Rbtree_compare_**function,
>> + true
>> diff --git a/cpukit/posix/src/keycreate.c b/cpukit/posix/src/keycreate.c
>> index b41b590..09778c3 100644
>> --- a/cpukit/posix/src/keycreate.c
>> +++ b/cpukit/posix/src/keycreate.c
>> @@ -37,10 +37,6 @@ int pthread_key_create(
>> POSIX_Keys_Control *the_key;
>> - void *table;
>> - uint32_t the_api;
>> - uint32_t bytes_to_allocate;
>> _Thread_Disable_dispatch();
>> @@ -52,52 +48,8 @@ int pthread_key_create(
>> the_key->destructor = destructor;
>> - * This is a bit more complex than one might initially expect because
>> - * APIs are optional.
>> - * NOTE: Currently RTEMS Classic API tasks are always enabled.
>> - for ( the_api = 1; the_api <= OBJECTS_APIS_LAST; the_api++ ) {
>> - the_key->Values[ the_api ] = NULL;
>> - #if defined(RTEMS_DEBUG)
>> - * Since the removal of ITRON, this cannot occur.
>> - if ( !_Objects_Information_table[ the_api ] )
>> - continue;
>> - * Currently all managers are installed if the API is installed.
>> - * This would be a horrible implementation error.
>> - if (_Objects_Information_table[ the_api ][ 1 ] == NULL )
>> - _Internal_error_Occurred(
>> - INTERNAL_ERROR_CORE,
>> - true,
>> - INTERNAL_ERROR_IMPLEMENTATION_**KEY_CREATE_INCONSISTENCY
>> - #endif
>> - bytes_to_allocate = sizeof( void * ) *
>> - (_Objects_Information_table[ the_api ][ 1 ]->maximum + 1);
>> - table = _Workspace_Allocate( bytes_to_allocate );
>> - if ( !table ) {
>> - _POSIX_Keys_Free_memory( the_key );
>> - _POSIX_Keys_Free( the_key );
>> - _Thread_Enable_dispatch();
>> - return ENOMEM;
>> - the_key->Values[ the_api ] = table;
>> - memset( table, '\0', bytes_to_allocate );
>> - _Objects_Open_u32( &_POSIX_Keys_Information, &the_key->Object, 0 );
>> - *key = the_key->Object.id;
>> + _Objects_Open_u32( &_POSIX_Keys_Information, &the_key->object, 0 );
>> + *key = the_key->object.id;
>> return 0;
>> diff --git a/cpukit/posix/src/keydelete.c b/cpukit/posix/src/keydelete.c
>> index 5ef6261..3f594bd 100644
>> --- a/cpukit/posix/src/keydelete.c
>> +++ b/cpukit/posix/src/keydelete.c
>> @@ -42,8 +42,6 @@ int pthread_key_delete(
>> switch ( location ) {
>> case OBJECTS_LOCAL:
>> - _Objects_Close( &_POSIX_Keys_Information, &the_key->Object );
>> @@ -51,6 +49,7 @@ int pthread_key_delete(
>> * of the application to free the memory.
>> + _Objects_Close( &_POSIX_Keys_Information, &the_key->object );
>> return 0;
>> diff --git a/cpukit/posix/src/**keyfreememory.c b/cpukit/posix/src/**
>> keyfreememory.c
>> index f71af4f..e01e6e9 100644
>> --- a/cpukit/posix/src/**keyfreememory.c
>> +++ b/cpukit/posix/src/**keyfreememory.c
>> @@ -21,14 +21,43 @@
>> #include <rtems/system.h>
>> void _POSIX_Keys_Free_memory(
>> - uint32_t the_api;
>> + POSIX_Keys_Rbtree_node search_node;
>> + POSIX_Keys_Rbtree_node *p;
>> + RBTree_Node *iter, *next;
>> - _Workspace_Free( the_key->Values[ the_api ] );
>> + search_node.key = the_key->object.id;
>> + search_node.thread_id = 0;
>> + iter = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree,
>> &search_node.rb_node);
>> + if ( !iter )
>> + return;
>> + * find the smallest thread_id node in the rbtree.
>> + next = _RBTree_Next_unprotected( iter, RBT_LEFT );
>> + p = _RBTree_Container_of( next, POSIX_Keys_Rbtree_node, rb_node );
>> + while ( p->key == the_key->object.id) {
>> + iter = next;
>> + * delete all nodes belongs to the_key from the rbtree and chain.
>> + p = _RBTree_Container_of( iter, POSIX_Keys_Rbtree_node, rb_node );
>> + while ( p->key == the_key->object.id ) {
>> + next = _RBTree_Next_unprotected( iter, RBT_RIGHT );
>> + _RBTree_Extract_unprotected( &_POSIX_Keys_Rbtree, iter );
>> + _Chain_Extract_unprotected( &p->ch_node );
>> + _Workspace_Free( p );
>> + iter = next;
>> diff --git a/cpukit/posix/src/**keygetspecific.c b/cpukit/posix/src/**
>> keygetspecific.c
>> index debad83..39c0fcc 100644
>> --- a/cpukit/posix/src/**keygetspecific.c
>> +++ b/cpukit/posix/src/**keygetspecific.c
>> @@ -26,6 +26,7 @@
>> @@ -36,19 +37,24 @@ void *pthread_getspecific(
>> pthread_key_t key
>> - register POSIX_Keys_Control *the_key;
>> - uint32_t api;
>> - uint32_t index;
>> Objects_Locations location;
>> + RBTree_Node *p;
>> void *key_data;
>> - the_key = _POSIX_Keys_Get( key, &location );
>> + _POSIX_Keys_Get( key, &location );
>> case OBJECTS_LOCAL:
>> - api = _Objects_Get_API( _Thread_Executing->Object.id );
>> - index = _Objects_Get_index( _Thread_Executing->Object.id );
>> - key_data = (void *) the_key->Values[ api ][ index ];
>> + search_node.key = key;
>> + search_node.thread_id = _Thread_Executing->Object.id;
>> + p = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree,
>> + key_data = NULL;
>> + if ( p ) {
>> + key_data = _RBTree_Container_of( p,
>> + rb_node )->value;
>> return key_data;
>> diff --git a/cpukit/posix/src/**keyrundestructors.c b/cpukit/posix/src/**
>> keyrundestructors.c
>> index 9f48888..db31d2b 100644
>> --- a/cpukit/posix/src/**keyrundestructors.c
>> +++ b/cpukit/posix/src/**keyrundestructors.c
>> @@ -23,7 +23,10 @@
>> +#include <rtems/score/wkspace.h>
>> +#include <rtems/posix/threadsup.h>
>> * _POSIX_Keys_Run_destructors
>> @@ -38,36 +41,46 @@ void _POSIX_Keys_Run_destructors(
>> Thread_Control *thread
>> - Objects_Maximum thread_index = _Objects_Get_index( thread->Object.id );
>> - Objects_APIs thread_api = _Objects_Get_API( thread->Object.id );
>> - bool done = false;
>> + Chain_Control *chain;
>> + Chain_Node *iter, *next;
>> + void *value;
>> + POSIX_Keys_Control *the_key;
>> + Objects_Locations location;
>> - * The standard allows one to avoid a potential infinite loop and
>> limit the
>> - * number of iterations. An infinite loop may happen if destructors
>> set
>> - * thread specific data. This can be considered dubious.
>> - * Reference: 17.1.1.2 P1003.1c/Draft 10, p. 163, line 99.
>> - while ( !done ) {
>> - Objects_Maximum index = 0;
>> - Objects_Maximum max = _POSIX_Keys_Information.**maximum;
>> + _Thread_Disable_dispatch();
>> - done = true;
>> + chain = &((POSIX_API_Control *)\
>> + thread->API_Extensions[ THREAD_API_POSIX ])->Key_Chain;
>> + iter = _Chain_First( chain );
>> + while ( !_Chain_Is_tail( chain, iter ) ) {
>> + next = _Chain_Next( iter );
>> + * remove key from rbtree and chain.
>> + * here Chain_Node *iter can be convert to POSIX_Keys_Rbtree_node *,
>> + * because Chain_Node is the first member of POSIX_Keys_Rbtree_node
>> + * structure.
>> + &((POSIX_Keys_Rbtree_node
>> *)iter)->rb_node );
>> + _Chain_Extract_unprotected( iter );
>> - for ( index = 1 ; index <= max ; ++index ) {
>> - POSIX_Keys_Control *key = (POSIX_Keys_Control *)
>> - _POSIX_Keys_Information.local_**table [ index ];
>> + * run key value's destructor if destructor and value are both
>> non-null.
>> + the_key = _POSIX_Keys_Get( ((POSIX_Keys_Rbtree_node *)iter)->key,
>> + &location);
>> + destructor = the_key->destructor;
>> + value = ((POSIX_Keys_Rbtree_node *)iter)->value;
>> + if ( destructor != NULL && value != NULL )
>> + (*destructor)( value );
>> + * disable dispatch is nested here
>> + _Thread_Enable_dispatch();
>> - if ( key != NULL && key->destructor != NULL ) {
>> - void *value = key->Values [ thread_api ][ thread_index ];
>> - if ( value != NULL ) {
>> - key->Values [ thread_api ][ thread_index ] = NULL;
>> - (*key->destructor)( value );
>> - done = false;
>> + _Workspace_Free( (POSIX_Keys_Rbtree_node *)iter );
>> + iter = next;
>> diff --git a/cpukit/posix/src/**keysetspecific.c b/cpukit/posix/src/**
>> keysetspecific.c
>> index b25e44c..132061a 100644
>> --- a/cpukit/posix/src/**keysetspecific.c
>> +++ b/cpukit/posix/src/**keysetspecific.c
>> @@ -26,7 +26,9 @@
>> * 17.1.2 Thread-Specific Data Management, P1003.1c/Draft 10, p. 165
>> @@ -37,18 +39,36 @@ int pthread_setspecific(
>> const void *value
>> - uint32_t api;
>> - uint32_t index;
>> + POSIX_Keys_Rbtree_node *rb_node;
>> + POSIX_API_Control *api;
>> + /** _POSIX_Keys_Get() would call _Thread_Disable_dispatch()
>> implicitly*/
>> case OBJECTS_LOCAL:
>> - the_key->Values[ api ][ index ] = (void *) value;
>> + rb_node = _Workspace_Allocate( sizeof( POSIX_Keys_Rbtree_node ) );
>> + if ( !rb_node ) {
>> + return ENOMEM;
>> + rb_node->key = key;
>> + rb_node->thread_id = _Thread_Executing->Object.id;
>> + rb_node->value = value;
>> + if (_RBTree_Insert_unprotected( &_POSIX_Keys_Rbtree,
>> + &(rb_node->rb_node) ) ) {
>> + _Workspace_Free( rb_node );
>> + return EAGAIN;
>> + /** append rb_node to the thread API extension's chain */
>> + api = (POSIX_API_Control *)\
>> + (_Thread_Executing->API_**Extensions[THREAD_API_POSIX]);
>> + _Chain_Append_unprotected( &api->Key_Chain, &rb_node->ch_node );
>> return 0;
>> diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
>> index 873449a..0ea44f1 100644
>> --- a/cpukit/posix/src/pthread.c
>> +++ b/cpukit/posix/src/pthread.c
>> @@ -234,6 +234,9 @@ static bool _POSIX_Threads_Create_**extension(
>> created
>> + /** initialize thread's key vaule node chain */
>> + _Chain_Initialize_empty( &api->Key_Chain );
>> return true;
>> diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
>> index 3f65442..b5e62c2 100644
>> --- a/cpukit/sapi/src/posixapi.c
>> +++ b/cpukit/sapi/src/posixapi.c
>> @@ -64,7 +64,7 @@ void _POSIX_API_Initialize(void)
>> _POSIX_signals_Manager_**Initialization();
>> _POSIX_Threads_Manager_**initialization();
>> _POSIX_Condition_variables_**Manager_initialization();
>> - _POSIX_Key_Manager_**initialization();
>> + _POSIX_Keys_Manager_**initialization();
>> _POSIX_Mutex_Manager_**initialization();
>> _POSIX_Message_queue_Manager_**initialization();
>> _POSIX_Semaphore_Manager_**initialization();
>> 1.7.1
>> ______________________________**_________________
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130225/82856473/attachment.html>
